| scrimshady |
 scrimshady Derestricted Danger
 Posted: 14:13 - 04 Nov 2009 Post subject: |
It is very crude. You set the points gap and hope the timing is somewhere close.
If it's been that highly tuned, you might want to slot the mounting holes for the stator plate so you can advance it a bit.
This may however cause problems for the mechanical ignition advancer.
EDIT: There seems little point in setting the timing to the factory setting if you're running a high compression top-end and methanol because it'll all have gone batshit anyway.
Keep advancing it slightly until it either wont start, looses power or starts pinking, then back it off a bit.
At a total guesstimate, I'd start around 4mmBTDC and work from there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| scrimshady |
| Blue_SV650S |
 Posted: 12:13 - 05 Nov 2009 Post subject: |
I have a haynes and the points gap is stated as 0.3-0.4mm.
Set the points gap to that and then align the index mark on the points backplate to the index mark on the engine (they are fairly obvious markers).
That obviously only sets it back to factory standard. The better way to do it is to take the rotor plate off (honda cover down below) and reveal the flywheel. On it there will be some markings and an index on the casing. the points need to be just opening as the 'F' mark passes the index. I'd then mark the backplate to have a baseline to work from.
If you are using high octane fuel, you can advance the timing from there - the actual value will need experiment or further research, but I'd try 5deg to start with (that is 10deg at the points)).
But that is for you to fiddle with ... at least you now know how to set back to standard  ____________________ The purpose of life is to fight maturity. |
| scrimshady |
| Hoffy |
 Hoffy Trackday Trickster
 Posted: 15:44 - 05 Nov 2009 Post subject: |
Halfrauds ? or contact pyro4lyfe , he had my old CB125s and also the manual. I know he sold the bike, he might still have the manual though  ____________________ Plagued by 1980s Suzuki 2 strokes ! |
| Hoffy |
 Posted: 15:45 - 05 Nov 2009 Post subject: |
| Blue_SV650S |
 Posted: 16:39 - 05 Nov 2009 Post subject: |
| scrimshady |
| Blue_SV650S |
| scrimshady |
 Posted: 11:54 - 08 Nov 2009 Post subject: |
i have a various dial guages for finding TDC, i use it for deisels engine for my company. i dont have any flywheel in the side casing of the engine so i cant align the F mark.
you said about the marks on the points backing plate????? i can see the mark on the plate but not on the casing.... do you have a picture of what i am looking for????
i am with you on setting it back to stock first but like i said i dont have the marks to do that.
| Blue_SV650S |
| scrimshady |
| Blue_SV650S |
| scrimshady |
| Blue_SV650S |
| scrimshady |
| Blue_SV650S |
| scrimshady |
| Blue_SV650S |
The last post was made 16 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
