plumbing question. Chrome pipe and speedfit plastic pipe
t121anf
PostPosted: 17:27 - 28 Nov 2009    Post subject: plumbing question. Chrome pipe and speedfit plastic pipe Reply with quote
quick question. Why cant you use speedfit plastic fittings on chrome pipe?
Also is there a way to use chrome with these fittings with out attaching standard copper pipe. thinking along the lines of stripping the chrome off
Thanks in advance...i really need to learn to use copper pipe lol
Raffles
PostPosted: 21:51 - 28 Nov 2009    Post subject: Reply with quote
Chromium plating is too hard for the stainless steel teeth in the fitting to grip. If you must connect these items to each other then you will need to remove the chromium plating from the copper pipe. This is not an easy task to perform. By the time you've finished you'll wish that you'd learned how to use a blowtorch!
The last post was made 16 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 31.32 Kb
