 ---- World Chat Champion
 Posted: 20:00 - 20 Nov 2009 Post subject: Is this repairable?[What caused it? ] |
Goto last post
https://www.bikechatforums.com/files/aaaaaaaaaaaa.jpg
Hard to see properly but the chips next to the ports are about 2mm deep.
A replacement cylinder is £600 so if it's not repairable the engine is scrap
Thanks
Dave ____________________ DRZ-400sm
| boundy |
 boundy Nearly there...
 Posted: 21:37 - 20 Nov 2009 Post subject: |
Cheers for the reply's ,i was pretty sure it would be beyond repair!
That's cheered me up a bit. Just got to hope it's not too expensive now  ____________________ DRZ-400sm |
| boundy |
| stevo as b4 |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 23:39 - 20 Nov 2009 Post subject: |
DT230 didnt last long then? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
 Posted: 00:08 - 21 Nov 2009 Post subject: |
The engine sounded quite rattly since i bought it to be honest but i thought nothing of it until my mate bought one which sounded a lot quiter than mine.
I should have trusted my gut instinct and stripped it then for a look.
Even if i did have to buy a new cylinder,i'd do it but if it's repairable i'll have it back on the road within a couple of weeks  ____________________ DRZ-400sm |
| Frost |
 Frost World Chat Champion
 Posted: 12:58 - 21 Nov 2009 Post subject: |
So i took the cylinder over to ard racing today.
He advised me to get the liner fitted because i'll get 4 re-bore's out of that one liner (re-bore is only £20)
In regards to power loss,he say's i wont notice the power loss at all,it would only be slightly noticable on a dyno.
So cost of the liner is £150 (nikasil was only £30 more) then however much wiseco charge me for the new piston & rings.
Not too bad at all considering i thought it was un-fixable
Thanks for the reply's  ____________________ DRZ-400sm |
| Frost |
 Posted: 17:34 - 21 Nov 2009 Post subject: |
Be careful, you will be tempted to buy a piston of an abnormal shape to improve compression etc, its probably not worth it  |
 Posted: 22:11 - 21 Nov 2009 Post subject: |
Price is a bit higher than a few online company's,but up here ARD Racing are quite well known for doing a good job so i dont mind paying the extra.
Had another bit of luck tonight aswell as i found the little piece of piston ring which caused all the damage it was in the exhaust  ____________________ DRZ-400sm |
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 21:37 - 22 Nov 2009 Post subject: |
For a repair to a single cylinder engine I would go for a liner;
It`s usually quite affordable and cheaper if you can do your own porting.
You then have the option of a few rebores,
If you want to you can bore to a much more common and therefore cheaper piston,
Down side is you may loose a little power,
A cast liner can be used with any type of ring.
but i would go for a modern steel type ring rather than the spun cast iron types,
as the modern wire types are suited to very wide exhaust ports, ie about 70% of the bore.
However if I had a multi cylinder engine and one bore was damaged I would go for welding and a replate so that both barrels had identical cooling and ring to bore friction.
but that`s just what I would do and everybody sees things there own way ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
 Posted: 14:50 - 25 Dec 2009 Post subject: |
Over a month now and i'm still waiting for the cylinder head back ! The waiting is killing me
So another week or so and i should get this back and i have all the gaskets e.t.c. waiting.
I'm wondering what could have caused this in the first place on a bike which only has 3000 miles I really don't want to put it all back together for it to happen again!
The carb was just setup a few weeks before this happened and it's running perfect according to the plug chop.I usually use normal unleaded but i have used super unleaded a couple of times
I do thrash the bike constantly and with it having no rev counter i tend to rev until the power drops off then change gear,maybe i should stop this? but it's a 2 stroke they loved to be revved don't they?
Any advice would be appreciated  ____________________ DRZ-400sm |
| chillpill |
 chillpill World Chat Champion
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 09:40 - 26 Dec 2009 Post subject: |
Over-revving causing extra ring wear
Looks like the plating's come off to me on the large patches at least and something has got trapped in there to cause the deep gouge (piec of plating perhaps?).
Send it off to be repaired and re-plated properly and get a good quality piston like wiseco, better yet, find out if you can get over-sized pistons and have it bored to suit that instead of welding.
Put a cheap piston in it and you're asking for more bother. ____________________ a.k.a 'Geri'
 Posted: 21:26 - 26 Dec 2009 Post subject: |
If Wiseco are making a custom piston then have them make it oversize deliberately to accomodate the repair to the barrel. ____________________ a.k.a 'Geri'
| stevo as b4 |
 Posted: 23:43 - 26 Dec 2009 Post subject: |
The last post was made 16 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
