mikuni Carb problems
Alabama Blacksnake
PostPosted: 14:38 - 08 Nov 2009    Post subject: mikuni Carb problems Reply with quote
Basically im looking for parts for my carb. Its a mikuni and thats all i know, it has no serial numbers or anything reconisable to track it down.
I think it maybe a mikuni tmx but im not to sure as all the other tmx carbs i've looked at have not got the sloped induction from the air filter or to the cylinder.
I've attached a picture so if anyone could help that will be much appreciated Thumbs Up
cheers Tom
Bikes i've owned: mobylette ----- Ts 50er ------ GS 400e ------ CB250n superdream ------r6 ------ bandit 400 ----- 2005 kx 125
Bikes i have:dtr125 field bike that doesnt not seem to die!!! 1992 gsxr 750 Very Happy
trevoriv said: Leathers are like teenage girls, the tighter the better.
hovercad
PostPosted: 15:51 - 08 Nov 2009    Post subject: what bike? Reply with quote
Hello kicker2508,
What bike is this from?
Craig
stirlinggaz
PostPosted: 15:56 - 08 Nov 2009    Post subject: Reply with quote
Hi,
does look like a tmx....
u measured the bore? (accurately)
that would be a good starting pont.
the mikuni guide is also useful.
give it a GOOD clean on the outside, & you might find a couple of faint numbers (maybe around about the choke area).
what bike did it come off? or did you just get the carb, on its own?
& specifically, what parts do you need?
cheers,
GAZ
smegballs
PostPosted: 15:45 - 09 Nov 2009    Post subject: Reply with quote
Thats the carb of his Yam DTR 125.
Not sure what problems he has with it but its definatly off that bike.
stirlinggaz
PostPosted: 18:52 - 09 Nov 2009    Post subject: Reply with quote
hi,
iirc, the older ones had the vm26 (essentially same carb as the 125 gamma & mtx125,just different jets) got a couple lying in bits in ma big box of carb bits.
&, the later ones had the TM28.(imo a far better carb, though its not much bigger)
should be easy enough to identify by checking the workshop manuals, available over on dtr125.net.(well,they used to be)
cheers,
GAZ
Alabama Blacksnake
PostPosted: 14:14 - 10 Nov 2009    Post subject: Reply with quote
yh its of the yam dtr125.
Im looking for the air screw pilot as it was all messed up and i couldnt adjust it. cheers for the link Thumbs Up
cheers Tom
The last post was made 16 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 48.42 Kb
