Do you like ABS?
kawashima
PostPosted: 13:55 - 10 Dec 2009    Post subject: Do you like ABS? Reply with quote
Do you like ABS on bikes? Have you ever tried one?
own:2020 Serow 250
PostPosted: 14:13 - 10 Dec 2009    Post subject: Re: Do you like ABS? Reply with quote
I have ridden a BMW K1200s with it on track; it didn’t cause any problems, but I didn’t try and ‘test’ it with harsh braking on slippery sections. There was some people taking the same bikes around very quickly and it didn’t seem to be causing them problems. This was on a dry track.
Initially, I didn’t like the idea, but I’m coming around to it if it works well in the wet etc. However, the rider will have to be very aware that you still won’t be able to grab a big handful of brake in all conditions. I’m pretty sure you’re still going to be on the floor if you try and use too much braking force while near the limits of traction through cornering, especially in the wet.
However, for day-to-day riding, going to work or the shops through town, I could see it would be very useful to allow very good braking despite bad weather conditions.
Definitely has to have an off-switch, so you can still do stoppies!
I quite like the look of the new BMW1000SS, which has traction control and ABS. If some people crash them after using harsh braking mid-corner like you can in a car, I might pick a damaged one up cheaply in a few years time for a commuter Smile.
LeeR
PostPosted: 14:17 - 10 Dec 2009    Post subject: Reply with quote
Most of the courtesy bikes I've ridden over the last year have had ABS and to be honest I didn't notice the difference, but then again I didn't do anything stupid like grab a fistful of front brake.
My claim to fame: Austin Vince nicked my pen...
PostPosted: 14:25 - 10 Dec 2009    Post subject: Reply with quote
Good for commuting and what not I wouldn't want it on a fun bike though. My next TDM900 will hopefully have it.
kawashima
PostPosted: 14:29 - 10 Dec 2009    Post subject: Reply with quote
Bike shop clerk told me, "If you use rear brake when you enter the corner, you'll feel strange on ABS bike" and I believed it. But now I regret that!
own:2020 Serow 250
PostPosted: 14:33 - 10 Dec 2009    Post subject: Reply with quote
The ABS only comes into play when you lock the wheels, I lock my rear often (most of the time not on purpose) But have never done it in a corner.
I can't see how it would feel weird unless you are locking the wheel going into a corner.
PostPosted: 14:44 - 10 Dec 2009    Post subject: Reply with quote
I wonder what happens if you use engine braking to get the rear wheel going slower than the front (as I do with some regularity Confused), then use the front brake. Presumably the opposite (doing a doughnut etc) would cause problems as it might think the front is locking up.
PostPosted: 14:57 - 10 Dec 2009    Post subject: Reply with quote
ABS only acts on the single wheel I thought if a wheel stops turning (locks) while the biks is still moving forward it will back off the brakes abit.
Unless BMWs have a fancy linked version
Acemastr
PostPosted: 15:42 - 10 Dec 2009    Post subject: Reply with quote
Generally it'll kick in when a certain pressure is applied to the brake and the wheel is beginning to slow down enough to stop turning. Doesn't work like traction control with regards to different wheel speeds
2016 Toyota Tacoma Limited
Chris750
PostPosted: 16:18 - 10 Dec 2009    Post subject: Reply with quote
If it helps prevent a few offs it can only be a good thing in my mind.
As long as you have the ability to turn it off when not required.
You may not want it in a race situation but I imagine when it becomes more common on the road it will be more commuter style bikes that have it.
I agree G, that new BMW looks really nice, I never thought I would ever find myself saying that about a BMW Smile
tatters
Exxon Valdez
PostPosted: 16:27 - 10 Dec 2009    Post subject: Reply with quote
I had a bandit 1200 hire bike for a month a few years ago which had ABS, did,nt like it at all felt like it cut in too soon which got really anoying, other bikes probley have better systems.
Skudd
PostPosted: 17:00 - 10 Dec 2009    Post subject: Reply with quote
I have ABS and linked brakes on my Varadero, it isn't intrusive and only kicks in when it is useful to do so. It will not save you when there is no grip at all, ie ice, snow, deep mud, slippery grass that sort of thing, but will save you on those SMIDSY moments. It can sometimes lengthen your stopping but it will keep you more in control.
Would I get it again? Yes!
PostPosted: 17:14 - 10 Dec 2009    Post subject: Reply with quote
Not needed any so far, so for me it'll be an extra expense and something else that can go wrong.
PostPosted: 17:15 - 10 Dec 2009    Post subject: Reply with quote
How is it when it's really wet and cold? Can you still pull the lever as hard as possible and let it sort it’s self out.
Generally, I’m ok braking hard (from the racing and stoppy practice etc) in the dry, but naturally more cautious in less favourable conditions.
D O G
PostPosted: 17:24 - 10 Dec 2009    Post subject: Reply with quote
I'd say yes, even tho I normally dislike 'driver aids'. Read about them in PB, where an ABS fitted beemer tourer stopped in very wet conditions in 70% of the distance a non-abs CBR600RR managed.
It's in low grip situations like those where I would like its backup, I doubt it would make much difference on dry roads in normal riding conditions.
twostroketit
PostPosted: 17:29 - 10 Dec 2009    Post subject: Reply with quote
I've never ridden an ABS equipped bike myself,but i can certainly see where the merit lies.
I don't tend to use my brakes very often but just occasionally the situation may arise when i need to stop quickly.
If the road surface isn't what it should be ABS would be invaluable but i have wondered what it would be like riding quickly on perfect roads.
I do remember when BMW first marketed ABS in the late eighties a journalist managed to stop quicker on a "normal" bike against an ABS one.But that's not really getting the point, ABS is designed to be dormant until the need arises, then it kicks in.
I think if i was buying a new machine and i had the option then i would get ABS.
The first time you use it it should pay for itself.
sup up your beer and collect your fags
PostPosted: 18:44 - 10 Dec 2009    Post subject: Reply with quote
When I had it on my hire bikes I was testing it all the time It deffiantly saved me on 1 occasion, it is loud and is not a nice feeling when the brakes are adjusting themselves but I never found it interfered.
colin1
Captain Safety
PostPosted: 00:34 - 11 Dec 2009    Post subject: Reply with quote
From what I've heard, ABS is something you tend to have on big tourers with linked brakes, so you no longer have separate control of front and rear brake.
PostPosted: 08:15 - 11 Dec 2009    Post subject: Reply with quote
It's actually on quite a lot of lighter bikes these days - I think the G650 (real weight around 145kg) I tried had it, I was trying to remember how much I 'tested' it, but again I didn't really try and push the front.
The new BMW sports bike I'm pretty sure doesn't have linked brakes, the Hondas ae more likely to, as Honda loves sucking the fun out of biking Razz.
27cows
PostPosted: 08:30 - 11 Dec 2009    Post subject: Reply with quote
No, I don't. If I was an eejit incapable of using normal brakes, I'd retire from riding and be done with it Laughing I think ABS is a good idea on cars, though, as most drivers seem to be eejits incapable of using normal brakes etc Laughing
PostPosted: 09:26 - 11 Dec 2009    Post subject: Reply with quote
I had it on a Bandit 1250 (09) and a CBF600 (04), I don't think these where linked it, loads of bikes have it as an option now most of which do not have linked brakes, TDM, Tiger, most hondas, Blandits etc.
Edit, I also ment to say the Honda system was FAR superior to the Suzi one.
Adrian
PostPosted: 10:25 - 11 Dec 2009    Post subject: Reply with quote
Pro ABS here Smile
DAS 18/06/09 Off The Kerb Motorcycle Training. Proud owner of a Honda CG125 & a Honda Hornet
ClaireBear
PostPosted: 21:41 - 11 Dec 2009    Post subject: Reply with quote
The bandit I ride has ABS. I havent noticed any problems with it- but then again I havent slammed the brakes on lol
hellkat
PostPosted: 22:23 - 11 Dec 2009    Post subject: Reply with quote
Ooo, 'e's GOOOOOORGEOUS.
And so damn nice, too.
Mr. Green
c-m
PostPosted: 21:05 - 12 Dec 2009    Post subject: Reply with quote
why wouldn't you want something that will allow the bike to brake when on the absolute limit? surely its it allows you to brake harder and faster, since you won't be locking brakes which slows you down.
Of course most people are skilled enough not to lock their brakes, but they are probably not on the absolute limit of traction. doesn't ABS allow you to be on this limit?
The last post was made 16 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 128.3 Kb
