Gilera Runner 125 wont start
darthcrab
PostPosted: 16:19 - 05 Nov 2009    Post subject: Gilera Runner 125 wont start Reply with quote
hi guys,
a couple of days ago it was running fine, apart from a water leak. my friend asked me if I could fix it and I did, was just a new O-ring needed, really simple job.
it started back up and he took it away. about 2 miles up the road, it cut out and wouldnt start up again, and when he said what it sounded like, I straight away said fuel. so I went with a can and filled it up, tried and tried off the kick start, nothing. it wouldnt even try,
it has a spark, and I got a new plug yesterday. it has fuel, and oil. fuel is getting to the carb, and the fuel is good (I set fire to it)
I even tried with easy sart while turning it over.. NOTHING
all it does, is build up and backfire after a few attempts on the kickstart.
any ideas please guys, im stressed
cheekythomas
PostPosted: 10:22 - 06 Nov 2009    Post subject: Reply with quote
Sounds like it partly siezed, and now doesnt have enough compression to run.
Pussy Magnet
PostPosted: 13:22 - 06 Nov 2009    Post subject: Reply with quote
i agreee with the comment above
what i always do is start at the start see if its getting fuel and work my way down the cycle myt be flooded becuase you kept trying to start it.
steo
PostPosted: 20:29 - 06 Nov 2009    Post subject: Reply with quote
You said it was getting fuel, oil & a spark but backfiring? If it's a compression problem then you could do a compression test as suggested by the other posters. Incase it had partially seized, did you notice a grating noise in the engine note when you were turning it over?
The Gilera has a two stoke pump belt which can easily snap, did you take this off or forget to put back on when you working on the water pump?
darthcrab
PostPosted: 16:19 - 07 Nov 2009    Post subject: Reply with quote
there was no grinding noise, and I didnt take the water pump off, it had a leak due to a o-ring on the cover where spark plug is.
so minimal stuff was taken off.
the slightly seized idea does seem to be more and more possible.
it is getting fuel, and enough of it too, I have taken the carb off many times and it fills the boat up great.
what should the compression be out of interest so I know what im trying to get.
thanks again
steo
PostPosted: 01:45 - 08 Nov 2009    Post subject: Reply with quote
I wouldn't know off hand what the compression pressure for the Gilera is, the spec will be in the workshop manual but anything under 100psi would suggest you will need to pull the head & barrel off.
Here's a link which might help you out. https://www.bikechatforums.com/viewtopic.php?t=155044&highlight=compression+pressure[/img][/url]
The last post was made 16 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 46.58 Kb
