| Jamie S |
 Jamie S World Chat Champion
 Posted: 18:18 - 15 Nov 2009 Post subject: Braided Line worn through to the metal, safe to use ? |
Hey guys, fitted my brake line on the front of my dt, the end was swagged on it the wrong place (180degrees out from where it should of been) putting the brake line , when under braking right inline with the tyre and rubbing on it, needless to say it's worn the outer clear bit of the line away, right down to the metal braid, but hasn't dammaged the metal, will it still be safe to use ?
I Emailed the seller that I bought them from (acctualy bought them in person at the stafford show), he said that he refused to sort the problem with it being made wrong , so thats why I went ahead and fitted it any way.
Ebay shop: I reccomend you DON'T use this guy for lines:
https://stores.shop.ebay.co.uk/COBRA-PERFORMANCE-BRAKE-LINES__W0QQ_armrsZ1
Jamie. |
| tatters |
 tatters Exxon Valdez
 Posted: 18:29 - 15 Nov 2009 Post subject: |
Will be fine to use only the clear pvc sheath is worn, some braided lines dont even have a outer sheath. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Ariel Badger |
 Ariel Badger Super Spammer
| tatters |
 Posted: 18:36 - 15 Nov 2009 Post subject: |
If its still rubbing on the tyre is will fail, have you repostioned it? ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Jamie S |
| virus |
 virus World Chat Champion
 Posted: 22:32 - 15 Nov 2009 Post subject: |
as long as Id eliminate the wearing out risk, and the metal didnt look too worn out, Id use it, whether or not Id recommend it to someone else however is a different matter.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| supZ |
 supZ World Chat Champion
| Jamie S |
 Posted: 18:49 - 16 Nov 2009 Post subject: |
| supZ wrote: | hold on a tick... you're bashing a seller because, it sounds like to me, you fitted it wrong in the first place!
theres not a whole lot to a braided brake line, certianly nothing that can be 'wrong'.. sounds like you just put it on the wrong way round or didnt route it properly causing it to rub on your tyre (surely when you put them on and saw it was touching the tyre this would have tipped you off??)
im not surprised the guy wouldnt do anything about it, its not his or the manufacturers fault you've damaged it. |
First of all, it wasn't touching the tyre unless the suspention is fully compressed under hard braking, and seccondly, he has swagged the ends on WRONG, roughly180 degrees from the way that it should of been, making the right angled banjo for the caliper the wrong way, and the 15degree curved one for the master cyclinder the right way, and no way in hell was i going to twist the line to get it on the caliper end. |
| cobra performace |
 cobra performace L Plate Warrior
| G |
 G The Voice of Reason
 Posted: 13:56 - 09 Dec 2009 Post subject: Re: Cobra Performace brake line |
Well cobra performance, L Plate warrior, perhaps you should check what email address he sent the email to and find out why you didn't get it?
Otherwise, for responding in a moderately civil manner.
For Jamie; if there's any danger of it touching again, I'd stick some tape around the worn bit. That way it should be quite obvious if it is rubbing again, as opposed to then letting the braiding get worn away as well. |
| MarJay |
 MarJay But it's British!
| Jamie S |
| cobra performace |
The last post was made 16 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
