| Thom |
 Thom World Chat Champion
| finpos |
 finpos World Chat Champion
| Jamie S |
 Jamie S World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 20:26 - 09 Nov 2009 Post subject: |
I would expect a constant 12V to each of the coils, interupted momentarily to trigger a spark.
Fairly sure the ER5 uses a wasted spark system as the ignition pickups are on the crank and no way for it to know which rotation of the crank requires a spark. However as the sparks required are not 360 degrees of the crank out it needs to coils, rather than just 2 leads from the same coil. I presume that there are 2 seperate pickups on the flywheel to trigger a spark, so one of these could be dead as well.
I would expect the 2 coils to be the same and you could swap them over (fully).
Check the resistance over the coils. With luck one will be obviously dead (no circuit), but otherwise need the real resistances for them (manual should list them).
| Lukaz2205 |
 Lukaz2205 Nova Slayer
| Thom |
 Posted: 18:58 - 11 Nov 2009 Post subject: |
hi,
Jamie tried the coil from the other side so that wasnt the problem unfortunately
hoping the new CDI/coil combo will fix it!
If not it seems to be the pickup(s) and then wiring! ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
Previous Bikes: 1990 Honda NSR125 'Rothmans' (The smoking one), 1990 Suzuki GS500e 'Caf? fighter' (The loud one), 1987 Kawasaki GPX400r (The quick one), 1997 XJ600s Diversion (The reliable one), 2000 Kawasaki ER-5 (The spontaneously combustive one) |
| Jamie S |
| Thom |
 Posted: 20:34 - 11 Nov 2009 Post subject: |
For god sake I hope it works  ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
| Jamie S |
The last post was made 16 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
