cg125 feels like its bottoming out
cookie151175
PostPosted: 17:51 - 05 Nov 2009    Post subject: cg125 feels like its bottoming out Reply with quote
Hi i have a 2002 cg 125, up until recently it has run really well, but for some reason I have to thrash the nuts of it in 4th gear to get over 50mph...............(even on non windy days on a flat road). What could be causing this? The minute i get into 5th its like it just gives up all hope! Love my bike but its becomming annoying now.....!
Help please
Cookie
MattHirst
PostPosted: 19:20 - 05 Nov 2009    Post subject: Reply with quote
To many cookies!
Have you checked the chain + sprockets? You'd be amazed at how much power a badly adjusted/fucked chain can rob.
Check things like oil levels etc.
Although if it came on all of a sudden, your best option would be to whip the carb off and give the jet a blow out (not sure about the CG carb but you shouldn't need to strip it, just take the float bowl off which will reveal the jet)
If you have got a bit of shit in the jet (easily done if it doesn't have a fuel filter) then it will reduce the overall power by quite a margin.
Noxious89123
PostPosted: 19:29 - 05 Nov 2009    Post subject: Reply with quote
"Bottoming out" is when your suspension uses up all of it's travel Eh?
Regarding the loss of speed, have you checked your tyres? You can lose a fair bit of power, engery and speed if your riding on squidgy flat tyres.
cookie151175
PostPosted: 10:19 - 06 Nov 2009    Post subject: Reply with quote
hi Guys.... will try a couple of things today. Tyre pressure feel ok... It feels like what ever it is, it is mechanical wrong........ coz the engine sounds as if it is drowning if that makes sense.....
Cookie
cookie151175
PostPosted: 14:59 - 06 Nov 2009    Post subject: Reply with quote
hey!!!!!!!! it looks like i may of solved the problem...... just gonna try it out now. Had to refit a centre stand on it today, and whilst removing chain guard it was pretty visible......... the chain had more slack than a prostitutes knickers....lol. Heres hoping she runs well now. Thanks for the advice..... Very Happy
cookie151175
PostPosted: 19:00 - 08 Nov 2009    Post subject: Reply with quote
damn! it didnt solve it! would a simple thing like a spark plug cause it to loose power in 5th??? Or is that me been thick? Starting to frustrate me now................ Sad
Noxious89123
PostPosted: 20:11 - 08 Nov 2009    Post subject: Reply with quote
Well, things that you can check;
Air filter, is it clean or encrusted with filth?
Fresh fuel in the tank? If you've run it on reserve recently, it could have pulled crap out the bottom of the tank into the carb?
Otherwise, I dunno Laughing
rob_scott92
PostPosted: 23:36 - 08 Nov 2009    Post subject: Reply with quote
take the plug out ind brush it with a wire brush, if it hasnt been cleaned for a while i suppose that could cause it do stop climbing in 5th Wink (Remember to blow away the excess dust before you put the plug back in! you dont want that shit in your engine!)
How fast does it go if you're, say, going flat on a straight road with little wind? the Gs is a tempromental bugger. some days all it'll do is 50, yet then the next day it may do 60-65 fairly easily in similar conditions Confused
other than that, just try what everyone else said Rolling Eyes
Hope this helps
Rob Thumbs Up
Edit: tell us what colour the plug is when you get it out Thumbs Up
cookie151175
PostPosted: 04:51 - 09 Nov 2009    Post subject: Reply with quote
gonna take the plug out today after work!!!! no matter whether theres a head wind or not the only time it will do 60 is if i thrashing it in 4th, the minute i hit 5th it just loses momentum,
its goto be something simple surely!!!!!!! Confused
The last post was made 16 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 60.12 Kb
