 Serendipity World Chat Champion
 Posted: 14:46 - 07 Dec 2009 Post subject: CBR954 Charging Problem |
Yes, it’s a Honda with a charging problem. What a surprise.
What I want to know is where the problem is most likely to be?
The Facts:
The battery predates my ownership of the bike so I suspect a minimum of four years old. It could possibly be the original battery so therefore seven years old.
I am a daily commuter; however my commute is quite short with speeds rarely exceeding 40mph. I always ride with lights on.
I have an alarm/immobiliser that adds to the drain.
In the summer months I never have a problem, but during the winter I normally leave the bike on trickle charge overnight once a fortnight to keep the battery topped up.
Yesterday the bike died in traffic (ironically on the way home from Maplin after purchasing some parts to make up a charging connector to keep under the seat). After jump starting the bike I tested the voltages. With the discharged battery and the engine running the values were only about 12.5v rising to 13.4v at 5000rpm. If I switched on the lights the voltage dropped to 11.8v even at high revs. Not good. A very nice man from the AA gave me a lift home with his (complete overkill) 10 tonne flatbed.
This morning after a night on trickle charge (12 hours at less than 300mA) and a ride to work (with the lights off) the battery tests as follows:
Ignition off: 12.67v
Ignition on: 12.50v
Engine running at 5000rpm: 14.40v
Engine running at 5000rpm with lights on: 12.50v
Still not great.
So I’m after recommendations for next step. New battery? Or will that just mask a deeper problem? New reg/rec? That could get expensive. I still need to run through the steps from the Haynes manual to test the reg/rec and alternator connections.
Cheers
Simon ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
 Cigaro World Chat Champion
 Gawain Nitrous Nuisance
 Posted: 17:01 - 07 Dec 2009 Post subject: |
OK, next question then…
…what is the practical difference between a Kyoto battery at £49.99 and a Yuasa battery at £114.99?
Both appear to be sealed gel batteries. Just build quality? Name?  ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
