dt 125 overheated and steamed can any one help?
wil1hit
PostPosted: 19:31 - 07 Dec 2009    Post subject: dt 125 overheated and steamed can any one help? Reply with quote
Crying or Very sad Crying or Very sad i have a dt 1988 been totally restored went out tonight and it overheated and steam bellowed what could be the cause please
oldbiker
PostPosted: 20:03 - 07 Dec 2009    Post subject: Reply with quote
I`m not familiar with DT`s, but at a guess thermostat stuck and not opening.
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
el_oso
PostPosted: 20:58 - 07 Dec 2009    Post subject: Reply with quote
blocked radiator pipe somewhere
Duke 390
Car: Jeep Wrangler 4.0L
Billing
PostPosted: 21:05 - 07 Dec 2009    Post subject: Reply with quote
I'd agree wit ha dodgy thermostat, in the end the one in my TZR was taken out (I found out from a mate of mine) It shouldn't do it any harm to run without a thermostat, from what I've been told it will just take longer to warm the coolant up initially Smile
Failing that, did you bleed the system? If it's got an air lock I'd expect it to over heat
wil1hit
PostPosted: 22:14 - 07 Dec 2009    Post subject: Reply with quote
thanks for the right direction folks will have a look the week end Very Happy
PostPosted: 22:28 - 07 Dec 2009    Post subject: Reply with quote
It could be lots of things:
It could be a poorly bled cooling system, a dodgy thermostat, or a blown head gasket. You need to try to find out if you have a coolant leak, and do some investigation before you decide on the cause. We won't be able to give you a definitive answer without more information though.
Is there a water leak?
What did the temperature gauge say?
Are all the hoses and gaskets tight?
wil1hit
PostPosted: 23:18 - 07 Dec 2009    Post subject: Reply with quote
temp said off the clock will try therm in pan of hot water, if thats fine will tryalternative flow from pump ill replace the head gasket anyway because they are only 6 quid can anyone advise best place 2 get thermostat if it is gone please
bladerunner
PostPosted: 01:05 - 08 Dec 2009    Post subject: Reply with quote
if it's non of the above then check things like is the rad cap sealing and are there any air leaks in the reed block etc causing it to run lean etc...also possible crank seal failure if it like I said any of the above!!
oldbiker
PostPosted: 21:33 - 08 Dec 2009    Post subject: Reply with quote
the_godfather and bladerunner,
both list other things worth looking at after you check the stat, although I don`t think that an air leak or dodgy reeds are the problem (they would show up as tick over problems and very pale deposits on the spark plug)
For yam spares I check fleabay or the interwebnet thing, and often end up buying from stinkwheels or yambits (both good dealers)
The last post was made 16 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 59.78 Kb
