New type of engine?
Bike Chat Forums Index -> Biking News & Rumours
Fahd
PostPosted: 18:55 - 01 Dec 2009    Post subject: New type of engine? Reply with quote
Interestingly uses two-stroke technology rather than 4-stroke and is capable of meeting much stricter emissions than old 2-strokes (or even 4-strokes):
(Scroll down the page for moving diagrams of the engine at work).
https://www.autoblog.com/2009/11/30/autoline-on-autoblog-with-john-mcelroy/#continued
Thoughts?
I Ride: Honda CBR 400RR.
I Drive: Audi S3.
Itchy
PostPosted: 19:06 - 01 Dec 2009    Post subject: Reply with quote
Quite clever, though I do like the 6 stroke engine a bit more (as it is less of an evolutionary leap).
I wonder how you would cram it into the chassis of a bike though, as those BMWs are already pretty damned wide to start with and thats just an opposed flat twi, BMW man on his R1150GS tried hard one day following me on me CBR and the cylinder head touched down. I suppose you could have a + shaped four or would that be an 8? Confused
PostPosted: 19:43 - 01 Dec 2009    Post subject: Reply with quote
Not sure I see any advantages. More moving parts.
However also can't see why it has to be an opposed twin. Looks like it could be built as a single. Just that it looks like it would result in a hideously long crank for a single or parallel twin.
PostPosted: 19:46 - 01 Dec 2009    Post subject: Reply with quote
I wonder if it could be made a bit 'easier' by having two cranks, one either end, then your row of cylinders between them.
PostPosted: 22:27 - 01 Dec 2009    Post subject: Reply with quote
Can somebody please explain to me how the fuel and air enters and leaves?
Also, however it works, surely you could remove the normal crank and piston and just have the outer piston and the long conrods, then have a 2 stroke cylinder head (apart from it wouldn't be a head because it would be inside the engine). The only problem I can see with my idea is the scavenge efficiency wouldn't be any better than a normal 2 stroke.
buddy
PostPosted: 09:08 - 28 Dec 2009    Post subject: Reply with quote
its got ports, have another look
i think its a crap idea anyway
1st what makes it more effecient at scavenging?
2nd its much too complicated
3rd it would be really heavy for its size since youve got 2 pistons rods ect for each cylinder
much better off trying to make a fuel injected 2 stroke
When this baby hits 88 miles per hour... you're gonna see some serious shit.
Shreddie
PostPosted: 15:43 - 28 Dec 2009    Post subject: Reply with quote
Longitudinal V perhaps?
More moving parts? Too complicated?
It has fewer moving parts and is more simple than a 16 valve engine... There's no cams or valve train.
spitfire123
PostPosted: 17:41 - 28 Dec 2009    Post subject: Reply with quote
Think of the rebuild costs on that thing Surprised
You won't be able to eat my dust......As it'll settle before you get there.
PostPosted: 21:38 - 28 Dec 2009    Post subject: Reply with quote
So it is an over complicated ported 2 stroke.
pepperami
PostPosted: 22:11 - 18 Jan 2010    Post subject: Reply with quote
buddy wrote:
its got ports, have another look....
did`nt one of the scooter manufactures develop a fuel injected two stroke engine???
PostPosted: 07:38 - 19 Jan 2010    Post subject: Reply with quote
Just because it's fuel injected doesn't stop the fuel flying straight out of the exhaust port like a bit does in a carb fed 2 stroke.
pepperami
PostPosted: 12:10 - 22 Jan 2010    Post subject: Reply with quote
but surely the electronic whizz bang tecnicery of the fuel injector can be more fuel efficient than a carb???
PostPosted: 12:25 - 22 Jan 2010    Post subject: Reply with quote
Not really no. Carbs work very well on bikes. Biggest problem on a 2 stroke is that the exhaust port is open at the same time as the transfer ports so a load of fresh fuel and air goes straight out of the exhaust. Compared to this any small saving from injecting the fuel in slightly more precise amounts is tiny (and for most greatly outweighed by the far higher cost of a fuel injection system).
The last post was made 16 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Biking News & Rumours All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 80.75 Kb
