4 Stroke Top end rebuild
smegballs
PostPosted: 11:36 - 03 Dec 2009    Post subject: 4 Stroke Top end rebuild Reply with quote
My mate has a superdream that is burning oil, not too much but it is noticeable - especially up hills. We were perhaps thinking of giving it a bit of TLC but not too much as it is old and pretty wanked.
We was thinking of having the head off and cleaning it up, lapping in the valves, new valve stem seals, and a hone and re-ring.
I've done valves before so I know whats going on there but I'm not sure whats the deal with the bore. If its gets measured and the pistons/bore is wanked then will a hone and re-ring make much difference? Or would it definately need a rebore? The bike is pretty old as it is so its not worth spending the money on rebores and pistons, but 40 quid of rings and seals might make it a bit better (and its something to do over xmas break).
Is it worth bothering with or will it just open a nice big can of worms?
hmmmnz
PostPosted: 12:06 - 03 Dec 2009    Post subject: Reply with quote
well if you don't mind taking the head off to do the valve seats ect,
then you may as well do the rings, they wear quicker than the barrel... usually Very Happy
the humans are dead
I kick arse for the lord
smegballs
PostPosted: 12:18 - 03 Dec 2009    Post subject: Reply with quote
Yeah I know on lots of four strokes just re-ringing gives a nice compression boost on a tired engine.
Only thing I'm wary of is it being taken apart and then not functioning once its all back together. I think I'll comp test it to get an idea wether its valves or rings that are leaking.
unitybiker
PostPosted: 22:26 - 03 Dec 2009    Post subject: Reply with quote
if the compression test says knacked then just put some molyslip or slick 50 in it and thrash it till it starts smoking .
or , if you are going through all that trouble on the head then why not bung a couple of new pistons in it as well ,
it's not my money and time being spent but for a few dollars more?
smegballs
PostPosted: 23:11 - 03 Dec 2009    Post subject: Reply with quote
Well I've priced up a set of rings for about a tenner each and piston kits are like 40 each.
So while 20 quid on rings isnt that bad, 80 quid with new pistons is 4 times as much and probably more than its worth. Certainly more than my mate will want to spend.
unitybiker
PostPosted: 21:41 - 04 Dec 2009    Post subject: Reply with quote
yup you 're right u could get a sechand engine for that ,If it;s a nice bike it can be worth cleaning and spraying engine and doing a bit of nimor paint work on the inaccessable bits of the frame
.Chris.
PostPosted: 23:03 - 04 Dec 2009    Post subject: Reply with quote
Depends what the bores are like (which obviously you're not going to know until you take the head off). If the bores are badly worn then putting new rings on might work in the short term but probably won't last very long, so you may as well go for a rebore and new pistons. If the bores are OK then new rings would be fine.
A secondhand engine is an option, but a bit of a gamble - it could be equally as knackered or have other issues.
Chris
1985 Kawasaki Z550F
The last post was made 16 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 56.24 Kb
