| ginllfixit |
 ginllfixit Nova Slayer
| Cigaro |
 Cigaro World Chat Champion
| ginllfixit |
| Cigaro |
| Howling TerrorOutOfOffice |
 Posted: 15:57 - 09 Nov 2009 Post subject: |
My air cooled 250 takes ages to fully warmup in winter (<5 degrees)
So sometimes when i'm slowing to a stop it cuts out. I've got an idler adjustment knob within easy reach and give it a twist before setting off.
You mentioned yours cutting out whilst you were filtering. Was this when the throttle was closed? Or did it cut out with some throttle on?
A good spray of WD40 wouldn't go amiss especially with these cold damp days we're getting.
Carb icing occurs when there is alot of moisture in the air combined with a low temperature.
Some more knowledgeable people will offer advice.
Pat ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| ginllfixit |
 Posted: 17:14 - 10 Nov 2009 Post subject: |
For the short term on cold mornings, then yes try and keep the throttle just on and clutch it. Hopefully the garage will be able to re-adjust your carburettor, either your idle or mixture.
As for the WD40 Just spray it over your carb. And if possible remove your newish air filter and spray abit in the housing but not directly at the inlet to your carb. After that just spray it whenever very cold or wet weather is forecast (every other day )
Hope you get it sorted.
The last post was made 16 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
