Right angle gear box?
UnknownStuntm...
PostPosted: 21:17 - 09 Dec 2009    Post subject: Right angle gear box? Reply with quote
So, I have a project that needs it's drive turned through 90 degrees. Essentially I'd like a 1:1 ratio, but it's not massively important. Somewhere between 1:1 and 2:1 would be ok. up to about 40hp, 1000 rpm input, no idea of the torque, but certainly no more than 60nm.
I'm liking the idea of an industrial gearbox, like these:
https://www.tandler.co.uk/sbg/s13-1.jpg
But, I think it's going to be big, expensive and heavy. Another option is a shaft drive motorcycle setup, but I have no clue as to what to look for, and what drive ratio it would give. All I'm aware of is Moto Guzzi, Beemers and some Divvys that have them, but any more tech specs I'm lost on.
Could someone give me some clue? Preferably with pics of a stripped down unit?
PostPosted: 22:31 - 09 Dec 2009    Post subject: Reply with quote
You need a bevel box off a shaft drive bike. I'd suggest a Yammy XS/XJ bike like the xs1100. Most if not all of them will be a completely independant unit.
smegballs
PostPosted: 13:38 - 10 Dec 2009    Post subject: Reply with quote
If thats the case I have the engine/gearbox and rear wheel off a XJ650 so you could work with either end bezel wise. Off the turbo model so should be powerful enough....
It (and a load of other XJ stuff) is just sitting there doing nothing so you are welcome to it.
Where you to in the country...?
UnknownStuntm...
PostPosted: 14:44 - 10 Dec 2009    Post subject: Reply with quote
You are the proud owner of a Personal Message, sir. Thumbs Up
The last post was made 16 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 39.53 Kb
