| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 08:57 - 08 Dec 2009 Post subject: |
You want noise? You want one of these, you do. Uses a C# proggy to convert the USB to MIDI :-
https://www.bikechatforums.com/files/dsc00107_190.jpg
Just need to pull my finger out and sort the latency so I can have 6 strings instead of 4, and put it into a guitar body. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Hobes |
 Hobes Crazy Courier
 Posted: 09:29 - 09 Dec 2009 Post subject: |
I have a Roland VG-88 for midi stuff, although that's pretty much exclusively guitar based modelling.
I did borrow another Roland module from a mate for a bit and this did do piano/brass instruments etc but it was very difficult to get set up correctly and would often get lost if you tried to play any quick phrases. Midi is ok to play around with but essentially it's quite gimmicky IMO and I'd certainly never find a use for it live. ____________________ Current: Suzuki DRZ400sm (07) https://fbc.spruz.com
XBL: Matt Hoban
PSN: MattHoban |
 Posted: 16:02 - 09 Dec 2009 Post subject: |
That MIDI plank of Shaggy's look so crap its coolness is assured . (no-way i could build anything like that )
What kind of things do you trigger? I suspect some Bass synth reinforcement?
One of the reasons i've not looked into the Roland VG stuff was its price and installation. Sounds good...can't knock it.
I sometimes use a Variax 300 guitar. It uses piezo bridge pickups to capture each individual string’s
vibrations, and process the signals through software algorithms that captures the physical and electronic
properties of the guitars that have been modeled (26 including sitar,reso and acoustics). But it doesn't do MIDI
I don't find MIDI gimmicky...old and restrictive maybe.
I also use GuitarRig and use a MIDI footboard..works great with 4ms latency at 24/96 so no noticeable delay, has some nice features but it doesn't turn my guitar into a drumkit Whereas that Sonuus G2M will keep the neighbours guessing 'WTF is he doing now' for a good while longer.
Pat ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| The Shaggy D.A. |
 Posted: 16:41 - 09 Dec 2009 Post subject: |
| Howling Terror wrote: | What kind of things do you trigger? I suspect some Bass synth reinforcement? |
It's got 4 note polyphony, plus the joystick handles pitch bend and modulation. If I stick to 4 strings, I can have velocity sensitive triggers too, whereas going to 6 means key on/off only. Each string is configurable for voice and tuning, so I can have any combination I fancy. I'll be modding the software so that I can have it play autochords, like the Suzuki Omnichord. That way I could have (say) lowest string play major chords, second plays minor, third plays major sevenths, fourth plays minor sevenths etc. with various arpeggiator patterns.
Once I sort out the latency and it moves from Alpha to Beta I'll post some videos. I've got a Strat neck I need to hollow out and adapt for the fretboard and I haven't decided on the body shape yet. I might make it headless to match my Westone Quantum bass. Don't hold your breath though, I'm a lazy bastard  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
 Posted: 22:36 - 09 Dec 2009 Post subject: |
Bespoke baby
You'll be in noodling heaven. I think the headless look will suit your cosmic guitar. What bodies you thinking of? BC Rich style or more trad or maybe a Gibson Firebird (loads of room for inside trickery) Mind you looking at your pic, you'll have a bigger choice.
Would love to see you complete it.
[doffs cap]
| The Shaggy D.A. |
| Hobes |
 Hobes Crazy Courier
 Posted: 17:40 - 10 Dec 2009 Post subject: |
Shaggy, that will be one radical axe.
Agonyst, maybe its related to your pickups. Or your placement of head and cab in relation to the stage microphones or even a stage monitor/wedge with a poor foldback mix.
I'd ask the question in the Sound on Sound guitar forum.
Personally i like all types of guitar amps. Valve/SS but did send an Epiphone hybrid amp back. Horrid digital reverb and loud noisefloor.
I occasionaly play live and use a 1980 Peavey Bandit (75w) combo. Very very clinical even when driven hard. Its the only large amp i have now...apart from a Marshall 40 Valvestate(can only produce 1 nice tone...pants)
So most of my playing is on little practise combos. Orange Tiny Terror, Orange Crush 10 and one of those little Orange Microcrush things .
Also got a modded Epiphone valve Jnr. Maybe 5watts but like the Tiny Terror its valve so its still loud I use a power soak so i can drive the valves hard enough to sound nice, yet not make my ears bleed.
On one of the Strats i use noiseless pups..perfect for playing in rooms with dimmers and lots of electrical gear...Not so good for Shredding tho
| Hobes |
 Hobes Crazy Courier
 Posted: 13:24 - 11 Dec 2009 Post subject: |
| Howling Terror wrote: | Shaggy, that will be one radical axe.
Pat |
My basic Live Rig is EMG equipped Ibanez K7 or the Dean 7 string I have, again with the 7 string equivalents of the EMG '81 and '87 into my Line 6 head via my AKG wireless and the Boss noise gate. I also sometimes run into my BBE sonic maximizer although that is currently out of action as I knackered the power supply.
I considered running the solid state Line 6 into a Peavey 5150 or XXX to see how that sounded but haven't got round to trying that. Personally I think that if I'm struggling to tame the Line 6 then running that into the Peavey's probably not going to work too well! ____________________ Current: Suzuki DRZ400sm (07) https://fbc.spruz.com
XBL: Matt Hoban
PSN: MattHoban |
The last post was made 16 years, 275 days ago. Instead of replying here, would creating a new thread be more useful? |
