| jasepugh1984 |
 jasepugh1984 Renault 5 Driver
| element |
 element World Chat Champion
 Posted: 16:41 - 29 Nov 2009 Post subject: |
no power/lack of compression - rebuild
rattly top end (worn small end bearing)/piston slap - rebuild
should be changing the rings on a rs every 10k miles max or something like that.. check workshop manual..
you can hear/feel when a 2t needs a topend rebuild.. bottom end you dont need to touch until the main bearings start to go unless the crank goes before.. ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| jasepugh1984 |
| spitfire123 |
 spitfire123 Could Be A Chat Bot
| jasepugh1984 |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 22:20 - 01 Dec 2009 Post subject: |
get a set of rings and change them,
check the top and bottom ends for up and down play, while you are changing the rings,
clean out the power valves and remove all the carbon build up on the piston,
as said its a couple of hours of easy going,
or about 20mins if you know what your doing ____________________ the humans are dead
I kick arse for the lord
| hmmmnz |
| ram_doom |
 ram_doom World Chat Champion
| hmmmnz |
| Oz. |
 Oz. Spanner Monkey
The last post was made 16 years, 315 days ago. Instead of replying here, would creating a new thread be more useful? |
