Owning a 125 2 stroke...
craigs23
Mr Muscle
PostPosted: 14:06 - 01 Nov 2009    Post subject: Owning a 125 2 stroke... Reply with quote
...what do I need to know?
I've never owned a 2 stroke before, but I'm tempted to look for one (most likely an Aprilia RS) as a project/fun/toy bike.
I've read the odd post here and there, about how easy the strokers are to work on, but what do I really need to know in regards to:
Frequency of engine rebuilds - what's likely going to be needed on a regular basis - when, what and how much?
2 stroke oil - I understand that this is burnt in the combustion chamber and is fed from a separate tank - is this much like a secondary fuel tank - how much is needed over what kind of distance?
Fuel consumption - likely to be a lot lower than what I'm used to from a 125 bike, but what sort of figures am I to expect?
Any major difference between the newest RS125s and the older models? Other than looks, obviously - are they both similar in terms of maintenance schedules/reliability?
And lastly - anyone care to post some pictures of their own models, and your thoughts/stories of such little beasties?
Paulington
PostPosted: 14:16 - 01 Nov 2009    Post subject: Reply with quote
On most 2 stroke 125s you are probably looking at once every 10k miles, Aprilia suggest the first rebuild at 16000km so around that distance. As for what it's usually just a piston and cylinder, probably costing you around £200-£400 or so.
Yes it is like a secondary fuel tank, most 125s just put a small tank under the seat to put the oil in. My 125 uses around a litre of oil per 25 litres of fuel, 25:1 ratio which is about right as that's what my Kart uses also which is a Rotax 125.
My 125cc does about 100-120 miles to a FULL tank (including reserve) which is 13 litres, it is not good on fuel at all haha.
Yeah going to be similar, they are hardly different besides a bit more power and looks that I know of.
My bike, it's the same as a Derbi GPR125R:
https://i176.photobucket.com/albums/w182/OllieePaul/GileraSC125.jpg
As much as I love the bike, as flickable and fun as it is I just find it lacks power. I enjoy being able to turn my right wrist and something to happen, whereas if you're in 2nd gear or above on the 125 you just don't get that.
HTH. Thumbs Up.
PostPosted: 14:19 - 01 Nov 2009    Post subject: Re: Owning a 125 2 stroke... Reply with quote
Warm it up before thrashing it, and look after it.
Piston and rings every 10k ish - check the bore shape and smoothness each time. Inspect the ports etc.
Usually does about 5-10 fuel tanks to a refil of 2t, but there is a light so you don't need to worry about running out. Use good fully synthetic oil like Castrol TTS.
Yeah it will be bad, but I can't say that it will be any worse than something like a CBR600RR.
I'd avoid anything from the last four years because anything with a catalytic converter will be awful.
Buy an older clean one and rebuild it as soon as you get it. RS125's have nikasil plated barrels which are hard wearing, but if damaged need replating after a rebore.
Owning a two stroke is not hard, but you basically need to be over 25 to be anal enough to get on with it, which is why you see so many blown up RS125's etc.
The reliability of the NSR is a testament to Honda build quality rather than the RS being particularly unreliable.
Good luck! Smile
PostPosted: 14:50 - 01 Nov 2009    Post subject: Re: Owning a 125 2 stroke... Reply with quote
Screw relying on the light, that's a disaster waiting to happen. Fill the oil tank up every 200 miles and you can't go wrong.
Rebuild costs would be under £100 if you are doing it yourself and just fitting a new piston, rings, small end bearing and gudgeon pin. You're probably looking at around £60 for the parts.
Fahd
PostPosted: 15:06 - 01 Nov 2009    Post subject: Reply with quote
Just to add my 2-pence, I've owned an Aprilia RS50 and Aprilia RS125 (the latter for 2 years) and never had to rebuild either of them once, they'd both also always start on the button very quickly.
I think a lot of people underestimate how much damage riding these things without warming up does to them. I found warming up for 5 minutes before riding gently for at least a mile before thrashing it kept it pretty well looked after.
Having said that you might want to test-ride before buying anything, I find the Honda CBR 400RR far more entertaining and I don't have the worry of my engine blowing at the back of my mind every time I ride it with some enthusiasm. So I doubt I'd ever go back to one, it's great when you're 17, not so great when you can ride whatever you want. Here's my old little beast (the yellow and grey one) with my cousins, back when we were 17:
https://www.bikechatforums.com/files/dsc01772.jpg
I Ride: Honda CBR 400RR.
I Drive: Audi S3.
PostPosted: 15:30 - 01 Nov 2009    Post subject: Reply with quote
But.
5 mins idling is enough to foul the plugs. You're best off just riding it and keeping the revs low for a little while. No max throttle and nothing above half revs.
If you're going to warm it up at a standstill you're best off just revving it a bit every so often. I tend to never let mine sit at idle and I just lift the revs up to 1/4 - 1/2 as you used to hear in MotoGP pit garages. Brrrom! Brrrom! Brrrom!
Annoys my neighbors! Laughing
PostPosted: 15:44 - 01 Nov 2009    Post subject: Reply with quote
Mine sits at idle with the choke on while I shut the garage door and put my helmet and gloves on.
Knock the choke off, give it a few revs going up to 4,000rpm and letting it drop to 2,500rpm, probably do that for about 20 seconds.
Get on, ride under 5,000rpm, wait until the temp gauge drops due to the thermostat opening, then once it moves back up to temperature I know it's safe to ride like a hooligan.
Philious
PostPosted: 17:22 - 02 Nov 2009    Post subject: Reply with quote
I bought an RS 125 in June this year and parted with her a month ago for my GS500e, I think they are under rated and mainly slated for the unreliability due to the 17yr old riders not warming the engine thoroughly.
Very quick little bikes, they just want you to over take at every opportunity and great handling too, a couple of times i found my knees scarily close to the tarmac whilst riding out wearing jeans....
Mileage I found did depend on how often I pinned the throttle fully open.
As for the 2t oil as stated don't rely on the light, just pop your key under the seat and use your eyes to see how much you've got, you have to do it with the tank anyway so one more thing to check won't hurt.
https://img.photobucket.com/albums/v330/flippy2k4/DSCF2137.jpg
Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09
Andy C
Tree Seeking Missile
PostPosted: 21:15 - 02 Nov 2009    Post subject: Reply with quote
I loved and hated mine. Was always careful to let it stand to warm and use the best oil but still ended up having to pay for a top end (wasnt machanically minded enough back then to do it myself) which worked out expensive.
Great handling but after the top end went I found myself quite paranoid about it happening again and although it was great to ride wasnt practical at all (though im sure you would be using it for summer days).
Think I actually perfer my RXS as is a 2 stroke but seems to have more character (though slower, worse brakes/suspension/frame/wheels/everything). Thumbs Up
Philious
PostPosted: 21:25 - 02 Nov 2009    Post subject: Reply with quote
I miss the old RD 125 Lc, a mate of mine had one a few years ago and that was a sweet bike. They just don't make them like they used to. Crying or Very sad
PostPosted: 22:33 - 02 Nov 2009    Post subject: Re: Owning a 125 2 stroke... Reply with quote
Aprilia say to check the ring at 8000km. It is about as much effort to check them properly as it is to just change them. I tend to change them at 6000km. It is a gentle afternoons work. Rings are not a massive amount and the only gaskets you need to disturb are the base gasket and power valve gasket (should be under £5 for the pair). Head gaskets are a couple of rubber O rings and can be reused a few times if you check them.
The drive gears for the balance shaft are also meant to be replaced.
They eat brake pads. Rear shock work OK but are not the most long lived things.
Like a secondary tank. The RS isn't bad on 2 squeak oil. Some 2 squeaks use more than others (the TZR125 we had many years ago used at least twice as much as the RS). RS owners handbook says something like 1%~2% 2 stroke oil, so that is probably a litre every 4 tanks or so.
About 55mpg in general use, less if thrashed. Managed 74.5mpg during the fuel strikes (it was agony)
Lots of differences but maintenance is much the same. Older ones need the timing setting properly and the older flywheels are more delicate.
Although the engines are similar, loads of bits cannot be interchanged. Barrels are different, gearchange is different.
https://www.alfa-pages.co.uk/TempPicture/img_7714.jpg
Personally I like them. Reliability is acceptable, performance acceptable, handling is good and the brakes are good.
PostPosted: 23:05 - 02 Nov 2009    Post subject: Re: Owning a 125 2 stroke... Reply with quote
I've been a bit disappointed by the suspension generally on RS125s, (my rs250s were a bit lacking at the front too, though apparently the later model was better). NSR was fine when I had it, but I suspect wouldn't feel so great now.
If it was for 'keeps' I'd definitely consider budgeting for some aftermarket bits.
Saying that, I still found the RS250 perfectly adequate for road work, where it being a bit soggy at the front didn't limit my riding.
Never been that impressed by the brakes either - ok and do the job, but lacking the 'sparkle' of something like the yamaha blue-spots.
PostPosted: 23:13 - 02 Nov 2009    Post subject: Re: Owning a 125 2 stroke... Reply with quote
The stock pads on the 125 are not great. Brakes work well but feel a bit dead. Changing them to (for example) EBC HH pads makes a massive difference. Possible Aprilia toned down the brakes with less grabby pads to make them a bit more novice friendly.
PostPosted: 23:23 - 02 Nov 2009    Post subject: Re: Owning a 125 2 stroke... Reply with quote
The RS125 brake seem to be a budget version of those on the RS250 (may just be the same painted a different colour)... and I haven't been that impressed by the gold ones on the various bikes I've ridden with them on either.
'Ok', but nothing amazing considering the brembo logo, etc.
PostPosted: 23:28 - 02 Nov 2009    Post subject: Reply with quote
The 125 calipers are nothing like the 250. The 125 uses Grimeca calipers (marked as Aprilia).
serlant
PostPosted: 23:34 - 02 Nov 2009    Post subject: Reply with quote
my 125 (kawasaki KH125 k7) takes about 13 litres without going into reserve and does probably 180 miles to a tank, with about 4 tanks to 1 litre of 2 stroke, and i think its stil on the origional top end with 16k miles on it, no other maintenance than adjusting the chain and changing the oil once in the 3k miles i put on it.
PostPosted: 23:39 - 02 Nov 2009    Post subject: Reply with quote
Oh well, looked similar to me at a cursory glanced and presumed their damp performance was related.
https://www.maxmoto.co.uk/images/Aprilia%20RS125%20MotoGP.jpg
https://www.motorcyclespecs.co.za/Gallery/Aprilia%20RS250%2000.jpg
I wonder how the latest one with a radial calliper matches up?
PostPosted: 23:45 - 02 Nov 2009    Post subject: Reply with quote
Not sure, although to be honest not sure that there is any direct benefit from a radial caliper. Suspect any benefit is down to the details such as how stiff any particular caliper is and the ratio of piston bore to lever movement.
prawny1
PostPosted: 23:50 - 02 Nov 2009    Post subject: Reply with quote
Best advice would be use the best quality auto mix two stroke you can afford change the rings regularly as a service item rather than wating untill they break up, and let your engine warm up before riding it hard or at all.
oh and engine breaking is not your friend on a two stroke due to high load and low lube / mix going into your engine.
PostPosted: 23:51 - 02 Nov 2009    Post subject: Reply with quote
Yea, can't see the 'radial' bit being the over-riding factor, but so far all the bikes I've ridden that have bothered with radial callipers have had good brakes. Presumably if they're going to the money/effort of doing them, they're going to do them half-decently.
I'm sure it won't be too long before they're on cheap Chinese bikes with appropriate performance, however Rolling Eyes.
Mord
PostPosted: 00:13 - 03 Nov 2009    Post subject: Re: Owning a 125 2 stroke... Reply with quote
They are.. and pretty much you can do everything by yourself. Piston and rings need to be changed every 5-8k miles or so (compression tester is your friend, so is Haynes manual). Always warm it up properly before you trash it (usually after 5-10 minutes of sensible riding when temp gauge stops going up and down).
Don't buy cheap piston, go for genuine Aprilia one or Wiseco. Cost around 100 quid for Wiseco rebuild kit. Run-in for first 200 miles or so.
You need 1 litre of 2T oil per 40-50 litres of petrol you use. Just top-up every 2-3 times you fill your petrol tank and you will be ok. Don't rely on 2T oil level sensor, better visually check oil level.
I get 45mpg from full power 2008 RS125.
Power wise they both can be the same.. Older models are cheaper to derestrict.. newer models apart from powervalve+solenoid fitting need also exhaust changed or decated to make them produce as much power as older models i.e. exhaust in 2003+ models is with cat, in Euro3 models the cat is even more restrictive (easy to solve.. just get decated exhaust i.e. Arrow like I did).. Pre 1998 models used to have bigger 34mm carb = worse mpg, more power. 34mm carbs available for 1998-2009 bikes so no problem Thumbs Up
Photo..
https://i244.photobucket.com/albums/gg19/Mordoklej/RS125_640V1.jpg
Videos..
https://www.youtube.com/watch?v=a0N72n5F-ys
https://www.youtube.com/watch?v=DZFOXzEmT8s
craigs23
Mr Muscle
PostPosted: 06:50 - 03 Nov 2009    Post subject: Reply with quote
Thanks for all of the responses Thumbs Up I'm a bit closer to making my mind up about whether to truly get one or not. As mentioned, I've never had a stroker before and can definitely see the appeal - even the regular tinkering away in the garage is a bit of a plus point for me.
I'll have a nose around the local papers to see if I can get something at a reasonable price - I think if I can get an Extrema-like model with some change left over for some parts would be ideal.
Thanks again. Karma
PostPosted: 12:00 - 03 Nov 2009    Post subject: Reply with quote
Not too much of an issue if you are running an oil pump.
27cows
PostPosted: 12:25 - 03 Nov 2009    Post subject: Reply with quote
Sporty 125s are entirely pointless and ridiculously expensive in relation to the ludicrous fragility of the engines (and most other components) and poor performance compared to a bigger bike.
Why would anyone in their right mind buy a bike that is going to require constant attention?
PostPosted: 12:34 - 03 Nov 2009    Post subject: Reply with quote
Personally, because they are fun, and you can thrash them pretty hard without going at silly speeds. Because they are in a fairly high state of tune and you need to get it right to get the best from it. Unlike anything much larger (including 250 2 strokes) where you can be far lazier and still make good progress. Same can apply to even smaller 2 stroke (I have an unrestricted 50cc gag bike as well), just that they land up being too slow for any great distance on major roads, while a 125 can happily keep up with the general flow of traffic on the motorway.
Sure a 400 4 stroke will be far quicker, but to me nowhere near as much fun.
Fast does always mean fun. Fast normally means you cannot use the performance so are just sitting round at boring revs.
The last post was made 16 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.59 - MySQL Queries: 16 - Page Size: 156.74 Kb
