| Itchy |
 Itchy Super Spammer
 Posted: 13:36 - 01 Dec 2009 Post subject: Car oil change, |
I want to change the oil on a car, easy enough, the issue is that the car is rather low about 9 inches, no way I'd be able to squeeze under that.
I also most definately do not want to use a car jack on the said car as I've had bikes fall off jacks and a 150 kilo bike is dangerous enough never mind a 2 ton car which would probably kill me. Though I have thought of putting tyres and wooden blocks in the space that the jack creates so if it does fall off the jack it will harmlessly be wedged up by the wooden blocks, though it still feels dodgy to me.
Ontop of this I don't want to be spending £50 on some stands or ramps which will be used once.
My only thought is to drive the car to somewhere with a high kerb and park with the passenger side wheels on the kerb and the other wheels on the road giving me some decent access. However I'm not sure the cops would like this very much.
BCF what are your solutions to this?
Thanks. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:53 - 01 Dec 2009 Post subject: |
I have used the curb like that (but for changing an exhaust father than oil). Trouble with changing oil like that is that the old oil will go to one side of the sump, leaving a fair amount in there when you drain it.
However 9" is a fair amount of space to change the oil. It is more space than we have under the Maserati (about 6" clearance) when it is over the pit with boards on it (gives another couple of inches between the garage floor and the board covering the pit), which is what I tend to use to change the oil. You should easily be able to slide a washing up bowl under the sump if it is that high, and have space to undo the sump plug. No real need to crawl fully under the car.
If you need a bit more clearance then get a couple of small planks of wood and drive the front wheels onto those.
| G |
 G The Voice of Reason
| stinkwheel |
| Mark65 |
 Mark65 World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 16:58 - 01 Dec 2009 Post subject: |
I would get something solid under either the wheels or part of the frame that will take the weight.
Or just jack up enough that lifts it, but leaves the wheels on the ground.
Failing that take a trip to a garage that does cheap oil and filter changes.. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 20:44 - 01 Dec 2009 Post subject: |
If you havn`t got the tools pay someone else to do it,
I knew 2 people who died trapped under their vehicles.
one was andy smith who worked for paddys patches.
The second I only knew as H, he was trapped under his lorry for an estimated three days, before he was found.
If you aint got the tools don`t do the job ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
| unitybiker |
 unitybiker Nova Slayer
| kingsmith |
 kingsmith Scooby Slapper
 Posted: 23:21 - 01 Dec 2009 Post subject: |
just go buy yourself an oil draining tub..very shallow in hight so easy slid under your car.
no need to fuck around jacking your car up and having old oil stayin your engine cause its not flat, well the car..
 ____________________ honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy |
| Mark65 |
| ZRX61 |
 ZRX61 Victor Meldrew
| paddlesat16 |
 paddlesat16 Crazy Courier
| Itchy |
 Itchy Super Spammer
| LeeR |
 LeeR World Chat Champion
 Posted: 12:39 - 03 Dec 2009 Post subject: |
I faced exactly the same problem with my wife's latest car, it has a huge plastic panel obscuring the engine, and too little clearance to remove it even with the use of trolley jack + axles stands, or ramps all of which I possess.
As I don't have an inspection pit I gave up, and took the car to a man that does. ____________________ My claim to fame: Austin Vince nicked my pen... |
The last post was made 16 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
