Transition from 125cc to 600 cc
bonkersz
PostPosted: 23:14 - 31 Oct 2009    Post subject: Transition from 125cc to 600 cc Reply with quote
What are the main differences between riding a 125 and a 600 ?
Apart from the obvious , like an extra gear , more speed and heavier weight .
I am about to buy a 600 cc which is my first bike , can anyone give me any tips ?
What is the major transition from 125 to 600 ? Will i find it difficult to change ?
c fnjfnejf
wizzzard
PostPosted: 23:20 - 31 Oct 2009    Post subject: Reply with quote
The main transition for me was the throttle response. I went from a 125 to a 750 and nothing else really came as a great suprise other than the delicacy of the throttle.
Alexio
PostPosted: 03:04 - 01 Nov 2009    Post subject: Reply with quote
You won't have to have the throttle entirely open absolutely everywhere any more I imagine and seeming as the weight of the bike will increase the corners are likely to be different (not more difficult but need to be taken with much more care to the throttle too).
There are certain things that are pretty much impossible to mess up on due to a lack of power for accelerating and braking on a 125. Lots more room for error once you move up Thumbs Up for example... I have ridden before like a crazy person when it's pouring down with rain, overtaking at 60MPH +. If you get your throttle wrong on a 600 doing that then you could be off if you ride it like a 125.
aargh
PostPosted: 03:54 - 01 Nov 2009    Post subject: Reply with quote
If you mentioned to 4 cylinders 600cc, I think that you should give try to a 2 cylinders 500 cc bike before having it. Imho it could be better to get used to handle weight and steering of the big machines. By the way, throttle response of 600c bikes can be a problem if you have not enough experience.
My first bike is YBR125 and the veterans around me advised me no to ride 600cc bike in a short term. So that presently I have GS 500 and realized that the guys are totally right. Riders must upgrade the bikes step by step.
A rider from Istanbul, TR.
'06 Yamaha YBR 125 black | '04 Suzuki GS 500 blue | '04 Suzuki DL 650 V-Strom black | '17 Honda NC 750X red | '17 Honda CRF1000L Africa Twin Tricolor | '22 Aprilia Tuono 660 Factory Dark
iooi
PostPosted: 09:05 - 01 Nov 2009    Post subject: Reply with quote
You will find that the weight and steering will be a improvement as will the stability on the road.
Just remember the throttle to brain interface is your biggest issue.
No more winding the throttle to the stop to set off or after changing gears, unless you really are in a fast mood.
Weight is only a problem when you are stood still. Once moving its no diffrent.
So unlike your 125 once they start to fall over you tend to let them go down slowly as if you trying to stop it from falling, over often results in more body pain than anything else.....
I went from 250 to 600 and found it a far better ride all round and so long as you are aware that the only real diffrence is the throttle and how it effects everything.
You will be OK and don't worry about it.
Faraz
PostPosted: 11:51 - 01 Nov 2009    Post subject: Reply with quote
This is the main thing. Take it very easy.
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
Mord
PostPosted: 11:57 - 01 Nov 2009    Post subject: Reply with quote
Yay.. and I want to jump from 125cc 2 stroke to Ducati 748 V2 yay.. There is a hardly a throttle response in 2 strokes.. they wake up at 6-7k rpm.
Jrod
Page 3 Girl
PostPosted: 17:19 - 01 Nov 2009    Post subject: Reply with quote
Don't agree, just have to be careful.
Noxious89123
PostPosted: 20:56 - 01 Nov 2009    Post subject: Reply with quote
I understand what you mean, but I disagree in a way...
It's quite easy and safe to jump staright to a screamin 600cc sportsbike, you just have to make sure you are totally aware of the fact that you must ride it alot more delicately than a 125. On a 125, there is very little link between throttle and power. With a 600, you open it wide through second gear, and by the time you finish saying "oh fuck" you'll be doing well over legal speeds.
You just have to take baby steps and get used to the bike, rather than jumping on and riding it the same as a 125.
mr_s81
PostPosted: 23:26 - 01 Nov 2009    Post subject: Reply with quote
For me anyway, wind became less of a factor (not mine I should hasten to add Wink ) When I was learning I rode a Kawasaki AR125 which was a great little bike, but because it was so light, if there was any wind at all I found myself being blown all over the road.
After passing my test and moving on to a SV650 I found that the bike was much less affected by breezy conditions and much more stable. So although the extra weight can become a little disconcerting at slow speed. Once your on the move it definitely has its advantages! Thumbs Up
PostPosted: 07:05 - 02 Nov 2009    Post subject: Reply with quote
+1
Take it easy to begin with. You'll be fine.
I went from a restricted 400, to a full power 600 and didn't find it that much of an issue.
Pussy Magnet
PostPosted: 07:40 - 02 Nov 2009    Post subject: Reply with quote
yes throttle response and the shire weight of the bike would be a bit of a difference.
tsmith
PostPosted: 09:45 - 02 Nov 2009    Post subject: Reply with quote
you'll be able to overtake everything, cars will seem much slower. Acceleration is incredible, 100mph is easy and can be reached on any straight bit of road.
I didn't find much difference with braking, the 125 had worse brakes but was much lighter so in the end braking was about the same.
Don't slingshot in corners though, I found this out the hard way. On the 125, the main place I overtook cars was coming out of corners as it was the only time they slowed down. Grab a handful of throttle mid corner on a 600 and the back end can slide out.
Oh and turns in the road - on a 125 its easy. On a big bike the turning circle can be way bigger. You may need to go up onto the curb or do a 3 point turn to get round.
fuel economy is worse on a 600, insurance is higher and tyres cost more.
chart06
PostPosted: 10:40 - 02 Nov 2009    Post subject: Reply with quote
Thumbs Up Thumbs Up Thumbs Up
my first bike is gsxr 600 (30 days owned) and no problems. Its fast of course but u dont have to speed all the time. My bike feels like its just perfect for me at the moment, im thinking bout 1100 cc tho Laughing
swordheart
PostPosted: 12:34 - 02 Nov 2009    Post subject: Reply with quote
Sorry for hijacking this thread but it seems a waste making a new thread for it Neutral
So as regards big bikes would you say 600cc and above is a lot different to anything lower, i ask because i may hopefully be doing my DAS in a few weeks and i presume i will be using a 500cc bike, i am 5ft 10 and 10.5 stone so could i have any probs with the bike ?
wizzzard
PostPosted: 12:43 - 02 Nov 2009    Post subject: Reply with quote
I used a CB500 for my DAS and I'm 5'9". Never had any problems with the weight at all and if anything it was a lot more stable at any speed.
As to whether a 600 or above is a lot different to anything lower, that really does depend on the bikes in question. I currently ride a zzr600 and it is as sedate and sensible as you could wish for at lower revs, certainly no worse than the CB I rode. I had a FZR1000 up until a few months ago and that was a completely different kettle of fish.
swordheart
PostPosted: 12:47 - 02 Nov 2009    Post subject: Reply with quote
Thanks, thats good to know i was starting to have a few concerns about that particular issue.
iooi
PostPosted: 12:52 - 02 Nov 2009    Post subject: Reply with quote
Turning circle on my 600 is less than my last 250....
And the ins is way cheaper went from £130 on a zzr250 to £70 for the xj600.... Both were same year and value.
Tis nice when you get cash back from ins co's Laughing
There is no problem going from a small low power bike to a larger more powerfull one.
So long as the rider understands what you are in control of and treats the twisty bit on the RHS with respect.
Alexio
PostPosted: 14:13 - 02 Nov 2009    Post subject: Reply with quote
Turning circle is related to wheel base length and turning is related to bike weight.
Some 600's are near as light as some 125's and the same goes for wheel base I guess?
Paulington
PostPosted: 14:24 - 02 Nov 2009    Post subject: Reply with quote
As people have said, you just need to be more aware of what your right wrist is doing and when it's doing it.
I went from a 24bhp 125cc to a 100bhp 600cc and I had no issues whatsoever. As people said just be aware. If I pinned the throttle in 1st on my 125cc I'd be doing 25mph or so at redline, with the 600cc in 1st gear if I pin the throttle the front end comes up and at redline I'm doing around 65mph.
Have fun and good luck. Thumbs Up.
Jrod
Page 3 Girl
PostPosted: 23:03 - 02 Nov 2009    Post subject: Reply with quote
I went from 3 years with no bike to a zx12r.I don't think theres a much bigger jump than that.
I havn't dropped it, havn't even had any 'moments' as I knew It wasn't comething to mess about with so I've been careful.
Skynet-T800
PostPosted: 23:35 - 03 Nov 2009    Post subject: Reply with quote
Went from my Scooter to an R6.
Not a major issue, but when I first saw it I though god look at the size of that thing.
Wasn't so bad, as mentioned the throttle is dangerous if your ham fisted.
The brakes shocked me on a motorway I once used too much pressure on the front brake lever and that made my clench at the power of them- respect.
Syx
PostPosted: 15:10 - 09 Nov 2009    Post subject: Reply with quote
If you are confident on the 125, then don't let yourself get worked up about moving to the 600. I did exactly the same, and the only differences are what have already been mentioned - the throttle, brakes and stability.
I had managed to get myself into a state of worry meaning that I was near petrified the first time I sat on mine... and for nothing. Just be calm and collected about that first ride and you won't have any problems. Thumbs Up
ashwell-09
PostPosted: 15:03 - 13 Nov 2009    Post subject: Reply with quote
I had a 50 on and off for two years, got rid of it and then did my A2 and got a 400 CBR, it's wierd how quickly you adjust to the bike but i think being paranoid for the first few weeks/months depending on how well you adjust to it will do you good because you never stop thinking about what needs to be done. Just take it easy and don't open up too much exiting corners. Be careful this time of year too because heavier bike - alot harder to control in shitty conditions.
Riding as fast as you can sounds like a good speed to me
1988 Yamaha DT 50 > 2004 Motorhispania RYZ 50 > 1988 Honda CBR 400
AcIdBuRnZ
PostPosted: 15:18 - 13 Nov 2009    Post subject: Reply with quote
Over the years I went from an NSR125, to an ER-5 after passing my full license, then a ZZR-600 before getting my current bike GSXR-750.
To be honest, it depends on the bike. I thought the ER-5 was a handful at first after the 2 stroke, and then I found the ZZR a screamer after that, and even going from 600 to 750 was a big jump, as the Gixer is bloody insane, but only if you want it to be.
Point is take it easy, as already said the biggest change is in weight of the bike, throttle response (the Gixer is so twitchy) and also the brakes. The Gixer has wavy discs and semi-road/race pads and the bite is scary. I'm actually more scared of the braking than anything else as it is so powerful.
Hope this helps.
The last post was made 16 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 134.54 Kb
