Urgent part required help!!!!!!!!
Gareth
PostPosted: 22:44 - 11 Nov 2009    Post subject: Urgent part required help!!!!!!!! Reply with quote
Hi Guys
Can any one help me am after a carb for a ns125r-k 1990. I have this part number phbh 26 fs make dellorto. Any one sellin one let me know. Or dose any one know where i can get hold of one. I have been on dellorto, there website but can find the exact part number any help guys really appreciate it.
Regards Gareth
PostPosted: 22:51 - 11 Nov 2009    Post subject: Reply with quote
Should turn up on Ebay fairly often. However why do you need a new one?
Gareth
PostPosted: 23:06 - 11 Nov 2009    Post subject: Carb Reply with quote
Hi Keith
I have tried to start my bike starts with easy start and will run then dies. I have managed to get it to run and idel fine. Now i cant get it to run i stripped the carb and reed valve. As i stripped the carb i snapped the small gold clip off the float that held on a valve if you know what i mean. It just wont start tried bumping off no luck and there is a spark. I jsut don't know whats wrong so thought by buying a new carb would fix the probblem.
Regards Gareth
PostPosted: 23:17 - 11 Nov 2009    Post subject: Reply with quote
The bit from the float should easily be available as a spare part.
For the rest make sure it is clean. Mainly the idle circuit. Possibly take everything that is rubber out and then leave the carb body soaking in something to dissolve the dried on petrol (possibly brake cleaner as you can buy it in buy unlike carb cleaner).
Gareth
PostPosted: 23:40 - 11 Nov 2009    Post subject: Carb Reply with quote
Hi Keith
Sorry to be a pain any chance you know where i can find a carb kit for it that comes with the float and all the jets and needle. Thanks for all ya help really appreiate it.
Regards Gareth
PostPosted: 23:45 - 11 Nov 2009    Post subject: Reply with quote
Think they are just seperate parts. The UK Dellorto importers should be able to help you
alains
PostPosted: 16:05 - 12 Nov 2009    Post subject: Reply with quote
you may also buy a second hand 28PHBH used on the NSR125
just check where are your adjusting screws :
- on the left , you need the JC20 model (28PHBH/FS)
- on the right , the JC22 model (28PHBH/FD)
Gareth
PostPosted: 00:51 - 13 Nov 2009    Post subject: Reply with quote
Thanks for the post, can i jsut ask what is the diffrence to the phbh26fs to a phbh28fs will it make any diffrence at all.
Regards Gareth
alains
PostPosted: 01:28 - 13 Nov 2009    Post subject: Reply with quote
intake mixture is bigger , it has a powerjet
Gareth
PostPosted: 01:32 - 13 Nov 2009    Post subject: Reply with quote
Will it run ok on a ns125r 1990
Regards gareth
The last post was made 16 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 63.78 Kb
