cg help!
RooRoo
Anal Intruder
PostPosted: 18:23 - 22 Jun 2004    Post subject: cg help! Reply with quote
i got a honda cg a while ago, and someone pointed out it was making a vibratey ticking sound when it gets revved, which ive now started to notice a lot more...my GS125 never did it, and i took it into the dealer and the technicial said its normal...but im still a but concerned..its makes the normal engine noise (you know theone...) but over the top is the very quick and high pitched 'ticktickticktick'...
any idea what it is/if its anything bad?
Robby
Dirty Old Man
PostPosted: 19:02 - 22 Jun 2004    Post subject: Reply with quote
Most likely just the pushrods - CG has a pushrod engine, GS has an overhead cam engine. CG engines make an awful racket, what with them being designed to make fuck all power in a about 1965.
mr.z
PostPosted: 22:55 - 22 Jun 2004    Post subject: Reply with quote
I seem to remember mine doing the same!
its could possibly be tappets being noisey, which could be if your oil is low (try and fill it to the max level it makes a little difference)
Otherwise ignore it, its a very old engine design as robby pointed out, check the oil, keep your chain in good condition and if the engine explodes get a replacement Wink
Mine was allot older and was mechanicaly sound, chances are yours will be too.
Keep telling yourself "i will have a better bike after my test"
mr jamez
PostPosted: 23:26 - 22 Jun 2004    Post subject: Reply with quote
Yeah should just be noisy tappets, you could probably adjust the clearances but who cares, being a little loose won't do it any harm.
dibbster
PostPosted: 23:37 - 02 Jul 2004    Post subject: Reply with quote
I shouldn't worry about it, the CG engine will go on and on and on.....
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
ts50x0
PostPosted: 20:27 - 03 Jul 2004    Post subject: Reply with quote
i wouldnt worry. its probably more noticable because your friend pointed it out, before you probably heard it but didn't even think about it. try changing the engine oil and if it makes no difference i wouldn't worry about it. i've never heard of a cg blowing up so i'm sure its nothing.
good luck Smile
The last post was made 22 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 47.37 Kb
