| thegift |
 thegift L Plate Warrior
 Posted: 22:04 - 06 Nov 2009 Post subject: transporting a motorbike? |
Going to do my DAS after the new year, but was planning on getting a bike now to store in the garden ready for after ive passed my test!
Question is im thinking about hiring a transit van, find the bike I like (gixer 600) and picking it up. How would this be done? Can it even be done?? What would I need apart from another pair of hands?
Ta!  |
| Mystery |
 Mystery World Chat Champion
 Posted: 22:36 - 06 Nov 2009 Post subject: |
you will need ropes and stuff to keep the bike in place while moving it  ____________________ Carbon knuckles assure you maximum protect against debris and unfortunate accidents or if someone cuts you off, their side mirror.Mopeds are like chubby chicks.. they are really fun to ride until you're friends catch you on one |
| cammy mack |
 cammy mack Could Be A Chat Bot
 Posted: 22:39 - 06 Nov 2009 Post subject: |
you'll nee at least 2 tie down straps 1 on each side of the bike tensioned up so it wont spill over. maybe a ramp as well  |
| ms51ves3 |
 ms51ves3 Super Spammer
| G |
 G The Voice of Reason
| thegift |
| ms51ves3 |
| 69.9mph |
 69.9mph Crazy Courier
| SamJL |
 SamJL Nearly there...
 Posted: 00:01 - 07 Nov 2009 Post subject: |
I always tie mine down with 4 rachet straps.
I have 2 holding the rear pegs down and 2 holding the handle bars down, never had a bike fall over on my yet. You can pick up cheap rachet straps from pound shops, mine are Fro Systems ones, and there about £15 each, you can get them for about £5 for 4 if you want cheap ones, they work pretty well, make sure you don't do them so tight that they end up braking the rachet mechanism!
If your going to be transporting it quite a bit, you might want to invest in a ramp, there not that cheap, but make loading the bike so much easier then planks of wood. If its just a one off, save some money and just get some wood, make sure its strong, you don't want it breaking when your pushing your bike up it! |
| stirlinggaz |
| 27cows |
 27cows World Chat Champion
| dodgydog |
 dodgydog World Chat Champion
 Posted: 08:33 - 07 Nov 2009 Post subject: |
A ramp.
At least four ratchet straps.
Position the bike at the front of the van and cable tie the brake lever on, (bike in gear too).
Strap the bike from the rear footpegs, you should have a strap going from the left, over the seat, to a point high up in the van on the right. Another from the right, over the seat, to somewhere high on the left.
I always used either kitchen roll or a blanket so the straps don't rub on anything. (keep the ratchet mechanisms WELL out of the way too)
I use the other straps at the front, attached to the clip ons (or bars) you need to be very careful there, so as not to put any strain on the plastics. Again, I always crossed the straps over, right to left and vice versa. Try to strap it so the bike can not move backwards when you accellerate.
I sold a bike last year, the guy came to pick it up in a hired van, all he brought with him was an Oxford security chain . He was seriously just going to stand the bike up in his van and put the chain through the wheels?? Luckily I had some rope so we managed to get it secured eventually, but I told him to stop frequently to check it all.
we got four bikes into an Iveco van for the Isle of Man, looked like a spiders web inside but nothing moved  ____________________ I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant |
 Posted: 11:41 - 07 Nov 2009 Post subject: |
Yep, ratchet straps. Even the cheapo car boot sale tool stall ones work fine.
I usually put two on either the handlebars or the fork stanchions between the yokes and two on the grab rail/rear footpeg hangers.
I usually put a chock of wood in front of the front wheel to stop it rolling forwards as I ratchet it down.
If you're pushing it up the ramp, leave it in gear and pull the clutch in. Then if you need to stop, you can let go of the clutch and the bike will stay put.
If you're brave enough to try riding it up the ramp, mind your head and if you don't get it all the way in, DO NOT give it more throttle, roll back down and try again. If the front wheel is in and the back is still on the ramp, gassing it will cause the ramp to shoot out backwards and down you will go.
Storing a bike outside and not using it all winter is going to leave it in a shit state come spring. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 15:22 - 07 Nov 2009 Post subject: |
+1 for rachet straps.
Put in in gear and tie the front brake on.
From then it depends on what the van you're using has.
If it's just a rental then you'll need about 4 straps from the bike to the floor(most vans have 4 tie down points on the floor as standard). One from each pillion footrest and one from each bar.
If it's got tie points on one wall, then you just need one strap from the footrest, over the tank and to the wall.
A plank of wood is ok, but super bendy, so if you know someone with a ramp that's probably better to be using. ____________________ My Flickr |
 Posted: 15:39 - 07 Nov 2009 Post subject: |
I use one ratchet strap. I have the loop hooks on the floor of my van, I hook the strap onto the hook just forward of the rear right wheel arch, run it under the front of the bike seat and the ratchet on the rearmost left hook. With the bike on the sidestand and in gear I ratchet it down just like that. Never had one move like that. ____________________ a.k.a 'Geri'
| WildGoose |
 WildGoose White Van Man
 Posted: 16:05 - 07 Nov 2009 Post subject: |
| Stinkwheel wrote: | if you don't get it all the way in, DO NOT give it more throttle, roll back down and try again. If the front wheel is in and the back is still on the ramp, gassing it will cause the ramp to shoot out backwards and down you will go. |
I did this with my KLE , it was not a fun filled few minutes, though I was alongside and not sat on it. It dropped onto its sump, leaving just sump and front wheel in the van the rest hanging out the back, ramp on floor, and me holding the bugger up. KLE's are light, but not /that/ light.
Manhandled it in from that mess eventually with a lot of swearing. Probably wasn't good for me though.
Ramps that hook on to the van are better than ones that don't.  ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| Reppyboyo |
 Reppyboyo Nearly there...
 Posted: 16:21 - 07 Nov 2009 Post subject: |
In the past I`ve only used 1 rachet strap and a plank of wood.
2 of us push the bike up into the van.
1 hold the bike in place the other put the rachet strap over the seat and hooked into the van floor, tension it down to the suspension is loaded.
Works fine.  |
| vt6 |
 vt6 Spanner Monkey
| G |
 Posted: 18:25 - 07 Nov 2009 Post subject: |
| stinkwheel wrote: |
If you're brave enough to try riding it up the ramp, mind your head and if you don't get it all the way in, DO NOT give it more throttle, roll back down and try again. If the front wheel is in and the back is still on the ramp, gassing it will cause the ramp to shoot out backwards and down you will go. |
I've only managed to shoot the bike out the back once. If you're gentle with the throttle it's not too bad. That time was a race bike, thankfully without belly pan but with my newly bought just fitted full m4 exhaust system, which the bike landed on . The brake lever had hit something else in the van on the way in - the basic technique is to get decent speed up before you hit the ramp anyway .
You need to use 'trials' style skills to get it in - a bit of a burnout on the edge of the van will give it a bit more grip, then push with your hands as you release the front brake and give it a bit of gas. Make sure you're covering the rear brake and clutch just encase it does grip really well!
On the range of different things to use - with a dirt bike I've often just used a single old bungee to hold the bike against the side. With a race bike I'll generally use two or three ratchet straps, or one held against the side if it's a bit tatty.
With someone else's shiny bike they're taking to sell for many thousands pounds I'll use four to six - and more importantly, make sure they're happy with it first .
Cheap ratchets may work once or twice, but not all will do that. They often then won't ratchet. Only had a couple of straps break and that's been old ones on trailers, where I always take even more precautions anyway. |
| Gazz |
 Gazz World Chat Champion
| G |
| cazmal |
 cazmal Two Stroke Sniffer
The last post was made 16 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
