Government Rider Attitude Poll 2009
You are riding your motorbicycle in lane 2 of a stretch of NSL dual carriageway. Traffic is moderate. The sun is shining, your genitals are comfortable in your leathers, the bike feels good. You see the following sign (attached) Do you:
Check your mirrors, then move into lane 1 at the earliest safe opportunity in anticipation of the lanes merging ?
16%
 16%  [ 12 ]
Immedately pin it and fucking hoon down the outside lane and see how many cars you can overtake before the lanes merge and you are forced back into lane 1 ?
83%
 83%  [ 62 ]
Total Votes : 74
s44678
Guest
PostPosted: 17:27 - 03 Nov 2009    Post subject: Government Rider Attitude Poll 2009 Reply with quote
https://www.bikechatforums.com/files/sign_116.jpg
Would be interested to know the outcome.
PostPosted: 17:29 - 03 Nov 2009    Post subject: Reply with quote
Option 2, with the additional "using as much of the herringbone runoff area as I can" too.
PostPosted: 17:31 - 03 Nov 2009    Post subject: Reply with quote
Depends what sort of mood I'm in, but usually it would be option 2. Thumbs Up
PostPosted: 17:43 - 03 Nov 2009    Post subject: Reply with quote
If i'm not kicking up dust it means i've given in.
Pic not working
Pat
LankyPaddy
PostPosted: 17:45 - 03 Nov 2009    Post subject: Reply with quote
I'd argue that option 2 was the correct answer. As the sign means "merge in turn in 600 yards", not necessarily "merge now"
Say, do you have any Gatorade? I'm afraid I left all my electrolytes with your daughter.
Current bike: SV650S K8
Muscle Bike Rider
PostPosted: 18:04 - 03 Nov 2009    Post subject: Reply with quote
Cant see the sign?
Previously Known As A5tra_G
Old Bikes :2010 Kawasaki ER6 F & 2000 Honda VTR Firestorm
Current Bike : XJR1300
The Original Muzza
PostPosted: 18:21 - 03 Nov 2009    Post subject: Reply with quote
300 yards is when you start considering merging, 100 is the earliest you bother. That's 500 less yards to be frustrated with.
willis1337
PostPosted: 18:24 - 03 Nov 2009    Post subject: Reply with quote
Be continental and use ALL of the available road space (it's not illegal) - if you like to queue sell your bike and get the bus ffs.
PostPosted: 19:14 - 03 Nov 2009    Post subject: Re: Government Rider Attitude Poll 2009 Reply with quote
What's stopping you continuing to filter past the thraffic in the cones, just as you would have been filtering before the sign?
Or, nipping through the cones if you're feeling particularly cheeky and there's no people working behind them?
Faldo
PostPosted: 19:19 - 03 Nov 2009    Post subject: Reply with quote
Can't see the pic either, but I presume it's directing us to move over as the outside lane is about to end, in which case I'd most likely maintain the same speed until the last safe opportunity to move over.
I can't be doing with drivers that don't use all of the road, that's what it's there for Evil or Very Mad . Even worse is people that try and cut you off as if you are 'pushing in'. If you have to merge it isn't pushing in, it's merging.
Current: ZZR1400
craigs23
Mr Muscle
PostPosted: 20:16 - 03 Nov 2009    Post subject: Reply with quote
Not enough information for the hypothetical situation - there may be a convenient gap in a traffic halfway between my position and the lane closure, or the lane might be wide enough to carry on filtering once it's narrowed to one lane...and it also depends on what mood I'm in and what bike I'm riding.
Pin my 125 for example? I'd probably already be doing that if I was caught a). on a bypass b). in the fast lane.
calyx
PostPosted: 20:41 - 03 Nov 2009    Post subject: Reply with quote
That sign is no different than a traffic lights sign. I just filter(which is not filtering tbh) and zip in safely as always.
Boris - London
PostPosted: 21:08 - 03 Nov 2009    Post subject: Reply with quote
Except where you drive past all the other people 'merging' and go right to the choke point, expecting to get in. Then it's pushing in and I'll happily 'block' you Smile.
PostPosted: 21:13 - 03 Nov 2009    Post subject: Reply with quote
Doesn't matter what you do.
The second the lanes merge, even if the road on the approach has been totally devoid of traffic for the last five miles, you will come up behind a double artic with a full load of car batteries/sand/concrete blocks which is tailgating a bus, which is being held up by some old bloke in a flat cap driving a powder blue nissan micra at 40mph. There will be solid lined chevrons for the next six miles.
The worst one is if you can SEE the wagon up ahead. There is a bit on the A66 (Penrith to Scotch Corner) like this, about 10 miles before Scotch Corner. You come over the crest of a hill to see the last mile of dual carriageway then five miles of double-white-lined, empty single carriageway wending its way across the countryside. There is ALWAYS a huge artic about 300yds off the point where the lanes merge. If you don't get there first, you're going to be stuck behind it until the next bit if dual carriageway.
I have seen some very silly numbers indeed on the VFR speedo as I squeeze between the wagon and central barrier on the last little wedge of chevrons before the double whites start.
map
Mr Calendar
PostPosted: 21:50 - 03 Nov 2009    Post subject: Reply with quote
stinkwheel wrote:
...you will come up behind a double artic with a full load of car batteries/sand/concrete blocks which is tailgating a bus, which is... There is a bit on the A66 (Penrith to Scotch Corner) like this, about 10 miles before Scotch Corner. ...
Not sure when you last did that run but the A66 is a lot better. The dual bit is actually from/to Scotch corner with more dual bits in between. Still single sections though, the bit I find frustrating is past the tank training grounds.
Having said that you can have a very good run on that road Wink Very Happy
PostPosted: 01:23 - 04 Nov 2009    Post subject: Reply with quote
You should try it at midnight in midsummer Very Happy. I do it every other weekend or thereabouts.
The bit I'm on about is where there is a short stretch of dualled road that goes up a fairly steep hill, heading East from Warcop. Then it drops down again (pretty much the end of the "hills"), goes to single carriageway at the bottom of the hill and there is a longish bit of single carriageway that goes past the Fox Hall pub. Always seem to land up racing a wagon to the end of the dual carriageway.
divuk83
PostPosted: 06:59 - 04 Nov 2009    Post subject: Reply with quote
Depends how many HGVs/Caravans/Austin Metros being driven by old men wearing flat caps are ahead of me.
The A66 is a very good example of a road where this happens a lot.
Dave
The last post was made 16 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.42 - MySQL Queries: 15 - Page Size: 102.07 Kb
