Kawasaki GPX250
xXshadowXx
PostPosted: 07:08 - 07 Dec 2009    Post subject: Kawasaki GPX250 Reply with quote
got me a nice green GPX250. I went to change the front brake pads on it, managed to get the pads off with a little leverage, but when I went to put the new ones on, I found that they wedged in very tightly together as the pads were thicker due to not being worn. As a result I couldn't fit so much as a peice of paper in between them let alone squish the disc back in.
How do I get the pads apart to put them back on the disc?
thanks guys
temeluchus
PostPosted: 08:22 - 07 Dec 2009    Post subject: Reply with quote
youll need to give the pistons in the caliper a thorough clean, and push them back into the caliper to get the new pads to fit.
Have fun.
Raffles
PostPosted: 08:40 - 07 Dec 2009    Post subject: Reply with quote
You need to take the new pads back out and force the piston back into the caliper. Special tools can be purchased for this purpose or you may be able to use a G clamp if you have one that is thin enough. I use a tool that is basically a flat piece of steel with a long handle welded to it at a right angle. I simply put this tool into the caliper where the disc would go in and by using a twisting action force the piston squarely back into the caliper. You may be able to improvise such a tool using a tyre lever with a pair of mole grips.
Cigaro
PostPosted: 11:32 - 07 Dec 2009    Post subject: Reply with quote
As said you need to push the piston back into the calliper, open the master cylinder cap first so you don't cause too much pressure in the system.
PostPosted: 13:16 - 07 Dec 2009    Post subject: Reply with quote
As above, but note that there is a good chance that when the cap is off and you push the pistons back in the fluid will squirt out of the reservior. Put something around that area to protect the paintwork (brake fluid wrecks paintwork).
GPX250 uses a twin piston sliding caliper (from memory), which should make pushing the piston back pretty easy. Remember that if you push just one piston back the fluid has to go somewhere, and the 2 easy places for it to go are back to the reservior or for it to push the other piston out. Watch out for the other piston and try and get both to go back at the same rate.
The last post was made 16 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 44.01 Kb
