XJ600 Diversion Restrictors - Fitting
Herbalrick
PostPosted: 19:40 - 04 Nov 2009    Post subject: XJ600 Diversion Restrictors - Fitting Reply with quote
Has anyone fitted one of these and how hard are they to do yourself?
Also if anyone has a kit they are no longer using I'm willing to buy it off you.
Cheers,
Rich
iooi
PostPosted: 20:12 - 04 Nov 2009    Post subject: Reply with quote
Should not be too hard. Although getting the carbs to sit right on the air box fittings can be a real pain.
Herbalrick
PostPosted: 12:21 - 05 Nov 2009    Post subject: Reply with quote
Thanks, when you say getting the carbs to sit right do you mean balancing them? Or is there some rearranging to the way the bike is physically arranged.
Thom
PostPosted: 20:16 - 05 Nov 2009    Post subject: Reply with quote
herbal, you dont even need to remove the airbox, i assume these are the metal washers?
Smply get an allen key in, undo the engine intake manifolds (i expect theyre made of aluminium as my '97 was) and slide the metal washers in place, thread the bolts back up and tighten.
Two words of warning/advice.
You'll have to pry the inlet manifold backwards doing it this way to make space.
Put some liquid gasket or sealant on both faces of the washers as i had air leaks without the stuff.
thom
Herbalrick
PostPosted: 09:30 - 06 Nov 2009    Post subject: Reply with quote
Metalforever, where did you get your restrictors from?
The installation sounds pretty easy, but I'm having a hard time sourcing them from anywhere but FI International (rip off merchants)
Herbalrick
PostPosted: 16:30 - 06 Nov 2009    Post subject: Reply with quote
Me again. I found a motorbike breakers on Ebay who have a restrictor kit for £12. However they can’t tell me what year of bike the kit came from, only that it was a 91-99 diversion.
As far as I can find out there have not been any major changes to the mechanics of the diversion between 91-99, however I’m not particularly knowledgeable about the Divvy.
Does the restrictor work the same way in all the bikes in the 91-99 diversion? So if the kit came from a 95 Diversion will it work in a 98 Diversion?
PostPosted: 16:44 - 06 Nov 2009    Post subject: Reply with quote
MCN wrote:
1992: Yamaha XJ600 Diversion launched.
1993: Yamaha XJ600 Diversion gets new fairing with air scoops, screen now has grey trim.
1994: New Diversion logo on fairing.
1996: Yamaha XJ600 Diversion gets oil cooler. New carburettor. New fairing with indicators mounted on the sides. New headlamp. Choke now mounted on left handlebar. Redesigned bar end weights. Reshaped side panels.
1997: New fork leg protectors. Now with hazard warning light switch. New seat.
1998: Revised centre stand. New 41mm (from 38mm) front forks.
2004: Yamaha XJ600 Diversion discontinued.
There was a carb change for the '96 Divvy - depending on where the restrictors are fitted, they may not work, but it's likely they are just a washer that fit in the inlet, which may not have been altered.
Thom
PostPosted: 12:20 - 07 Nov 2009    Post subject: Reply with quote
my restirctors were from ebay from a 92 model if i remember rightly and i fitted them to my 97 no problem.
Herbalrick
PostPosted: 23:05 - 07 Nov 2009    Post subject: Reply with quote
cheers mate, I'll put the order in
The last post was made 16 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 60.66 Kb
