| squishio |
 squishio Spanner Monkey
 Posted: 19:35 - 02 Nov 2009 Post subject: Just a thought... - Engine Valves |
Why are they always round?
Randomly popped into my head that you could probably get more surface area covered therefore a bigger port covered if the valves were square or maybe semi-circular.
https://www.srcf.ucam.org/~mmp26/images/rebuild/head-valves.jpg
somthing like this...
https://www.rdphoto.co.uk/mg2/pictures/valves.jpg
is it because the air flows better past round shapes as opposed to square pointy things? ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250 |
| NSR Mick |
 NSR Mick World Chat Champion
| Paulington |
 Paulington World Chat Champion
| 27cows |
 27cows World Chat Champion
 Posted: 19:49 - 02 Nov 2009 Post subject: |
Honda gave oval pistons a whirl...maybe they should try oval valves too  |
| The Artist |
 The Artist Super Spammer
 Posted: 20:19 - 02 Nov 2009 Post subject: |
Same reason pistons are not square.
Too much pressure at the corners which is why circles are perfect as they spread the pressure all the way around.
If you want more air/fuel in your engine then that is what a turbocharger is for  |
| iooi |
 iooi Super Spammer
 Posted: 21:03 - 02 Nov 2009 Post subject: |
There is also the heat matter.
Round the heat is evenly spread.
Make it like your drawing and you will find that the corners get a lot hotter and will burn more. Leading to a very poor seal after a while.
Also the head does need to be able to disipate heat, in your example there is very little left to do that.
Never mind that there is the matter of you have blocked out the spark pulg hole  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| prawny1 |
 prawny1 World Chat Champion
 Posted: 21:10 - 02 Nov 2009 Post subject: |
not to forget that valves can spin under normal use
are we looking at a 1.0l corsa head? |
| ZRX61 |
 ZRX61 Victor Meldrew
| squishio |
 Posted: 22:12 - 02 Nov 2009 Post subject: |
| prawny1 wrote: | not to forget that valves can spin under normal use
I thought about the spinning but just thought you could use a square/triangular stem to keep it fixed in one position.
no idea what the dead is, just googled valve head
As for the heat dissipation issue, if you had valves big enough (in comparison to the cylinder size) then there would be much more/easier exhaust so less heat staying in the engine ???
blocked spark plug...
yeah...
oh well, make do without or stick it in the side of the cylinder  ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
| squishio |
 Posted: 22:17 - 02 Nov 2009 Post subject: |
just posed this question to my dad and his reasoning was as Geri said wast machining.
Valves used to be turned on a lathe. Are they still?
I would be quite surprised if they still are as the waste material and machining involved would be pretty high in relation to the quantities of engines (cars, bikes mowers etc) being produced. ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
| Ariel Badger |
 Ariel Badger Super Spammer
| prawny1 |
| ms51ves3 |
 ms51ves3 Super Spammer
| G |
 G The Voice of Reason
| prawny1 |
 Posted: 23:20 - 02 Nov 2009 Post subject: |
double post oops
| prawny1 |
| prawny1 |
 Posted: 23:29 - 02 Nov 2009 Post subject: |
rotary valves are for crank case induction, what I was thinking of is for four stroke application with the induction and exhaust flowing into the head as in a conventional four stroke, sealing the valves would be the major problem with it in practice, and would be further complicated in a multi cylinder engine. |
| chris-red |
| prawny1 |
| G |
| chris-red |
| ms51ves3 |
| Ariel Badger |
The last post was made 16 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
