What shall i do?
Dr Nick
PostPosted: 13:27 - 23 Jun 2004    Post subject: What shall i do? Reply with quote
Recently my chain snapped, it has sheared off the water pump, and some of the engine casing. I took it to my local dealer, and he said its going to need new engine cases, complete strip and reuilt with new gaskets, said its going to cost thousands.
Don't know what to do, shall i try get a new engine?, If so where from?
or should i just buy new casings?
To add insult to injury, i recently bought new chain and sprockets, a new rear tyre and an exhaust for it.
What shall i do?
is that it
Mr C
PostPosted: 13:29 - 23 Jun 2004    Post subject: Reply with quote
was it the old chain that snapped then?
you could always try fro a recon engine
or even second hand parts from a breaker
get the manual and do the work yourself - it will be very rewarding (and frustrating)
187.3bhp = 201mph
Dr Nick
PostPosted: 13:33 - 23 Jun 2004    Post subject: Reply with quote
Yeah it was the old chain that snapped, fitted new chain and sprockets, thought it was going to be ok, coming back from a mates house, the temp gauge went into the red, pulled over and the water pump was hanging off the side of the bike, noticing that the chain had originally sheared one of the bolts holding it on off, so because it vibrated so much, ot snapped itself off the one remaining bolt. If that makes sense.
How much would i be looking at if i tried to sell it now?
is that it
mr jamez
PostPosted: 13:35 - 23 Jun 2004    Post subject: Reply with quote
So it just damaged the engine casing and took out the water pump? surely those parts cannot cost thousands? unless the water pump damaged other parts of the engine when it got ripped out Confused
Dr Nick
PostPosted: 13:39 - 23 Jun 2004    Post subject: Reply with quote
Im thinking about getting a donor motor, anyone know of any good breakers?
is that it
Dr Nick
PostPosted: 14:08 - 23 Jun 2004    Post subject: Reply with quote
Nobody knows of one breaker then? not even one?
is that it
McJamweasel
BCF Junkie
PostPosted: 14:10 - 23 Jun 2004    Post subject: Reply with quote
From the 'Links' section. Also try the equally useful 'Search' page.
https://www.ukbiker.net/partsf.html
Phoenix
Twisted Firestarter
PostPosted: 15:31 - 23 Jun 2004    Post subject: Reply with quote
It's not quite that simple, when part of the crankcase breaks it usually has to be replaced as it's one cast lump, and his water pump hasn't broken, the mounting points for it on the crankcase have. I've got an aluminium welder looking at my engine to see if he can repair it without doing a complete stripdown (due to welding temperatures), if he can't it's probably new engine time.
dainesefreak
PostPosted: 15:39 - 23 Jun 2004    Post subject: Reply with quote
You could always try pricing the parts up yourself and doing the work, it will always be lots cheaper than a dealer. Get the dealer to do you a full quote including parts and labour. You will usually have to pay for the quote but it's worth doing.
Then get in touch with these people;
https://www.davidsilverspares.co.uk/
I have always found them to be very good and helpful. They can usually offer you a discount on the parts prices if you are willing to wait a couple of weeks for them to ship direct from Japan, or pay more for the parts straight away.
Good luck.
Dr Nick
PostPosted: 15:48 - 23 Jun 2004    Post subject: Reply with quote
Thanks for the replies everyone, found a guy on Visordown, who has a s/h hornet engine, he has taken the gearbox out of it to fix his bike and said he would give me the rest for 100 quid Very Happy. Ive been told to ring the dealer back at half 4, thats when they said everything will be priced up, Most probably i will be paying all the money for labour, as engine needs to be completely stripped down, then rebuilt with new gaskets etc, plus Lings are one of the most expensive places for parts i have just found out Doh! . I may try davidsilverspares, for gaskets etc.
Will post some pics up tomorow, when hopefully i get the bike back
Thanks again.
is that it
1cyl
PostPosted: 16:12 - 23 Jun 2004    Post subject: Reply with quote
Good luck mate. Thumbs Up
You can always borrow the zed for a while.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
mr jamez
PostPosted: 16:37 - 23 Jun 2004    Post subject: Reply with quote
phoenix wrote:
It's not quite that simple, when part of the crankcase breaks it usually has to be replaced as it's one cast lump.
Ah right Smile I was thinking it might just be hollow crank cases bolted to the side, but this isn't a little 2 stroke we are talking about I guess Smile
map
Mr Calendar
PostPosted: 16:56 - 23 Jun 2004    Post subject: Reply with quote
Don't know if this will help but from my experience try pricing up new bits from dealer as well as parts from breakers. Found some bits for my bike brand new were cheaper at dealer Surprised I'd also use nothing less than genuine gaskets for a rebuild Smile
HTH
Dr Nick
PostPosted: 17:42 - 23 Jun 2004    Post subject: Reply with quote
Just got a call from Lings, they quoted me 1800 quid plus, said parts came to 1400 alone, and the rest is labour.
Bit of a disaster Sad , hopefully i will be able to pick up a s/h engine from a breakers, and rebuild it with parts off of the donor engine.
Will get pics friday (when i get the bike back)
They picked the bike up from my house, to the dealership about 10 miles, said it would be 30 quid for the quote and transport.
Does this sound about right?
is that it
PostPosted: 19:29 - 23 Jun 2004    Post subject: Reply with quote
I would say look for a good second hand engine. I take it that the chain has smashed the crank cases, and they are probably something silly like £1k from Honda.
If you are lucky then the Hornet engine can have the gearbox removed / replaced without splitting the crankcases which would make the engine for the VDer worth having. If the crankcases need splitting then you are looking at a fairly large bill (probably around £100 just for the gaskets, for example), which might make it cheaper just to buy a complete decent Hornet engine.
Doing an engine swap would take a while but not be too difficult.
Does the Hornet use the CBR600FM style engine?
Dr Nick
PostPosted: 20:23 - 23 Jun 2004    Post subject: Reply with quote
Got it in one, lings quoted me £1200 Confused
I have been told the Hornet uses the 97 cbr600 engine, by this website https://www.devilbod.co.uk/bikes_madmen/hornet_mod.htm, reckon i could steal a crankcase off of a cbr engine instead? im guessing there will be a few cbr lumps lying around.
is that it
PostPosted: 01:17 - 24 Jun 2004    Post subject: Reply with quote
While parts might fit I suspect the whole engine wouldn't. For example the 250 Hornet is meant to use the CBR250 engine, but the carbs go on to the head at a very different angle. Suspect the head castings are different.
I have a manual for a CBR600FM. Looking at that the cases have to be split to put the gearbox in place.
Phoenix
Twisted Firestarter
PostPosted: 13:42 - 24 Jun 2004    Post subject: Reply with quote
Have you got any photos of the damage, is the casing leaking oil at all? except where the water pump fits in.
Dr Nick
PostPosted: 00:25 - 25 Jun 2004    Post subject: Reply with quote
Case isnt leaking oil, only where the water pump fits in, i get it back tomorow hopefully, so will get some pictures.
is that it
The last post was made 22 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 106.99 Kb
