Another pitbike project!
swiftb
PostPosted: 21:42 - 12 Dec 2009    Post subject: Another pitbike project! Reply with quote
So this is very much along the lines of Ojaxos thread in here. As its pretty much an identical bike!
Picked it up today cost me 65 notes. Also came with a complete spare rolling chassis, spare engine (in bits) spare carb, spare set of plastics, tank etc etc. (so basically 2 bikes - one good - ish and one pretty much fuked Laughing )
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2548.jpg
Its a py90 - 90cc semi-auto 3 speed. Has Jupiter written on casings?? Copy of a Yamaha pw80 with a Honda copy engine.
Anyways seems ok - I knew it had running problem so got to get to work on fixing that basically.
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2550.jpg
At first glance tonight its going to need the following doing:
Running problem to be fixed - fires up and runs on choke but when choke shut off it cuts out. Also when under full throttle it borks and then picks up again in a sort of rythmic fashion - bit bizzare.
Front brake doesnt work - cable has broke off at hub so probably just a swap from the donor bike.
Rear wheel has spindles missing and appears buckled - again should be a case of a swap from the donor which seems ok.
Stand broke of frame - can stay like that
Footpegs, there shit - better ones needed.
Plastics - not too shabby, clean up and maybe a cool sticker kit.
Chain - its rotten - good one on the donor tho Smile
Small rip in seat - some kind of repair required
Left hand grip has seen better days
Various things are loose like the swingarm and rear shock - looks like they have been swapped from the donor but not tightened.
When the bike is shut off/cuts out - fuel proceeds to piss out of the overflow pipe on the carb. Neutral
Also needs a good clean!
So all in all theres gonna be plenty to keep me busy over the winter which was the idea. Both frames have vin numbers - may even collect some bits and make a good one out of the spares yet but concentrate on getting one looking sweet first!
Will update as and when
cheers Thumbs Up
oJaXo
PostPosted: 00:24 - 13 Dec 2009    Post subject: Reply with quote
looks like you got a lot better deal than i did on that one mate
looking alot nicer and cleaner than mine Laughing
be looking forward to seeing your progress and possibly nicking a few of your ideas Wink
cheers
swiftb
PostPosted: 23:17 - 13 Dec 2009    Post subject: Reply with quote
Just a small update. Been investigating the running issue for a few hours today. Not much further forward with regards the full throttle issue but some improvements after adjusting the valve clearance and air/fuel mixture.
Further investigation tommorow if get chance.
Some more pics for now ;
whats left of the donor
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2560.jpg
after a quick clean
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2562.jpg
Back end sits reallllly low so rather than replace the shock like Ojaxo has, and since I have two good shocks anyway I plan to make a small extension piece to push the swingarm away from the frame about another 30mm which should raise it up a decent amount. (also i am a tight bastard so the less spent the better Laughing )
oJaXo
PostPosted: 00:10 - 14 Dec 2009    Post subject: Reply with quote
looks good Thumbs Up
just thought id let you know when you do put the rear end up just keep an eye on where the chain runs out from the front sprocket, mine was catching quite abit against the bottom of the engine casing
cheers
swiftb
PostPosted: 14:49 - 14 Dec 2009    Post subject: Reply with quote
cheers
Ye well spotted, noticed that today when tinkering so plan to fit a plastic chain runner to the inside of the flywheel cover which should hopefully prevent any problems.
Not much achieved today really - only had a short time to spend on it but managed to get the carb stripped and on inspection it seems very clean and seems to be working fine. Gave it another once over anyway but it seems like the problem is lying elsewhere.
Tried swapping the exhaust incase of a blockage but no good. Had the bike running for a good 15-20mins today and it started to bellow some smoke from around the crankcase area. Thought it was just the lube etc burning off at first but on further inspection I fear I may have uncovered what is likely to be the problem.
Unscrewed the oil filler and getting a fair old bit of whiteish/blue smoke coming out of the crankcase, and stinks of burning. Dont get that much out of the exhaust - unless on wide open throttle - but it does stink of burning oil. So its looking like its going to need a rebuild as Im fairly certain the rings are on the way.
My only worry is that if I rebuild it and find I still have the bogging down issue I may be extremely pissed off Laughing
swiftb
PostPosted: 23:13 - 16 Dec 2009    Post subject: Reply with quote
Update - After some time spent on the bike I managed to fix the Bogging down issue. After changing various pits and pieces and much fookin about I decided to check the valve timing. Hey presto it was a tooth out! Timed up on the F mark at the crank rather than the T mark. So the bike runs pretty much sweet as a nut - apart from the previously mentioned oil burning.
Had an hour or spare tonight so got to work:
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/workbench.jpg
Weight bench makes an awesome pit bike work station Laughing
Head and barrel off
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2572.jpg
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2569.jpg
Barrel and piston are in great condition tbh, but looks like a bit of blow by above the gudgeon pin area - so hoping this is where the problem lies.
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2579.jpg
Barrel is like new so im going with a piston and ring kit and see how that turns out. Parts ordered tonight need so source a gasket kit now.
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2581.jpg
Hmmmmmm, further inspection seems to look like could be headgasket/oil way o-ring which was letting oil into the barrell. The lot will be changed anyway as never can be 100% with these things
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2584.jpg
Pictures are bit out of focus thanks to my shat camera Neutral
swiftb
PostPosted: 20:43 - 22 Dec 2009    Post subject: Reply with quote
Progress is at a halt at the minute - still waiting for a batch of parts to turn up Thumbs Down
Today I decided to investigate the spare engine - it was mostly there in various bits. Was actually seized up solid so stripped head and barrel to see why. It looked like its hydrauliced. Had water in the barrel and the top of the barrel had a nice rusty layer round it, piston seized in solid. Got it all apart and give eveything a good clean and lube up.
Reassembled it and she spins over! So I decided to see if it ran. Rebuilt with all old gaskets for now, good compression so borrowed various items from the good engine- carb, cdi, kickstart etc.
Quick oil change and kicked it over. She fires up and runs! Goes through all the gears sweet as well. Cool
So now have a good spare engine (will need new gasket set fitting at some point)
[img]https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2591.jpg
Spare engine mocked up in the spare frame
Im now trying to decide what to do - i reckon to build the spare bike to a half decent standard with the spare engine in its going to cost around £160. But at that its going to a basic , average condition py90.
Not sure if its worth it really. May fit it into a modern pitbike frame but not sure how much a rolling chassis for something modern would be or how easy it would be to get hold of Thinking
oJaXo
PostPosted: 21:04 - 22 Dec 2009    Post subject: Reply with quote
had any luck with the burning oil issue with the other engine mate?
swiftb
PostPosted: 21:34 - 22 Dec 2009    Post subject: Reply with quote
Still waiting for piston kit and gasket set to arrive to rebuild the good engine. Looks like one of the oilway seals had blown allowing oil to piss across into the barrel, changing the lot anyways to be on safe side Thumbs Up
cheers
oJaXo
PostPosted: 21:39 - 22 Dec 2009    Post subject: Reply with quote
ideal:up:
tempted to do something with the plastics
was thinking about ether modding a different set of plastics to fit or cutting and changing the originals on there to look abit more modern-ish
what you think?
cheers
swiftb
PostPosted: 22:20 - 22 Dec 2009    Post subject: Reply with quote
oJaXo wrote:
ideal:up:
what you think?
cheers
Be interesting to see some modifications, personally im tidying up the original plastics and fitting a sticker kit.
Planning on going down the supermoto route with the good bike I think. Then maybe make a cheap 'shitter' dirt bike from the second one.
Theres an awesome outdoor kart track not far from me which has pit bike meetings and also a small enduro track about 20mins away so planning on having a bike for each Surprised
Check out the track - looks like a hoot
https://www.youtube.com/watch?v=dx35_TZm4Zk
cheers
oJaXo
PostPosted: 22:32 - 22 Dec 2009    Post subject: Reply with quote
fair enough Thumbs Up
that looks like awesome fun mate.
wish there was a track like that down near me Laughing
swiftb
PostPosted: 17:16 - 02 Jan 2010    Post subject: Reply with quote
Received the new piston kit and gasket set so engine is now rebuilt. Any other work is pretty much cosmetic now so time to give it a good run out at the nearby enduro track - once the weather clears up a bit Mad
barrel cleaned up
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2598.jpg
head cleaned up
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2601.jpg
new gasket and seals and piston kit fitted
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2602.jpg
Rebuilt
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2603.jpg
Had a little blat round the garden today and engine seems to run sweet enough now - still seems to be burning a bit of oil though. Nothing on the scale of what it was before the rebuild but bit pissed off that it still smokes a bit. Neutral
Maybe the stem seals are leaking a bit but to be honest it can stay like that as its only slight and not really a major issue. Could even be the oil is a little too thin.
One thing that has seriously pissed me off however is after re spoking the rear wheel and swapping the tyre over (which was probably on par with wrestling an alligator Smile ) I was waiting for a tube to turn up. Well the tube came and after another fight with the rear tyre/wheel I managed to get the tube in and tyre on - sorted. So I thought, seems ive punctured the tube getting the tyre on so its gonna have to come back off again. Swine Embarassed
Next plans - drill frame to mount the shock approx 30mm further back to raise ride height
Clean up plastics and fit sticker kit
Tidy up cosmetically (bit of paint here and there) and retrim/replace the seat
Ride the son of a bitch Thumbs Up
oJaXo
PostPosted: 17:35 - 02 Jan 2010    Post subject: Reply with quote
looking good Thumbs Up
eyed up a sticker kit for it yet?
swiftb
PostPosted: 20:03 - 02 Jan 2010    Post subject: Reply with quote
Yeh got some stickers just need to get the plastics prepped before I fit them. Ive had enough at the min tho, too sodding cold! Think I got mild frostbite today Laughing
Got to try and keep the costs down now as its starting to mount up. Theres all sorts I could buy and im tempted to go wild on it but I keep reminding myself its a py90 at the end of the day! Confused
Gazdaman
I did a trackday!!!
PostPosted: 23:06 - 03 Jan 2010    Post subject: Reply with quote
Changing the inner tube without removing the tyre is nicely easy.
It's WELL worth getting someone to show you how to do it for the first time. Someone experienced showed me how to do it first time and it made it lots easier from then on.
Looks like you've done a decent job. And the smoking oil could be cack in the exhaust. And you might find it stops once you've ridden it for a while.
Gaz
swiftb
PostPosted: 16:18 - 07 Jan 2010    Post subject: Reply with quote
Cheers Gaz,
ye I wont be fully removing the tyre to change the tube, but the carcus on these little 12" blighters it tight as hell, need to pop one half of the tyre off the rim to get the tube out.
Ordered a spare tube incase this one wont repair anyways.
Got a sticker kit sorted here is the progress with it so far. Still got number board to do and front fender but this is how its looking.
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/rockstar.jpg
Not far off now, just need to get the ride height and puncture sorted then the cosmetic stuff can wait until it warms up a bit as spraying paint on too freezing cold metal isnt going to give a great finish Neutral
ps. I do realise a mixture of red bull and rockstar may not taste too clever Razz
swiftb
PostPosted: 19:49 - 07 Jan 2010    Post subject: Reply with quote
Another shot from the rear
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2615.jpg
Note the stunning tailpipe addition Laughing
Ok so got the numberboard sorted and I raised the ride height. Looks a lot better for it I think.
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2616.jpg
Havent taken any photos of adjusting the height as its not particularly interesting. But basically I drilled the frame where the shock mounts approx an inch further back to force the swingarm further away from the frame, effectively raising the height.
I like this shot - looks like its raining fireballs Laughing Unfortunately its not, its snow - more of the bastard stuff Neutral
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2620.jpg
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2617.jpg
https://i441.photobucket.com/albums/qq135/photobucca/mini%20bikes/CIMG2618.jpg
Dont want to spend much more now so this is pretty much as far as it will go apart from tidying up whats already there, few stickers for the front guard etc - although im tempted with the odd addition like some decent pegs etc
oJaXo
PostPosted: 15:59 - 08 Jan 2010    Post subject: Reply with quote
have you raised to the max height now then?
swiftb
PostPosted: 22:59 - 08 Jan 2010    Post subject: Reply with quote
Not quite max height, theres still a few mm play, just didnt want the swingarm fully topped out (not that it really matters once you sit on it i suppose)
See what you mean about the chain rubbing on the lower casing. Maybe a little chain runner bonded to the inside of the casing, what you reckon? Thinking
oJaXo
PostPosted: 23:32 - 08 Jan 2010    Post subject: Reply with quote
yeah thats what i was thinking with the chain rubber on the bottom of the casing.
ether that or grind a part off the bottom of the casing Confused
dont think it rubs when your sitting on the bike does it?
havent actually had the chance to ride mine for so long i forgot Laughing
cheers
baldy
PostPosted: 00:40 - 10 Jan 2010    Post subject: Reply with quote
You need to give me that spare rear shock and carb.
You REALLY need to.
Please.
One day i will rule the world, just not today.
swiftb
PostPosted: 11:29 - 10 Jan 2010    Post subject: Reply with quote
You REALLY need to.
Please.
Unfortunately the spare carb is missing the choke and generally a bit shagged. Be using the spare shock on the spare frame too hopefully! Sorrrrrreeeee Laughing
PEEWEE109
PostPosted: 14:56 - 25 Jan 2010    Post subject: Reply with quote
hi bud your py90 looks cool yeah , where did you your stickers from as been trying to find some for my py90 , cheers
The last post was made 16 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 131.26 Kb
