| Si1000 |
 Si1000 Two Stroke Sniffer
| unitybiker |
 unitybiker Nova Slayer
| Handsome |
 Handsome World Chat Champion
| Si1000 |
 Posted: 01:10 - 03 Dec 2009 Post subject: IT 175 - got spark, wont fire. |
Ok guys - thanks for hints.
I've got 2 new plugs bought today. Both are sparking very well, ie I can open the gap to 1.5mm and still get a spark to jump. I even bought a iridium plug to see if that would help. Set plugs back to.8mm. So i think i can rule out, lead, coils etc as spark is solid and blue.
I pulled carb and re adjusted float level - but at this point it's not really a factor as I simply cannot get it too fire at all, let alone run.
I've pulled the reed / intake plate today and checked over everything - but again, this would effect running, rather than getting the bike to fire - wouldn't it ?
I'm really stumped - the timing marks are in alignment on the flywheel as well...
Question - When i had all of the intake apart, i sprayed some ether down the ports. Now i would of thought that id still get some sought of "fire" without any intake in place, - not to get it running - but to at least "fire" - anyone know if this is accurate ??
I then tired some fuel down the plug hole - and again, i couldn't get it to go close to firing - something is seriously wrong and it's likely to be somthin stupid...but i'm out of ideas ??
Cheers Si. |
| smegballs |
 smegballs World Chat Champion
| unitybiker |
| Si1000 |
| Handsome |
 Posted: 08:48 - 03 Dec 2009 Post subject: |
Two things to try off the top of my head...
Snip a little off the end of the ht lead if you have enough just to get to fresh wire and try that...
If that doesn't work try replacing the coil/lead as while it may fire when you've got the lead bent to reach the frame the wire inside may have a break in it, if you see what I mean...
I've also had those issues in the past and if I remember right I got the new coil with about two feet of lead from Busters Accessories, around a tenner I think it was...  ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
| unitybiker |
| Si1000 |
| 27cows |
 27cows World Chat Champion
| Handsome |
 Posted: 21:15 - 23 Dec 2009 Post subject: |
At least you've found the cause...  ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
