Problem, Help ?
lewisb01
PostPosted: 23:34 - 19 Nov 2009    Post subject: Problem, Help ? Reply with quote
hi, ive got a speedfight 2 and ive got a problem with it. well to start off it just dont wanna go. it ticks over fine. just when you pull the throttle to move it struggles or when you full throttle it. it just makes a loud of noise like it trying to go but it moves a few yards then stops and maybe a few more. then it will cut off n a pop will come out of the exaust. ive had the carb checked and changed see if it was that. petrol was changed n toped the oil up too. i just dont know what else too do so anything would help thanks
TUG
PostPosted: 23:47 - 19 Nov 2009    Post subject: Reply with quote
Automatic choke on them, But that mixed with Bad air/fuel ratio means its going to kill itself. It could be a wide range of problems so its hard to diagnose really without seeing it.
Haz ER-5, innit!
27cows
PostPosted: 06:26 - 20 Nov 2009    Post subject: Reply with quote
Sounds like it could be ignition related. Bikes will often start with a weak spark but misfire and bugger about under load. Check the obvious stuff (plug, plug cap, HT lead, coil, alternator wiring, ignition switch). Wouldn't hurt to give everything a blast with WD40, see if that helps.
lewisb01
PostPosted: 09:52 - 20 Nov 2009    Post subject: thanks Reply with quote
il get some wd40 and see what happens cheers.
The last post was made 16 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.73 - MySQL Queries: 13 - Page Size: 38.16 Kb
