| sickpup |
 sickpup Old Timer
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 00:42 - 18 Nov 2009 Post subject: |
that doesnt sound too bad,
i did the clearances on my xz400 and i had to
1 take seat off
2 take tank off
3 unbolt air box
4 unbolt carbs
5 undo rad hoses
6 unbot rad fairing
7 unbolt rad
8 unbolt top engine mount
and that was even before i remove the 2 rocker covers and its a naked bike
and i had to change all bar 1 shim so all 4 cams had to come out
ad thats on a 1982 bike  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Ingah |
 Ingah World Chat Champion
 Posted: 01:11 - 18 Nov 2009 Post subject: |
I have relatively little experience, but i do expect they will get complicated if they aren't at the moment, the amount of times i've heard mechanics complain along the lines of "cars these days, so complicated you need a laptop to fix anything". But bikes do appear to be slowly copying cars and gaining complexity in the way of things like ABS (a good thing imo), and fuel injection (not such a good thing imo, as i roughly know where i am with a carb...) I really hope the line is drawn somewhere though, as i wouldn't enjoy having to take my bike and my (future) car to a mechanic because i haven't got the fancy software.
I've kept it very simple, starting with a CG125 (invented in 1970s), seemingly widely aknowledged as the easiest bike to work on, and now have a CB500 (1990s) which again is largely simple, although the valve clearances are more complicated than on the older CG125 engine design (so i've left them alone). To be fair, this could siomply be because it's necessary for a bigger engine or something like that though.
Wouldn't really fancy trying to work on a newer sports bike, with all this here fancy stuff to go wrong, and fairings to remove.
I'm surprised to hear it's such a job on the ER6F - i was under the impression it was a newbie-friendly bike (therefore generally easy?) ____________________ -- Ingah |
| chris-red |
 Posted: 01:31 - 18 Nov 2009 Post subject: |
Try doing the spark plugs on a TDM,
https://img.photobucket.com/albums/v295/chris-red/my%20pics/21012009122.jpg
This is after removing both side panels, both inner panels, both mid panels, tank, seat and airbox. See the orange and green wires slightly left of center? behind that you may just be able to see one of the HT leads. Don't even trying to get to the other one. It's the only bike I know that could probably justify 2 hours dealer labour to change the plugs. The S4 has twice as many and I could probably do it in 30/45 mins. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| temeluchus |
| Mystery |
 Mystery World Chat Champion
| hmmmnz |
 Posted: 05:32 - 18 Nov 2009 Post subject: |
my mz500 is the easiest bike ever (rotax 500 lump)(excluding aircooled piston port 2 strokes)
it has a cam belt, and takes about 5 mins to change that,
valve cleances can be done in less than 10mins and only require you to remove a couple of little plates,
you can remove the whole head and barrel in about 15mins tops,
gotta be why the british army uses the same lump in their bikes, ____________________ the humans are dead
| Blau Zedong |
 Blau Zedong Banned
| Smooth |
 Smooth Could Be A Chat Bot
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 09:18 - 18 Nov 2009 Post subject: |
I think they are staying pretty similar, just getting more difficult in different ways. ____________________ My Flickr |
| stinkwheel |
 Posted: 09:58 - 18 Nov 2009 Post subject: |
I think there is less rigmarole with the VFR even. Just need to remove the fairing middles, tank, airbox and radiator for that. There are two cylinder heads and 16 valves to deal with but they were surprisingly easy to get at.
Apparently the 800s are a bit more of a tw@ because you need to take the entire fairing lower off and the side mounted radiators get in the way more than simply removing the front one (which isn't hard to remove in the grand scheme of things, only the one bolt).
So yes, they are getting harder to work on and I would go so far as to say it is deliberate.
Took the fairing off a CBR125 not so long ago to repair it after a crash. There are 16 seperate pieces of plastic in the top fairing alone. Yet my GPZ which was made 10 years previously managed to achieve the same task using one piece. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| damz |
 damz World Chat Champion
| Smooth |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 10:14 - 18 Nov 2009 Post subject: |
The most I want to do to get to plugs or valves is take the seat and tank off. At a pinch, I don't mind taking side fairings off.
And I want locknut adjustment, not shims. But that's a different rant. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Itchy |
 Itchy Super Spammer
 Posted: 10:22 - 18 Nov 2009 Post subject: Re: Are bikes getting harder to work on? |
| sickpup wrote: |
I realise this is a fully faired bike but I think having to take the screen and clock surround off to get a side fairing panel off is going to the extreme a bit. So what do you think about your bike and the bikes you have worked on, are they getting harder to do? |
Yes they are, as bikes are a low margin item, quite typically they are like gillette shavers in that the handle is virtually free and they make money via servicing and parts.
Its why simple immortal indestructable bikes like XTs, NTVs , CXs,XJ600s no longer exist, as they are simple immortal and indestructable why buy new if it lasts?
However such things are often done to reduce manufacturing costs too, in that a one piece fairing needs expensive 3dimentional moulding, while if you split it into many smaller flatter parts it requires smaller molds, oh and of course more parts to replace when damaged.
My 1997 XT was incredibly simple to work on, one bolt took a panel off, two bolts secured the electronics bay, and the tank was secured by a single bolt, I could have the engine out 30 minutes.
While the new XT which has a far fairing crash bars , vulnerable plastic tank and water cooling will take hours to even get to the engine. Though on the flip side they did improve it a bit, in that for a single it is vibe free, it gets 5more mpg (Even though it weighs more) and the 5th gear doesn't disintegrate either.
I think as long as there is some sort of improvement for the 'price' of more difficult maintenance its ok, its not ok when it gets extra complicated with no improvement, like the VFR800 VTEC..
Or when chocolate bars decrease in size and the price stays the same or even goes up, totally unacceptable. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Syx |
 Syx World Chat Champion
| Charlie |
 Charlie World Chat Champion
| stinkwheel |
 Posted: 11:40 - 18 Nov 2009 Post subject: |
They do other stuff, I'm convinced just to annoy you.
Had a classic on the VFR. The very last bolt you need to take out when stripping the swingarm/unitrak fouls the mainstand bracket.
In order to get this bolt out, you need to remove the mainstand pivot but by the time you get to this point, you've already removed the swingarm and rear shock and the bike is now resting entirely on the mainstand.
Having sorted it all out this time round (using axle stands and such), I found that had the bolt been put in from the other side, there would have been no such problem. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dr. DaveJPS |
 Dr. DaveJPS World Chat Champion
 Posted: 11:45 - 18 Nov 2009 Post subject: |
apparently the new ducati monster has 11 bolts to remove the fuel tank.
although on old bikes you occasionally find some stupid designs, like on featherbed framed nortons you can't remove the side stand without removing the engine  ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| Kickstart |
 Kickstart The Oracle
 Posted: 12:05 - 18 Nov 2009 Post subject: |
Not so sure they are generally getting more difficult. Some get worse, some get better.
Worst bike we have ever had for working on was a 125 2 stroke Gilera from 1991. The CX125 is a complete pig to work on. Just about anything means removing the fairing, and to get the front fairing off you start by removign the bodywork at the back.
For comparison with the ER6, on a GPZ500 to do the valves.
Fairing inner panel off
Seat off
Tank off
Drain cooling system
Remove water pipes to head (normally stuck in place)
Remove throttle cables (possibly requiring the carbs to come off, which means unbolting the airbox
Removing the coils
Removing the rocker cover (just about possible with the coils off)
The old FZ750 is a fair bit worse, and the plugs are just about impossible to remove. Getting the carbs off a 1200 Bandit almost requires GBH to the bike. Older spine frame Triumphs need the carbs removing just to change an air filter.
Most modern bikes have frames that go around the outside of the engine with the carbs / throttle bodies pointing up with the airbox above them. Makes them a doddle to remove.
Might comes down to costs. Make it harder to work on and it is probably harder to make so making production more expensive and any warrenty work more expensive.
| truslack |
 truslack World Chat Champion
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 12:31 - 18 Nov 2009 Post subject: |
I think that on sports bikes, bikers in general have to take some of the blame in the move towards increased inflexibility, well, bikers and the nobs who enforce emissions laws.
Making bikes easier to service requires further R&D, not much in the grand scheme of things but when you are spending a lot of cash on R&D to make the latest GSX/CBR/Rx/ZX the lightest most powerful bike to date, which makes it quicker and therefore the highest rated one in the bike mags, which in turn leads to higher sales, then servicing and ease of maintenance come a long way down the list.
Take Stinkwheel's example on the VFR, a little bot of forethought on the design front could have seen that job made far easier but that requirement is way down on the manufacturers list of priorities.
I ride a Fazer 1000 and directly under the tank is a huge AIS (Air Induction System) valve that pumps clean air into the exhaust gases to pass the latest emission tests. I have now bought a blanking kit and removed the crappy think ang all the associated pipework but with it there you can't get to the sparkplugs at all. This is an exanple of manufacturers being dictated to and they know that putting the AIS there is a pain but there is nowhere else to put the huge valve.
I don't think manufacturers deliberately make things complicated (with the exception of VTEC ) but I do think that they don't really care about maintenance.
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| Kickstart |
| karoshi |
 karoshi Brolly Dolly
 Posted: 13:04 - 18 Nov 2009 Post subject: |
| The Shaggy D.A. wrote: | The most I want to do to get to plugs or valves is take the seat and tank off. At a pinch, I don't mind taking side fairings off. |
y'see coming from a cager's perspective as I get into bikes, that statement makes as much sense as:
| Quote: | well, if I have to do anything more than remove the headlights and learn french before I can change the engine oil.. |
Until I got my bike, the idea that i'd have to remove anything more than a plug lead to replace a spark-plug was just completely alien to me, but it's constraints of packaging and features that make these jobs more difficult..
It's happened / happening to every type of appliance that I can think of, to sell newer models to the public they have to be smaller and do more, and every time this is achieved the item gets more and more difficult to service.
You're not meant to do the valves on your new nicely faired motorbike, you are supposed to ride to the dealers, drop trew and bend over the service manager's desk while a gang of illiterate YTS monkeys take your bike round back and let a laptop tell them which bolts to round off with the airgun.  ____________________ Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd |
| 27cows |
 27cows World Chat Champion
 Posted: 13:59 - 18 Nov 2009 Post subject: |
I am convinced a lot of manufacturers deliberately make bikes more difficult to work on at home. Less home maintenance means more work and more lovely lolly for dealers. Honda in particular are notorious for their requirement of all manner of special tools to get things undone etc.
Main problem is that bikes are so tiny compared these days compared to the obese dinosaurs of 20-30 years ago. In order to squeeze an engine into a small and light chassic, lots of stuff has to be tucked out of the way. Fairings don't help, as they are time consuming to remove in general and relatively fragile. But even naked bikes can be a major pain in the arse.
When lots of stuff has to be removed just to get to the plugs, you have to say that the designers aren't doing much of a job. I begin to remember now why I've always liked air cooled strokers  |
The last post was made 16 years, 305 days ago. Instead of replying here, would creating a new thread be more useful? |
