About to give up on 550
blackfire2800
PostPosted: 19:26 - 23 Nov 2009    Post subject: About to give up on 550 Reply with quote
I have posted on here previously about my 77 cb550k. It went into storage not running. I have replaces the plugs and gone through the carbs. The battery is charged and still nothing The compression is all good on each cyl. Not sure what else to do. Any ideas?
When I took apart the carbs two were full of fuel and two were empty. THe carbs were soaked in cleaner and I thought that would do it, I also blew compressed air through all the jets/ports and they were clear.
27cows
PostPosted: 20:03 - 23 Nov 2009    Post subject: Reply with quote
Presumably it's sparking OK. The first thing I check for in cases of mysterious non-starting for no obvious reason is the fuel cap breather.
virus
PostPosted: 20:04 - 23 Nov 2009    Post subject: Reply with quote
take the carbs off and turn it over with plugs in and leads attached, squirt a little bit of neat petrol down each cyl seperatley and see if theres a pop/bang from all 4.
If only 2 or none go bang then youve not got the ignition system sorted out.
John
p.s. keep a fire extinguisher handy
own: 81 xs1100g...
PostPosted: 22:37 - 23 Nov 2009    Post subject: Reply with quote
On the assumption that it's a points ignition one, have you files, gapped and set the points? If it's been sat for a while, there is a good chance they are coated in a varnish-like deposit that does not conduct electricity.
You can clean the contact surfaces with either a proper points file or by trapping a small piece of emery paper in them then pulling it out a few times (each way up). Follow that with a squirt of electrical contact cleaner.
Also, no fuel in two carbs, it's not going to run until you sort that out. Has to be between the fuel tap and the needle valve, there's not much to check.
The last post was made 16 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 39.77 Kb
