nsr driving me mad
kneedown
PostPosted: 20:38 - 20 Nov 2009    Post subject: nsr driving me mad Reply with quote
hi guys
my brother in law recently got into biking and brought an nsr
bought it cheap as non runner
got it running but having n o end of trouble with it, one day it rides and runs fine, then next day cuts out and wont start again.
put in new carb, decoked exhaust and cleaned powervalve
the problem is obviously fuel related, but im thinking maybe the exhaust has something to do with it, also had the head off and there are no problems there, any ideas?
cheers peeps
27cows
PostPosted: 21:36 - 20 Nov 2009    Post subject: Reply with quote
Someone was having a similar problem earlier. Again, I would suggest taking a look at the ignition components, particularly if the bike has been out in this rain we've been having.
If I had a quid for every time I've had problems with engines cutting out and generally buggering about as a result of a bit of water getting somewhere it shouldn't I'd be wealthy. Or at least a bit less poor Wink
Normally 2 stroke pipes are only playing a part in a bike not running well if they're chock full of crap or have a hole in somewhere (though that wouldn't normally cause the motor to cut out).
Biggest culprit in descending order is duff plug, rotten bit at the end of the HT lead, trapped or damaged wiring, dodgy/leaky ignition coil, leaky or damaged ignition switch (or wiring from same), water in the alternator components. I never hurts to check, or to give everything a blast with WD.
Also be sure to sure the fuel filler cap vent - a bit of dirt in that will cause the motor to die after running a short while.
The last post was made 16 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 31.98 Kb
