| EARTHWALKER |
 EARTHWALKER Derestricted Danger
 Posted: 09:55 - 11 Nov 2009 Post subject: How's this for a theory? |
Some may have seen my post a few weeks ago, but for those that didn't, here is a short summary.
Basically, as long as you stay below 70mph, the bike runs like a dream. If it's pushed beyond that, it will cough, splutter and eventually die.
I recently had it in the garage for some back pads, but the mechanic said they are fine and didn't need changing. I left there and got about 1 mile away and the bike died while doing 40 (it had been raining hard). He diagnosed the problem being the carb having water in it.
My theory is this:-
1) If my petrol cap seal is gone, water would be getting into the tank when it rains; causing what I am experiencing? I'm quite certain of this one.
2) The more speed, the more air will be sucked through the broken tank seal, stopping the bike.
Good or bad theory? I just thought of it while in bed...lol
I've recently changed the HT's, Coils and CDI with no change in problems.
Try not to laugh...I don;t know much in the way of mechanics. Give me a PC, printer, notebook, netbook, digicam and I can strip, change, repair, look smug, but bikes...oooh, scary  ____________________ Insanes Numquam Moriuntur |
 . Renault 5 Driver
| EARTHWALKER |
| The Artist |
 The Artist Super Spammer
| robocog |
 robocog Traffic Copper
 Posted: 10:24 - 11 Nov 2009 Post subject: |
I would say part 2 is the opposite of what I have read
Leaving the filler cap off would not cause running issues, just a tad dangerous
If the seal was too good on the tank it would create a vaccum in there (because you are using fuel in a sealed tank, and it needs to be replaced by something) and could cause fuel starvation and behave like there is a blockage (filler caps need to allow air in and usually have a small drilling ...maybe yours is clogged?)
As you are running carbs it may pay to crack the float bowl drain screws open when it has done the dying thing...if they are empty then it would be fuel related
I could imagine that this is not such an easy task though if they are not easy to get to
If next time it dies you crack the filler cap open with your ear next to it and you hear it suck air in then you have found a possible cause and could be done fairly immediately after the event without having to strip the bike down
Regards
Rob |
| el_oso |
 el_oso World Chat Champion
| EARTHWALKER |
 Posted: 12:16 - 11 Nov 2009 Post subject: |
It's a GSXR-1100 WP. I like the ear thing as it made me smile.
I am deaf btw  ____________________ Insanes Numquam Moriuntur |
| Kickstart |
 Kickstart The Oracle
 Posted: 12:30 - 11 Nov 2009 Post subject: |
If there is no vent to the tank then it will cause problems. No air in means no fuel can leave the tank. Tends to get worse at higher speeds (and could be the problem you are having).
Water in the fuel would probably stop the engine with barely any throttle. Water sinks to the bottom of the carb and the main jet is down there, so as soon as you move off the idle circuit the main jet will probably draw in the water. Takes VERY little water to cause a problem.
| karoshi |
 karoshi Brolly Dolly
 Posted: 13:23 - 11 Nov 2009 Post subject: Re: How's this for a theory? |
| EARTHWALKER wrote: |
My theory is this:-
2) The more speed, the more air will be sucked through the broken tank seal, stopping the bike. |
part 2 would only happen if your tank is low enough on the reserve that the level of remaining fuel is lower in the tank than the fuel pickup pipe, allowing it to suck air in? As Kickstart says, if your tank was airtight, the bike would stall when the carbs can't suck any more fuel in against the increasing vacumn pressure in the tank.. or if you have a monster engine, it'll collapse the sides of your tank like an empty beer can
If you suspect water in the fuel, have you drained the tank and carbs and refilled with new clean fuel?
In my (admittedly very limited ) experience, I've had one car do this kind of thing to me, although it wasn't at 70mph it was at 3500prm in any gear.. That turned out to be a blocked secondary needle in the car (1.8L engine with a single twin-choke carb) which meant that as the second fuel feed should've come in it didn't and the air-fuel mix got leaner and leaner until it died. ____________________ Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd |
| el_oso |
The last post was made 16 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
