Arrrgh, car immobiliser!
killa
Won't Shut Up
PostPosted: 14:53 - 09 Nov 2009    Post subject: Arrrgh, car immobiliser! [HELP!] Reply with quote
My missus has one of them hatch-back Rover 214's.
Ive booked it in for a service as its in need of one. Just my luck, the key fob that turns the immobiliser off and opens the car has decided to die, i replaced the battery with no joy.
How do i get it to the garage now?! Confused
Misc
PostPosted: 15:00 - 09 Nov 2009    Post subject: Reply with quote
I had the exact same problem, immobilizer wouldn't switch of the alarm which meant the car wouldn't start. This may or may not help but a local mechanic suggested that i spray the wires connecting to the starter motor with some WD40 then plug them back in, not sure what the starter motor has to do with the alarm system but it worked! Couldn't believe it.
He says that it solves a lot of the problems with immobilizers, i'm quite surprised as there's nothing about this on the net.
Bikeless
PostPosted: 15:04 - 09 Nov 2009    Post subject: Reply with quote
resetting fob key
1. take out battery
2. hold each button in for 10 secs (not both at same time)
3. replace battery
4. unlock car then press the locking button on fob key fast 4 times
5. the fob key is reset and should be in tandom with the alarm
may or may not work,give it a go, Thumbs Up
killa
Won't Shut Up
PostPosted: 15:38 - 09 Nov 2009    Post subject: Reply with quote
Right ok guys, thanks for that, will try it tonight. Thumbs Up
killa
Won't Shut Up
PostPosted: 08:26 - 10 Nov 2009    Post subject: Reply with quote
The mechanic i usually go to got me the info for resetting the fob.
Open the car with the key, hold the fob close to the car and press the button 4 times in quick succession.
Ive done this, many many times, i took the battery out. I dissconnected the battery and the starter motor as mentioned above. No luck. Sad
She doesn't have a spare, so how can i drive the bloody thing?!
10 pence Short
PostPosted: 08:46 - 10 Nov 2009    Post subject: Reply with quote
Is the red LED light on constantly on the dash with the ignition switched on?
Have you got the security overide code? Usually written or printed on a card with the handbook, like the radio code, four digits.
I haven't had a cont all day, drinkstable.
killa
Won't Shut Up
PostPosted: 10:02 - 10 Nov 2009    Post subject: Reply with quote
The dash LED flashes intermintantly when the door is closed and locked.
If i open the door and try and start the car, the light is permanetly on.
How would i put a code in if there's no keypad?
0ddball
PostPosted: 11:54 - 10 Nov 2009    Post subject: Reply with quote
You turn the key in the door lock one way then the other in the right pattern.kinda like a lock on a safe.
NSR Mick
PostPosted: 12:47 - 10 Nov 2009    Post subject: Reply with quote
Is it factory fit?
killa
Won't Shut Up
PostPosted: 13:01 - 10 Nov 2009    Post subject: Reply with quote
gsxrmick wrote:
Is it factory fit?
Yep.
Seems like i can just buy another key fob and reprogramme it to the car. I just need to get one asap.
My GF's dad has been taken to hospital in liverpool and we're 2.5hrs away, she has no car. Sad bugger
10 pence Short
PostPosted: 13:13 - 10 Nov 2009    Post subject: Reply with quote
If you had the code you input it by a sequence of door locks and unlocks, there is a company you can buy the code from £15.
Reprograming a new key fob is different to re-syncing an already coded one.
Also open the keb fob and check that the solder is all intact especially around the battery carrier and buttons, have been known to fall apart.
killa
Won't Shut Up
PostPosted: 13:57 - 10 Nov 2009    Post subject: Reply with quote
Oh right ok. Bum
I just found a scrappy with a fob. No use without this code.
The last post was made 16 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 76.73 Kb
