Idle speed
Tom_B1H
PostPosted: 15:55 - 09 Dec 2009    Post subject: Idle speed Reply with quote
My (04) zx6r is idling too high (1600+rpm).
I have the idle adjustment all the way out. Any simple easy explanation??
Many Thanks
Previous: '08 Suzuki DRZ400SM > '04 Kawasaki ZX-6R B1H
Current: '07 Kawasaki ZX-6R P7F
yen_powell
PostPosted: 16:33 - 09 Dec 2009    Post subject: Reply with quote
You do have slack in your throttle cable don't you?
XT1200Z and a DR350 in bits
shadowbiker
PostPosted: 18:03 - 09 Dec 2009    Post subject: Reply with quote
+1 or air leak
shadowbiker
tweek the air screw ?
Tom_B1H
PostPosted: 16:44 - 10 Dec 2009    Post subject: Reply with quote
I have slackened off throttle and choke cable but still idles way too high, do not know how to tweek fuel/air
serlant
PostPosted: 17:48 - 10 Dec 2009    Post subject: Reply with quote
hows the slack in the choke lever?
Tom_B1H
PostPosted: 18:04 - 10 Dec 2009    Post subject: Reply with quote
engages after 1/4 of slide
temeluchus
PostPosted: 22:49 - 10 Dec 2009    Post subject: Reply with quote
that will be a FI controlled bike i reckon.
Air leak or cable as previously stated, im afraid youll have to get the tank off to make sure the cable is not pinched or trapped.
Tom_B1H
PostPosted: 17:41 - 30 May 2010    Post subject: Reply with quote
Save me starting a new post
Bike righted itself all through the winter and now the warm weather has arrived its idling at 3k Shocked
Dont really know what im looking at but i removed tank etc. and saw there was a slight gap between throttle bodies and engine inlet rubbers (thought this might be something to do with it) pushed back in and no difference...
Throttle cables seem fine?
serlant
PostPosted: 18:54 - 30 May 2010    Post subject: Reply with quote
A slight gap?!? Shocked pushing it back in might not have helped because theres still an air leak, i'd be undoing all the clamps seating the bodies properly and doing them back up.
Tom_B1H
PostPosted: 19:46 - 30 May 2010    Post subject: Reply with quote
Are you suggesting this is the cause? I undone the clamps, it was a real fiddle trying to get them in, i'd say they could go in more but the rubbers are surrounding the bodies?
Tom_B1H
PostPosted: 14:57 - 31 May 2010    Post subject: Reply with quote
Also the revs fall slower when in neautral. Again though i dont really know
serlant
PostPosted: 15:02 - 31 May 2010    Post subject: Reply with quote
revs dropping slowly to idle can be caused by a small air leak, when i had one i sprayed some wd40 aorund the rubbers, couldn't hear a change in engine note, but i could see the wd40 being sucked in.
Tom_B1H
PostPosted: 20:28 - 31 May 2010    Post subject: Reply with quote
Fixed now, was indeed an air leak, angle of the inlet rubbers.
The last post was made 15 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 78.99 Kb
