Anyone done any iCalendar work?
Gazdaman
I did a trackday!!!
PostPosted: 23:08 - 15 Nov 2009    Post subject: Anyone done any iCalendar work? Reply with quote
I know this may out-geek what is essentially a motorbike forum! But I thought I'd try anyway.
I'm trying to write a .ics file to enter entries into a calendar every 10 days.
That's not too bad, it looks like this:
Code:
BEGIN:VCALENDAR
CALSCALE:GREGORIAN
METHOD:PUBLISH
VERSION:1.0
PRODID:-//GazScript//ShiftCal//EN
X-WR-CALNAME;VALUE=TEXT:ShiftCal
BEGIN:VEVENT
SUMMARY:First Early Shift
DTSTAMP:20091115T220000
UID:D70C88D5-E5A1-48EC-84A4-D05DBD5CD8F6-1
DTSTART:20091117T070000
DTEND:20091117T160000
RRULE:FREQ=DAILY;INTERVAL=10
BEGIN:VALARM
TRIGGER:-PT1H15M
REPEAT:1
DURATION:PT5M
ACTION:AUDIO
END:VALARM
END:VEVENT
END:VCALENDAR
The bit I can't work out, is how can I change the entry if it falls on a Thursday, Friday or Saturday. At the moment it just places an entry every 10 days regardless.
There is a BYDAY argument that allows you to specify a day, but I don't think it works if you've specified a 'DAILY' repeat rule.
Clutching at straws I know, but anyone done any?
Gaz
Neorion
PostPosted: 09:29 - 16 Nov 2009    Post subject: Reply with quote
I dont do a lot of scripting but could you not use a conditional variable if thats supported in the code your using?
If var= thursday; friday; saturday'
Then
run whatyouwanttodo.script
Question
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
Gazdaman
I did a trackday!!!
PostPosted: 11:08 - 16 Nov 2009    Post subject: Reply with quote
I would, if one one existed in this particular language. Good thought anyway.
Gaz
dibbster
PostPosted: 14:52 - 16 Nov 2009    Post subject: Reply with quote
If it is every 10 days they will always fall in the same order e.g. If your 1st day is today (monday)
10 days would be Thu, then Sun Wed Sat Tue Fri and back to monday. Can you exploit that in some way?
What if you did it every 70 days and had 7 VEVENTS? (4 of one type and 3 different ones for Thur, Fri and Sat.)
Confused Just a thought Razz
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
Gazdaman
I did a trackday!!!
PostPosted: 15:02 - 16 Nov 2009    Post subject: Reply with quote
Hmm, I like the way you think.
The scripting interface seems fairly crappy for the .ics file type. But if I used some other sort of scripting language I could work it out.
Basically eventually I want to write this into an iPhone app.
But with iPhones not being able to have things running in the background it's fairly useless. Hence I'm just trying to write them all into the calendar automagically.
I've done it at the moment with the first script, and I'm just editing thurs/fri/sats manually.
It's a start.
Gaz
The last post was made 16 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 46.36 Kb
