running rich
hondagee
PostPosted: 08:00 - 07 Nov 2009    Post subject: running rich Reply with quote
Hi, Very Happy This is my first post and I could use some advice please. My CB250 is running rich and the plugs get really sooty but it starts and runs ok. Is there a way I can weaken the mixture? Cheers. Confused
garyd
PostPosted: 08:19 - 07 Nov 2009    Post subject: Reply with quote
Check the air filter is clean ,then you can alter the air/fuel mixture on carb,small screw ,sorry not familiar with your carb Thumbs Up
CRF230 all you need
PostPosted: 10:21 - 07 Nov 2009    Post subject: Reply with quote
A worn needle jet and jet needle can cause an over rich mixture, and is something that should be checked if the bike has covered a high mileage.
You may wish to take the option of setting the float height to the maximum figure which will give you a weaker mixture.
For instance if the manual advises 14-16mm then set the height at 16, don't forget to check that float halves are both square and level.
Ariel Badger
PostPosted: 10:29 - 07 Nov 2009    Post subject: Reply with quote
Is the choke full disengaging? A dry and rusty cable or linkage could cause problems.
hondagee
PostPosted: 08:04 - 09 Nov 2009    Post subject: Reply with quote
Thanks everyone, I will try all these options. Keep safe. Geoff. Very Happy
Blue_SV650S
PostPosted: 12:39 - 09 Nov 2009    Post subject: Reply with quote
hondagee, don't fiddle with this, it is the low running mixture and won't solve your problem, if it is idling ok at the moment, all you will end up doing is make it refuse to idle properly!! Wink
As others have said, check the filter as the first port of call, then move onto the main jet and needle jet as they are probably worn.
The last post was made 16 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 46.81 Kb
