| Gareth |
 Gareth Nova Slayer
 Posted: 12:16 - 09 Nov 2009 Post subject: |
If you are getting a spark then that suggests that the kill switch wiring, etc, is fine.
Possible fuel isn't getting through. Also possible too much fuel is getting through.
I would suggest possibly trying to get someone to give you a push and bump start it. Fair chance that would start it and also fair chance that once it has started and had a chance to clear out the rubbish in the engine it will start more easily in the future.
| Gareth |
 Gareth Nova Slayer
 Posted: 12:41 - 09 Nov 2009 Post subject: |
For the gear change, check that there is sufficient oil in the gearbox and that the clutch is adjusted properly.
Point about too much fuel would likely be the needle valve not sealing. Either from the float heights being wrong, some dirt in the needle valve or the needle valve itself is worn damaged (it has a small rubber tip which can easily wear out).
All th best
| Gareth |
 Gareth Nova Slayer
 Posted: 13:09 - 09 Nov 2009 Post subject: |
Clutch plates are probably sticking together. Suspect they would free off rapidly once you got the engine started.
The float height can change with time. It is just dependent on a thing metal tang which can bend slightly with time, plus the floats themselves can develop holes. However probably neither are that likely as a cause of it failing to start totally.
You could also try the bodge solution of a can of cold start. Take the airbox lid off and filter out and squirt a bit in while kicking the engine over.
| Gareth |
 Gareth Nova Slayer
| Gareth |
 Gareth Nova Slayer
| bradh511 |
 bradh511 Scooby Slapper
 Posted: 13:55 - 09 Nov 2009 Post subject: |
The normal MTX is a fair bit different. Think the engine mounts are in the right place but you need different spacers (this is going on something I was told 20 years ago with someone fitting an NS engine into an MBX). However it probably depends on which MTX, as I think some models (not sold in the UK) were built at the same Italian factory as the NS and it wouldn't surprise me if they used the same engine.
| Gareth |
 Gareth Nova Slayer
| Gareth |
 Gareth Nova Slayer
| Gareth |
 Gareth Nova Slayer
| bradh511 |
| Gareth |
 Gareth Nova Slayer
| tonyts50 |
 tonyts50 Trackday Trickster
| Gareth |
 Gareth Nova Slayer
 Posted: 17:28 - 09 Nov 2009 Post subject: |
Low compression could make it harder to start and reduce performance. Easy to check though with a compression tester.
The reeds are there to stop the fuel / air mix taken into the crankcases being pushed back through the back when the piston starts to move down.
The fuel dripping from the "breather" sound like it is overflowing. Ie, float height wrong or needle valve not sealing.
| Gareth |
 Gareth Nova Slayer
| Gareth |
 Gareth Nova Slayer
The last post was made 16 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
