Suzuki GP100 restoration
shadowbiker
PostPosted: 18:52 - 25 Nov 2009    Post subject: Suzuki GP100 restoration Reply with quote
Ive recently acciered a suzuki gp100 with no v5 docs no history the frame numbers and keys are there, Its also HPI clear so ive sent off for the v5 document.
But needing some ideas on the restore as its been sat in a garden for years.
I belive its a 1972 model ive had a good look around the bike and have a small list of things i need to fix/get
seat, chain, brakes, spark plug, and a service ( to get it running )
new loom , side pannels, fork seals , battery and thats it i think
im thinking about ratting it ( as dunc told me too ) Laughing
anyone have any tips on how to go about the tasks any help on anything else that i should be aware of ?
heres some photos
https://i391.photobucket.com/albums/oo360/tonymini145/SP_A0410.jpg
https://i391.photobucket.com/albums/oo360/tonymini145/SP_A0411.jpg
https://i391.photobucket.com/albums/oo360/tonymini145/SP_A0412.jpg
https://i391.photobucket.com/albums/oo360/tonymini145/SP_A0413.jpg
https://i391.photobucket.com/albums/oo360/tonymini145/SP_A0414.jpg
https://i391.photobucket.com/albums/oo360/tonymini145/SP_A0415.jpg
27cows
PostPosted: 20:10 - 25 Nov 2009    Post subject: Reply with quote
That model has points, as I recall, so be careful. Loads of people holed the pistons of GP100s and 125s.
That'll be a 1982 model, not 72 Wink I take it that was a typo.
Pretty good bikes, those that haven't rusted away. My mate tuned the buggery out of one and had it doing an indicated 90. I rode it once and it felt like it was doing about 200, but was probably nearer a real 80 Cool
shadowbiker
PostPosted: 23:19 - 25 Nov 2009    Post subject: Reply with quote
thats what i like to hear shame the bugger wont start ( found out the barrel was kaput so ive rigged the wires and obv rigged around a battery but no start and no bump its got fuel and strong spark and loads on compresion
Billing
PostPosted: 00:53 - 26 Nov 2009    Post subject: Reply with quote
are you sure the fuel is getting to the cylinder? no blocked jets or sticky float? sometimes spark plugs fail, my TZR is an arse for killing plugs, they spark, but arent strong enough to ignite the fuel in the cylinder. for £3 its worth a shot.
replace the plug, try starting it, then take the plug out and see if its oily/wet. if not check the carb is clean Smile make sure the air filter isnt blocked, itll run rich if it is
£14 for a new ignition barrel
https://cgi.ebay.co.uk/SUZUKI-GP100-GP-100-IGNITION-SWITCH-NEW-737548_W0QQitemZ400012872868QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item5d22a00ca4
shadowbiker
PostPosted: 01:14 - 26 Nov 2009    Post subject: Reply with quote
the user RDBIKES on her helped me get it running over msn tok him 10mins lol bit of fuel into the barrel and on kick bang second ringdingdingdingdingringding lol
cheers for your help
now next job is to GUT IT !
PostPosted: 02:29 - 26 Nov 2009    Post subject: Reply with quote
What do you mean you need new brakes? do you mean shoes?
shadowbiker
PostPosted: 12:29 - 26 Nov 2009    Post subject: Reply with quote
nope half the rear brake system is siezed, the front brake barely works Laughing
27cows
PostPosted: 20:00 - 26 Nov 2009    Post subject: Reply with quote
Nothing a bit of grease and sandpaper wouldn't sort out (in the right order LOL).
shadowbiker
PostPosted: 00:21 - 27 Nov 2009    Post subject: Reply with quote
lol now where does the2 stroke bottle go ?
Billing
PostPosted: 00:55 - 27 Nov 2009    Post subject: Reply with quote
usually its under the seat, looks like yours may have been removed and made to run premix.
have a gander on ebay, should be a 2t tank on there, aswell as an airbox which also appears to be missing
shadowbiker
PostPosted: 01:08 - 27 Nov 2009    Post subject: Reply with quote
got it all mate in a box i just have no idea were the 2t bottle mounts Laughing
Billing
PostPosted: 01:31 - 27 Nov 2009    Post subject: Reply with quote
if you have the airbox, mount that first, if nothing it'll help with the running of the bike, because it won't be running lean. It also gives you less space where the 2t tank can fit, thereby narrowing your choice of positioning Wink
27cows
PostPosted: 06:55 - 27 Nov 2009    Post subject: Reply with quote
Think the oil bottle goes under the left panel.
shadowbiker
PostPosted: 01:14 - 28 Nov 2009    Post subject: Reply with quote
seems to be a perrrrfect fit brownie points awarded Very Happy
shadowbiker
PostPosted: 00:47 - 06 Dec 2009    Post subject: Reply with quote
Now got the reg docs in my name, so now i can really gut it
defo needs a new loom
good service and rebuild with a 180cc kit and 34mm carb and spoketed
ignition barrel
lick of paint
a good clean
deseize brakes
MOT and Tax
then insurance
hows that sound ? anything im missing/should be checking ?
Billing
PostPosted: 01:22 - 06 Dec 2009    Post subject: Reply with quote
i assume you haven't got your licence yet? so for a start you'll be riding WAY outside your legal limit. my second concer is that the bore kit you speak of is nearly twice the size of the original, this in itself encounters 2 major problems from the off
1) the bottom end is designed to take 100cc, maybe a bit over to be on the safe side. nearly doubling the capacity of the engine will probably kill it in no time (if it can be done, which brings me to problem 2)
2) even boring the cylinder to the max it'll never get to almost twice the diameter. maybe a few mil to gain a little bit more capacity. so by this logic, you'll need to get the stroke changed, which i think is achieved by altering the crankshaft throw, meaning you may need to alter the crank cases to accomodate this.
from what I've gathered the standard size piston is 50mm, which means you will need to bore it roughly 40mm if your only going to bore it Shocked
but apart from this your plan is solid Thumbs Up
shadowbiker
PostPosted: 02:24 - 06 Dec 2009    Post subject: Reply with quote
when i say bore out i mean bigger barrel and piston kit not bore out original barrel and yes i do know about the 100cc gearbox mate. But my ts50 has run very well for 20,000 with a 80cc kit on it, only down size is i seized it the otherday Laughing but mended that quickly. but thanks for the concern in the boring out
and about the licence Embarassed i failed mod 1 Laughing but retake is soon Smile only failed it on some of my habits thats all
hmmmnz
PostPosted: 09:51 - 06 Dec 2009    Post subject: Reply with quote
your dreaming if you think you could get a 180cc kit for that bike,
that would be a 68mm bore, 18mm bigger than standard
your bottom end doesnt have the displacement to be able to shift the amount of fuel around required to get the bike running,
you could use a gp125 barrel and piston, as its the same stroke as the 100,
being a rotary valve, the potential for tuning is great,
all the gp 2 strokes used the system,
i currently own 3 rotary valve bikes, and out of a 125 with the right port timings and cut out on the rotary valve you could get 25-30 hp
with the standard port timing, and just mucking around with the rotary valve you could get 20hp with out too much trouble,
do some reading on rotary valves before you do anything,
i have a good bridgestone race manual that has some good tips in it (bridgestone (the tyre guys) used to make rotary valve bikes in the 70's and won loads of races)
the humans are dead
I kick arse for the lord
stevo as b4
PostPosted: 23:07 - 06 Dec 2009    Post subject: Reply with quote
Yeah it does seem that some rotary valved bikes seem to be very tunable and make alot of power. I once heard of and saw a dyno chart for a Kawasaki AR125 that was making 30bhp at the rear wheel at only about 10.2k rpm. Apparently the rotary plus reed valve induction system made it really tractable too, and it would pull really well from about 7500-11000rpm.
Would love a 30bhp+ AR125! Laughing
hmmmnz
PostPosted: 01:20 - 07 Dec 2009    Post subject: Reply with quote
the standard kawasaki kx125a1 from 1972 (father to the ar and kh bikes) produced 25hp at 9000rpm they were getting well into the mid 30's on the race models
the bridgestones 100 was getting almost 20hp in the late 60's on lightly modified bikes
add water cooling and you can get a pant load,
its not unheard of for the race rotary valve 125 bikes to be getting 50hp
the humans are dead
smegballs
PostPosted: 18:14 - 07 Dec 2009    Post subject: Reply with quote
What is the advantage of rotary over reeds?
Personally I like the rotary's better but seeing as reeds can give a whole 360 degrees of inlet timing surely its hard to beat that?
hmmmnz
PostPosted: 19:52 - 07 Dec 2009    Post subject: Reply with quote
the advantage is that you can completly control the inlet, reeds are reliant on the piston and can't be closed early or opened late,
it gives you a degree of tuning that you don't get from a piston port or reed valve engine,
and with a decent port map, you can get some great results,
the only down side is that you have a bulky carb bolted to the side of your crank case, if you have a slide the carb gets it
the humans are dead
smegballs
PostPosted: 08:30 - 08 Dec 2009    Post subject: Reply with quote
Thats because the reeds are still dependant on the pressure differential created by the piston movement right? So a reed is more like piston port with a one way system than a disc valve that is actually tunable for discrete timing.
shadowbiker
PostPosted: 03:08 - 28 Dec 2009    Post subject: Reply with quote
i had compleatly forgot to update this ! Sad
well update
gp100 has had a overhaul everything works
and its now ready for it phase of ratting
The last post was made 16 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 131.44 Kb
