Removing fork legs and rear shock
Noxious89123
PostPosted: 19:47 - 20 Nov 2009    Post subject: Removing fork legs and rear shock Reply with quote
I'm planning to remove the fork legs and the rear shock from my bike, either over this weekend or the next, weather permitting. Rear shock looks like it should be a doddle. Forks don't look to bad either.
Only concern is how I support the front of the bike. I have no paddock stands, and don't plan on buying any. Rear will be supported by the main stand. I was thinking of using a few bricks and a piece of wood under the downpipes to support the front of the bike. Is this a bad idea, or is this how everyone else does it? Any major DOs and DON'Ts? I realise the forks might be seized in the yokes, but I'm confident that with a bit of GT85 they should be persuaded loose without too much trouble.
They're all being taken to K-Tech to be serviced. New oil, seals and possibly bushes. £135 for the forks and £94 for the shock; £229 all in all. I contacted a place called MH Racing and he wanted £150 for either end. So K-Tech get's my cash.
Oh, and just to add; I am going to remove the fairing side panels before I start, but I reckon I'll have enough wiggle room around the yokes without taking off the front of the bike. Not a big deal if I have to take the front off, I’ve done it before, and my mum is good and doing as she’s told and holding things whilst I undo wires and bolts Laughing
BBC Weather forecasts a wet weekend, so might have to postpone this, but no rush, I've got until spring to get it done Smile
[Sneaky edit]
I'm also going to remove all the rear shock linkage and clean it up and regrease all the bearings. Will replace the bearings and dust seals if they are knackered. I think they could do with greasing, as when I bounce on the back, it sometimes squeaks. I've got a tube of brown "lithium multi-purpose grease". Is this ok? Haynes just states "multi-purpose grease".
Itchy
PostPosted: 19:59 - 20 Nov 2009    Post subject: Reply with quote
CBR6? , you can put a rope onto the headstock and throw it over the rafters, this is my prefered technique as there is nothing to knock over or trip over and have the bike fall on you, sometimes if it was just a tyre change it was just somebody leaning on the stand for a bit...
But although it turns out ok most of the time I wouldn't be sticking things under the downpipes, CBR6 pipes are mild steel and will be the same age as mine, before I replaced them with a stainless set poking them hard with a screw driver would hole them.
Noxious89123
PostPosted: 20:11 - 20 Nov 2009    Post subject: Reply with quote
No garage, working outside on the patio.
And my pipes are SS, replaced them last year Wink
serlant
PostPosted: 20:42 - 20 Nov 2009    Post subject: Reply with quote
Didn't have the rear off the ground but i doubt there would have been a problem if i needed too.
https://i191.photobucket.com/albums/z170/serlant/16052009021-1.jpg
PostPosted: 22:50 - 20 Nov 2009    Post subject: Reply with quote
https://i48.photobucket.com/albums/f216/stinkwheel/Image020.jpg
Axle stands under the frame. Car jack under the front of the engine.
Next time, I'd swap the left and right footpegs round so they are on upside down and put the axle stands under the pegs themselves.
Noxious89123
PostPosted: 23:54 - 20 Nov 2009    Post subject: Reply with quote
Lol, bonkers.
Will it be ok taking the weight on the downpipes though? I have a small scissor jack like that, but don't think I'd trust the stability of it to leave my bike on it for a week or more, out in the wind etc. Thinking
Also, interesting use of balast.
PostPosted: 00:08 - 21 Nov 2009    Post subject: Reply with quote
Noxious89123 wrote:
Lol, bonkers.
There is very little weight on the jack, it's just there to balance the bike, all the weight is on the axle stands. I used the jack because it's easy to raise and lower the bike. If I turned it through 90 degrees, I could have put the top of the jack up against the sump.
Another way to do it would be to flip the footpeg over, push the bike over towards the sidestand so the back wheel comes up off the ground and slide a prop stand under the peg. Then do the same with a prop under the front of the engine leaving the bike balanced on the sidestand and two props with both wheels off the ground. I've done that on my KLE500 and it was very stable
Noxious89123
PostPosted: 20:16 - 05 Dec 2009    Post subject: Reply with quote
Had very clear sunny weather today, so got the shock and fork legs off the bike Very Happy
I was expecting it to be a real pain to get the legs out of the yokes, but as soon as they were loosened up, they slid straight out! Mostly went smoothly.
Turns out that if my fuel tank is full and i tilt it forwards then backwards, it pisses fuel out the overflow Rolling Eyes
I was also cleaning up the inside edge of the fork sliders. They were caked in brake dut and greasy crap. "I know!" I thought, I'll use some brake cleaner. Bit on a rag, gave it a wipe, took a load of straight away. Wicked, spray some on there. Wipe. Oh. FUCK.
Turns out that Motul brake cleaner can melt paint. Laughing I gave it one wipe, which took the suface off the paint. I let the rest evap off. The paint seems ok, it just doesn't look shiny in that area anymore. Good thing it was the inner side of the fork slider. Oh well, live and learn. Funny though, it never touches the paint on the brake calipers!
I propped the bike up with some wood. Worked ok, not quite as stable as I'd like. Will get some pictures of the masterpiece when I put the suspension back on.
Also, it would seem that my headrace bearings need replacing, as there is a very definite notch in the centre that it falls into if you turn the yokes lock to lock. What would cause this? Just usual wear and tear? I don't wheelie the bike. (Ok, only tiny ones over crests, but they feel good!). Don't fancy the hassle of doing them myself, as I found changing wheel bearings a right piss-about Mad
Will take the bike into a garage early next summer to get the valve clearances checked, so will get the bearings done at the same time.
EDIT: Just thought of something else; When measuring the gap from the top yoke to the to of the fork leg, what kind of tolerance should I be working to? I have a steel rule that shows 0.5mm steps. But I have been ridiculed for this, and told that I shouldn't be so rediculous as (apparently) it's highly important that you do it with a "proper" measuring tool like a vernier to get it within 0.001mm else it could be dangerous to ride.
Which is funy, because befor removing them, I found one was about 1.25mm higher than the other. The previous owner had changed a fork seal, and measured from the fork cap, not the top of the stanchion. I never noticed anything whilst riding Laughing
Bendy
Mrs Sensible
PostPosted: 20:38 - 05 Dec 2009    Post subject: Reply with quote
I measured it with a pen mark on a screwdriver. Very scientific.
When I took the bike to get the suspension set up I mentioned this to the guy and he said he couldn't have got it any closer. So I think 0.5mm steps will be just fine.
PostPosted: 21:00 - 05 Dec 2009    Post subject: Reply with quote
I measured mine with a tape measure. Never had any handling issues to speak of.
Shreddie
PostPosted: 07:30 - 06 Dec 2009    Post subject: Reply with quote
I never measured mine. I just hoped that the forks had been made to the same length so got everything level at the top and left it at that... Never had a problem though.
Noxious89123
PostPosted: 18:46 - 08 Dec 2009    Post subject: Reply with quote
I have some pitting and tiny pin-head sized rust specks on the stanchions. I've been rubbing them with a cloth and some autoglym metal polish, but it doesn't seem to be doing alot, other than making the surrounding area very clean and shiny...
Any quicker way? I was thinking possibly of using some 1500~2000 grit wet and dry, and then polishing it back to a mirror smooth finish? Or is this just a totally bad idea?
Am I expecting too much too quick? Should I just keep at it with the polish?
Thinking
oJaXo
PostPosted: 21:28 - 08 Dec 2009    Post subject: Reply with quote
only a thought but what about using a bit of wd-40 on a cloth and rubbing it on the rust spots?
worth a go maybe ? Very Happy
cheers
Noxious89123
PostPosted: 21:43 - 08 Dec 2009    Post subject: Reply with quote
Nah, tried rubbing it with loads of GT-85, it won't shift any more than it has already.
It's not so much rust, but little pits and chips in the chrome.
oJaXo
PostPosted: 22:12 - 08 Dec 2009    Post subject: Reply with quote
dont know if its any help ether but thought this could help?
https://bicycletutor.com/rust-removal/
cheers
Noxious89123
PostPosted: 23:51 - 08 Dec 2009    Post subject: Reply with quote
I'm heading to bed now, but I'll see if I can get some pics showing the condition of the chrome, so you can see what I'm dealing with. I could just be making a fuss about nothing.
Shreddie
PostPosted: 23:59 - 08 Dec 2009    Post subject: Reply with quote
Pits on yer forks ain't easy to get rid of as it requires rechroming and regrinding. All I can really suggest is to keep your forks clean and try to prevent the rust/pits getting any worse... Eventually though, the pits will get worse and start knackering your fork seals... At that time you could either get your stanchions rechromed/reground or get a new pair of stanchions or forks.
temeluchus
PostPosted: 00:07 - 09 Dec 2009    Post subject: Reply with quote
https://i528.photobucket.com/albums/dd323/dodirectory/Muffys%20Car%20Pics/DSC00146.jpg
PostPosted: 00:55 - 09 Dec 2009    Post subject: Reply with quote
On one of my stanchions I had a few little rust spot. I flicked the rust out with my finger nail and I've never had a problem with any leaking.
el_oso
PostPosted: 12:42 - 09 Dec 2009    Post subject: Reply with quote
trick that has worked for me
buy some clear enamel nail varnish. apply some to the pits and use your old fork seal to run over the area to cover the hole and wipe away an excess. repeat a few times and the hole magically disappears (well sort of). then polish her up again. worked well for me
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 13:57 - 09 Dec 2009    Post subject: Reply with quote
https://img.photobucket.com/albums/v295/chris-red/06052009223.jpg
Abba Stand and front lift, I think it was about £120 all in all, more expensive than axle stands but once it was delivered it took me longer to get it out of the packaging than it took to get both the TDM's wheels off the ground on my own first time. Now I can get my bikes up on the stand in about a minute less than 30secs if sombody is helping me.
Sorry for the shite pic.
The last post was made 16 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 119.76 Kb
