Soon to be 30 new biker advice
SuperT3d
PostPosted: 12:58 - 29 Nov 2009    Post subject: Soon to be 30 new biker advice Reply with quote
Hi All
Wil start of with a bit of background information that i hope will help. I did read the stickies in this forum but am still somewhat confused Smile
Im turning 30 next June and decided i want to get my Bike Licence, i have not ridden since i was 16/17 and that was on a Yamaha DT50. I 'passed' my CBT first time and had the bike for a good 18 months which i only gave up because i was fed up getting went and i wanted a car. I am now in the position where i can afford both a Car and a Bike so thats my goal.
Upon thinking about it i dont want nor can i afford to go straight for the DAS and get a 1300cc bike, it's just not for me and i dont trust myself. So i want to get the license i need (help!) and ride maybe a 125 or a 250 for a while to get more experiance and confident before i go bigger.
I passed my car test 5 months after my 17th in 1998 so if i read right i dont *have* to take the CBT but it is advisable im sure. Am i right in thinking i should take my A2 license and ride a 125 or a 250 for a while and then just wait out the 2 years and i will then have the full license?
I think this will be best depending on the cost difference between that and the DAS, if its a lot it makes sense, if not maybe it does make sense to spend a little more and go for the DAS even though i have no plans to get a big cc bike for at least a year or more!
Thanks for your help in advance.
S.
PostPosted: 13:22 - 29 Nov 2009    Post subject: Reply with quote
Hello, a CBT lasts for 2 years, ditto the theory and modules.
So you'll be doing your CBT-theory then mods.
It will only be cheaper if you do your test on your own bike.
So go for the DAS.
I did A2 with a similar background to yours. Wish at the time i could've afforded DAS. Not that i'm dissing 33bhp, its perfect for the likes of me (1 step at a time) But i want to do longer trips and a bigger cc bike would help.
Yes after 2yrs your A2 automatically becomes a full licence.
Take your time and try and enjoy the whole process.
Sage advice from other BCF members will follow.
Pat
ClaireBear
PostPosted: 14:00 - 29 Nov 2009    Post subject: Reply with quote
Hello and welcome to the forum Smile
Even though I am 21, I decided to go for the A2 licence, basically because it was more achievable to pass for me and so didnt have to worry about the cost of retakes etc lol But also I preferred to go from a small bike to 33bhp and then whatever- bit more of a gentle learning curve. The restriction isnt permanent so it will be like getting a new bike when you take it off Laughing
Even if you do your das theres no reason why you cant ride around on a 125 or 250 to get the experience but it might be worth considering getting a bigger bike and restricting it if you got for the A2 route- that way you can get used to the weight of the bike which is actually the biggest 'worry' I have got. You get used to the power in no time but the weight and size is somewhat different Laughing
Anyway, good luck with whatever you decide Thumbs Up Smile
daemonoid
PostPosted: 15:08 - 29 Nov 2009    Post subject: Reply with quote
CBT is still necessary afaik.
I was in a very similar situation to you - I passed my A2 a little over a year ago when I was nearly 29 I went for the A2 for pretty much the same reasons as you. I'm still happy on the license, I've not been longing for the extra power. I did my CBT, bought a 125 and spent 6 months on L's before passing. I've now moved on to a 250.
The one thing I would've done differently is to have chosen a different bike... don't get me wrong, my 125 & 250 hyosungs have been great, the problem is expense. I would've got a restricted 2-stroke 125 that I would've lasted me for 2.5 years. On the plus side though I suppose I've got used to riding a large bike (hyos are big for their capacity) and have had the chance to try out faired and un-faired.
Good luck with whichever route you take though...
current: ducati monster 750
deanoet
PostPosted: 16:31 - 29 Nov 2009    Post subject: Reply with quote
Why does everyone assume you have to get a litre + bike after you pass your DAS?? Smile
Like has been said, you can do your DAS and then keep using a 125
It depends entirely on what you want the bike for. If it is just for weekends, and stuff like that, and a 125 / 250 will do you fine, then do the A2.
If you want to do the A2, then restrict a 600 down to 33bph, then you had may as well do the DAS, as any money saved will be used to put the restrictors in. Smile
I had 6 months on a CG125, then did my DAS and bought myself a 600cc Hornet. Does everything I want, it will happily sit on the motorway at 80 / 90 all day long, and it will equally scream its head off down country lanes having a bit of fun. Smile
You could, just do the CBT, get yourself a CG125 / other bike of choice, ride it for a year / 18 months getting experience. In the mean time saving up the little extra to do the DAS. Smile
If you pick a bike carefully you probably wont lose much, if any money on a 125 bike over a year or so
waffles
PostPosted: 16:41 - 29 Nov 2009    Post subject: Reply with quote
It is, you can ride something on your license already without doing a CBT but it isn't a 125cc bike. It'll be the smallest scooter known to man. But on the plus side, you will already have a provisional bike license attached to your car license if you got it in 1998 so you can plow straight into training.
The cheaper option that will get you on the road quickly would be to do a CBT and get a 125, that'll cost you between £90 to £120 for the training plus the cost of a bike when you pass.
A2 restricted license will take a tad longer but will get you on a 125 or 250cc that you mentioned in your original post. No idea how much they cost but only lasts two years before allowing you to ride anything unrestricted.
DAS is the most expensive option and can cost up to £900 depending on where you live. Normally takes a week but will let you ride any bike you want.
So it does depend on what you want, how soon you want it and money avaliable. Me personally I have done my CBT and theory and am getting lots of experience on the road before I go for a full license around Easter time.
SuperT3d
PostPosted: 18:17 - 29 Nov 2009    Post subject: Reply with quote
Hey
Thanks for the warm welcome and lots of advice, i do wish however the government would make it a bit clearer.
Reading from what you have all said if i want to ride a 50cc hairdrier i can on my current license just fine (dont want to be doing that, i think it would drive me nuts in a matter of days), however if i want to ride a 125cc on my current license i would have to take CBT?
If i wanted to ride a 250 or whatever is 33 restricted i would need to do the A2 test?
My thinking on the DAS is it will be too expensive at the moment and mean i have less to spend on a bike, i do like the look of the DT125 and at the moment that seems favourite. I have no plans to need it for long trips anywhere, my girlfriend doesnt like them so wont come with me on it so i would use the car for those trips.
I was figuring im going to have maybe £2.5k to £3k tops to spend on the whole package from Test to Helmet and gear to bike.
Generally it will be to and from work (10 miles each way) and some general riding around the local area (~40miles) at weekends if its nice.
S
cvntdude This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
SuperT3d
PostPosted: 18:45 - 29 Nov 2009    Post subject: Reply with quote
Sorry, i have been reading and just wanted to post the path i think i need to take to happily scoot around in a 250cc bike or thereabouts...
CBT > Theory > Hazard Perception Test > A2 Test
I think that right? I am presuming that included in the A2 Test is the Mod 1 and Mod 2 i have been reading about?
Sorry for the silly questions but i have to say im getting quite confused!
S
daemonoid
PostPosted: 19:34 - 29 Nov 2009    Post subject: Reply with quote
Spot on, although the theory & hazard perception happen are one test unless something's changed in the past year or so.
I did CBT > 125 scooting around > Theory/hazard > A2 > 250 (<33bhp)
If you do plan on getting the dt to cover both parts of riding then be aware it only kicks out ~22bhp deresticted.
SuperT3d
PostPosted: 19:51 - 29 Nov 2009    Post subject: Reply with quote
[quote="daemonoid"]
I presume by ur comment i would need to rent a bike for the later parts of the A2 test or will the DT be OK for it?
daemonoid
PostPosted: 00:42 - 30 Nov 2009    Post subject: Reply with quote
A dt would be fine for the A2 test. I meant after the test you can de-restrict a 2 stroke 125 to have close to 33bhp if you pick the right one. It's what I would've done with hindsight.
That means you can buy 1 bike to practice before the test then de-restrict it and serve your 2 years on A2 before buying your next bike.
The problem with a dt is it only de-restricts to 22bhp rather than say an nsr which de-restricts to 30bhp. However, I'm guessing you don't like the look of an nsr? Someone else will likely be able to suggest a 2 stroke trials type 125 that can de-restrict nicely.
SuperT3d
PostPosted: 07:08 - 30 Nov 2009    Post subject: Reply with quote
Ah right, i know what you mean now! Was being a bit slow Smile
Decided im going to get my CBT for Christmas hopefully to take in January and then go from there. Get used to the 125 for a bit and take the A2 test closer to by birthday.
That should give me 3 or 4 months riding around getting a bit more confidence.
If anyone can suggest a 125 that can be tweaked to 33bhp that is one of the trials style bikes that would be awesome!
S
bacon
PostPosted: 13:57 - 30 Nov 2009    Post subject: Reply with quote
do the das, dont restrict yourself for 2 years...
you can find cheap big bikes, and with a das you wont need to worry about restrictors. For the sake of saving £150 on the training course etc its not worth 2 years of potential hassle when you want more performance but are stuck to 33hp for the 2 years....
you can pick up 600 sports bikes for £1k-1.5k ish if you look on ebay atm (to show you big bikes are cheap enough not to make you want an A2) then say £700 for cbt, theory, das (give or take £ depending on location)
that leaves plenty of cash for gear, and no hassle from restriction if you know what i mean.
Of course you could buy a 125 if that was what you wanted, do your cbt, then ride the 125 for a few months, then flog it and do the das, and get a big bike
so yeh...do das Mr. Green
Ingah
PostPosted: 15:14 - 30 Nov 2009    Post subject: Reply with quote
I think all the previous posters have covered all the main points - although it's hard to get my head around despite the fact i even know the stuff already!
One additional point to note is that big bikes can be very cheap (you don't have to buy a sports 600!) - especially the 500cc commuter bikes (GS500, ER-5, and the less cheap, but better CB500) - they generally knock out 50+BHP and restrict very well if necessary (they look nothing like that there DT125 though, so may or may not suit you). You can pick up old ones for not too much more than 500/600 notes! (and insurance would be a pittance on them too as insurers regard them as 'safe' bikes).
You will grow out of them though, just like i expect you'll grow out of the DT125.
-- Ingah
SuperT3d
PostPosted: 17:03 - 30 Nov 2009    Post subject: Reply with quote
Thanks again for the reponse, i need to not be tempted into going for the DAS!
I do want it and you put across a good argument, but in all honesty i dont trust myself. I like to think i have grown up but im sure if i was riding a big bike i would act all stupid again and more than likley end up in trouble or wrapped round a tree!
My way of only being able to ride a smaller ish bike until i get more wise and sensible is kind of a safeguard.
Like you say though if i get bored after a year (likley) i can always do the accelerated to get a bigger bike so that option is always there i guess.
Ive swung the girlfriend and parents to a 125cc or maybe 250 so i might leave that for a bit and then if i change my mine try for bigger, tough call though!
PostPosted: 23:17 - 30 Nov 2009    Post subject: Reply with quote
Ok so you don't trust yerself, what makes you think a 250 or 33bhp won't lead you astray. They'll get to 30+ as fast as most modern cars. They'll do 80-100 which is plenty fast enough to get into trouble in corners...see what i'm saying..you'll have to learn self control, otherwise your biking career will be short and expensive.
Pat
daemonoid
PostPosted: 00:35 - 01 Dec 2009    Post subject: Reply with quote
I'm completely with ted on this one - I did my A2 for the exact same reasons he did. I think I'm a better biker for it - I'm learning to wring all the power I can out of my bike, I've learnt to corner better than I would've on a 600, plus, given my propensity for breaking myself, I've had a fairly safe 18 months...
And this time next year when I'm on my duc 695 I think I'll still recommend the A2 route to everyone, especially when us born again bikers are the second biggest risk group on the road!
bacon
PostPosted: 01:07 - 01 Dec 2009    Post subject: Reply with quote
maybe but nothing is stopping you buying a less powerful bike, just if after a year you fancy something over 33hp you dont have to ride illegally, or spend more money to do teh accelerated access and the test all over again
SuperT3d
PostPosted: 07:10 - 01 Dec 2009    Post subject: Reply with quote
Imo doing the DAS upfront would be preferable, but the cost is rather high!
Doing it the way i think i will means i can spread whatever cost it might be over a year or whatever. Doing the A2 restricted now and then if (when) i get bored with smaller engine bikes and i can afford to get a bigger one and do the i can just pay for the Accelerated.
Ok, in the long run the CBT, Restricted and then Unrestricted might cost more than doing the DAS straight away but its not an upfront one of cost, gives time to save some cash and improve my biking skills first.
The idea of going from 50/125 to 500 for the DAS test in a week is to me a little bit scary. Maybe im being to cautious, but thats my feeling considering i havent ridden for coming up to 13 years.
SuperT3d
PostPosted: 17:32 - 01 Dec 2009    Post subject: Reply with quote
cvntdude wrote:
Yes you are being to carefull, which is fine, but if you do the mod 1 and 2 in your time and cost frame and then buy a restricted bike, then thats the way to go IMO ...
This is what has changed i think, Initially want to go for a DT125 which as has been said i'll get bored and want a bigger bike so id have to sell that (lose a fortune) and buy another bigger bike...
As you say buying a bigger bike that is or getting it restricted saves money in the long term and the bike would last longer. Makes perfect sense now you have all told me several times (im slow!)
Now to find a bike i like and can be restricted. I do like the look of the KTM690, at first glance but i need to do a lot more reading i think!
Thanks again
S
The last post was made 16 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.24 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 139.14 Kb
