bike wont start
guest
Guest
PostPosted: 13:57 - 24 Jul 2002    Post subject: bike wont start Reply with quote
Hi all,
My nsr 125 wont start.... the starter relay clicks but nothing else.
It will jump start quite easily but even after a long run still nothing.
The battery seems fine...lights are ok (charged it up to be sure).
Also this happened with no warning... the bike was starting first time and then silence.
Any suggestions.
Thanks for any advice
Doddmaster
PostPosted: 13:59 - 24 Jul 2002    Post subject: Reply with quote
I'm having the same problem mate.
I just fitted a new spark plug and it starts perfectly but it feels weird, like its misfiring or something
U might wanna try that though, I got mine from Halfords
Demonic69
The Pink Rhino
PostPosted: 14:13 - 24 Jul 2002    Post subject: Reply with quote
Dodd, did you get the gap right in the sparky?
Back on a Blade. Just feels so right.
PostPosted: 14:48 - 24 Jul 2002    Post subject: Re: bike wont start Reply with quote
It could be a problem with the starter motor... have you got an alarm fitted? I had a very similar problem on my zx6 with a Datatool Evo alarm. The alarm fuse had blown, it still worked but stopped the starter motor from going (just a relay click) so I had to bump start it.
McJamweasel
BCF Junkie
PostPosted: 15:00 - 24 Jul 2002    Post subject: Reply with quote
Does the starter turn over?
If not then the problem lies there. Check the wires, it may be a loose connection.
Guest
PostPosted: 15:17 - 24 Jul 2002    Post subject: Reply with quote
I have an alarm fitted and it still works... i checked the fuses yesterday and all seemed ok.
The starter does turn over at all... only a click from relay.
Will check the wiring tonight.
Guest
PostPosted: 15:22 - 24 Jul 2002    Post subject: Reply with quote
meant to say starter does not turn over
PostPosted: 15:49 - 24 Jul 2002    Post subject: Reply with quote
Did you check the *alarm* fuse... this is usually to some degree hidden, it definatley won't be with the others.... it had me fooled for quite a while as everything else (including the alarm) seemed okay.
I'm not say it *is* this, but it's quite possible.
TiN
Pocket Tin
PostPosted: 16:36 - 24 Jul 2002    Post subject: Reply with quote
I had that kind of problem on my bike...
...my lights worked, but the starter would only click, and not "churn"...
I attributed this to the battery, and/or the fact that my fuel tap was off! (D'oh!)
...I basically charged it up (using Optimate jobby), and made sure the fuel tap was on...
It works very sweetly now.
TiN
dotgems.net
zaknafien
PostPosted: 18:53 - 24 Jul 2002    Post subject: Reply with quote
same problem on mine, starter was knackered.....
02 Firestorm.
Doddmaster
PostPosted: 21:26 - 24 Jul 2002    Post subject: Reply with quote
Hmm
I got the spark plug sorted, and seemed to be starting fine earlier. When I just went to leave the bike meet tonight, it wouldn't start Embarassed sooo embarrasing
So could it be the starter motor? How can you determine if it is the starter motor?
Cheers muchly,
Dodd
zaknafien
PostPosted: 21:33 - 24 Jul 2002    Post subject: Reply with quote
no idea m8, i took mine to a garage,
and my bike likes not starting when im around people, when im alone it starts first time everytime but whenever someones near (usually just as im leaving my local mechanics) it refuses to start for me, im sure it likes me being embarrassed........
02 Firestorm.
Demonic69
The Pink Rhino
PostPosted: 08:23 - 25 Jul 2002    Post subject: Reply with quote
Mine's a kicker so no probs there:)
Ropehead
PostPosted: 10:02 - 25 Jul 2002    Post subject: Reply with quote
ALL Bikes should have a Kick start like mine Very Happy
Never had a problem with IT Cool
McJamweasel
BCF Junkie
PostPosted: 12:01 - 25 Jul 2002    Post subject: Reply with quote
You try and kick a hayabusa up then!!!!
Demonic69
The Pink Rhino
PostPosted: 12:03 - 25 Jul 2002    Post subject: Reply with quote
Easy! It's only the starter motor you have to turn, not the bloody engine!! Wink
Ropehead
PostPosted: 12:19 - 25 Jul 2002    Post subject: Reply with quote
if its a HUGE engine they fit a VALE LEAVER that opens the valves (no presure) so u can kick it over!!
then u just let go and off she goes.
Would work on a busa witha long ish kick Laughing
PostPosted: 12:47 - 25 Jul 2002    Post subject: Reply with quote
I used to have to *bump* start my klr650... very, very nasty, the zx6 is a whole laod easier, so I'd expect a High-abuser wouldn't be *completley* ridiculous (you've only got to start one 325cc cylinder and the rest should get going).
Robby
Dirty Old Man
PostPosted: 16:48 - 25 Jul 2002    Post subject: Reply with quote
mine quite a heavy kick, and thats only a 250. starts first or second kick every time tho.
PostPosted: 19:30 - 25 Jul 2002    Post subject: Reply with quote
Dodds
If the bike turns over but just doesnt fire then the starter is almost certainly OK. In which case check the plug, plug gap, choke, fuel, etc. As your bike has just been run in and had bimbled round at low speed for a while you probably did the right thing replacing the plug (make sure you get the right grade of plug). Probably worth changing the oil now as well (now it is run in)
Doddmaster
PostPosted: 21:52 - 25 Jul 2002    Post subject: Reply with quote
Cheers Keith mate
the mechanic told me that the gap in the spark plug would be fine, though he didn't measure it.
He also gave me a different plug, he said the one I bought had a resistor in so he gave me a better one... maybe this plug doesn't match up?
Cheers,
Dodd
PostPosted: 22:00 - 26 Jul 2002    Post subject: Reply with quote
The resistor is mainly there to match up with the ignition system, and prevent radio interferance to everything around you. The important bit is the number. With NGK plugs this goes up, with the higher number being cooler plugs for hotter running engines (the cooler plugs transmit more heat out of the cumbustion chamber). At a guess yours should be a 7 or an 8 (that is a guess). Use too cool a plug and you will land up with the bike fouling the plug round town, too hot a plug and it will blister and fail
The last post was made 23 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 109.37 Kb
