 Gilly Two Stroke Sniffer
 Posted: 16:53 - 09 Dec 2009 Post subject: Main Relay ? |
Hi Folks,
I have a CBR 125 R5 06 plate and have the following issues.
When i turn my ignition on there is nothing... battery and fuses all checked and ok !
I am slightly confused about one switch in particular, the main relay.
In the haynes manual page 9.5 and diagram 5.8 there is a diagram of a main relay. now when i phoned honda and searched on flebay i had no luck as honda said i would need to bring my bike in.
my problem is if it is listed as a main relay why cant i just order that.
it aint the starter relay because that is located under the fuses with a fuse in it.
it describes it in the haynes manual as controling all the "lighting, signaling and instrumental functions".
so what is it called if its not a main relay ? a light relay ?
https://img205.images...i/img1222q.jpg/
Help |
 Itchy Super Spammer
 Posted: 17:00 - 09 Dec 2009 Post subject: |
your link does not work , at a guess I think it might be the starter relay. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
 Posted: 17:16 - 09 Dec 2009 Post subject: |
fixed the link. https://img205.imageshack.us/i/img1222q.jpg/
Its not the starter relay as the relay is under the fuses and has its own fuse.
i am now starting to think the spade connector has been an attempt at a botch electrical job. |
