stuck bolt
baldy
PostPosted: 15:55 - 21 Jun 2004    Post subject: stuck bolt Reply with quote
Hi,
I recently noticed that my back brake had started squeaking on my nsr and put it down to the pads. Problem.... the bolt holding the pads in is seized into the caliper and with it being a crappy straight bladed screwdriver type it is now nickered and definetley won't budge. Any suggestions?
Cheers.
One day i will rule the world, just not today.
mr jamez
PostPosted: 16:09 - 21 Jun 2004    Post subject: Reply with quote
You could try clamping the caliper down (if it is off the bike) and using a cold chisel/punch and hammer to turn the bolt, might be tricky with it on the bike. Not sure if you could drill it out or not, could screw the thread up. I think their is one on ebay at the moment if you are feeling lazy Smile
Soaking it in wd40 a few times and leaving it for a while is also good prior to trying to remove it Thumbs Up
DaveS
PostPosted: 16:14 - 21 Jun 2004    Post subject: Reply with quote
Of course be careful spraying wd40 near the brakes.
mr jamez
PostPosted: 16:56 - 21 Jun 2004    Post subject: Reply with quote
If he is changing the pads then it doesn't really matter, unless of course he isn't, just assuming here Shifty
PostPosted: 00:16 - 22 Jun 2004    Post subject: Reply with quote
Probably your best bet is an impact driver.
The last post was made 22 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 44.03 Kb
