Starter Motor going... backwards?
xXshadowXx
PostPosted: 20:21 - 05 Dec 2009    Post subject: Starter Motor going... backwards? Reply with quote
Yeah, the starter motor turns the wrong way. I rotate the really big sprocket on the crankshaft of my 83 GSX250 and in one direction it spins free and the other it turns the crank. Yet my starter motor has managed to start spinning it the wrong way.
How the heck does that happen?
The chassis being a common ground and the starter only having one lead that can be connected to the relay, I sure as hell haven't wired it up wrong.
unitybiker
PostPosted: 22:22 - 05 Dec 2009    Post subject: Reply with quote
you may have reasembled the startermotor brushes assembly 180 degrees out , or the case that holds the plate
smegballs
PostPosted: 08:10 - 06 Dec 2009    Post subject: Reply with quote
Yeah I'd check your connection polarity to double check!
Seeing as its is a DC motor if the polarity is reversed so will be the direction of motion. Left hand rule and all that....
The last post was made 16 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 34.81 Kb
