| Jamie S |
 Jamie S World Chat Champion
| ms51ves3 |
 ms51ves3 Super Spammer
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| Jamie S |
| Blue_SV650S |
| TUG |
 TUG World Chat Champion
 Posted: 23:47 - 13 Dec 2009 Post subject: Re: Yamaha fork damper rod Tool, dt125... size? |
| jamie stokes wrote: | Hi guys, I'm doing a set of fork seals on my 98 dtr125, the problem is the allen bolt that holds the damper rod in is just spinning, tryed using a wooden dowl shapped to a taper and wedged in to hold the rod but won't grip it well enough.
I would be able to use a bolt of the right sized head and weld it to a length of bar to hold the damper from the inside, the only problem is I don't know what size head I would need, does any one know ? (even roughly?) at a guess its looks to be around 20ish mm , but hard to tell as the leg makes it very hard to judge
I'm going to try my impact gun on the allen bolt in work tomorrow and hope this will free it off, if not then looks like im going to have to hunt around and try find a bolt of the right sized head.
Regards, Jamie. |
As said, you only get this problem when the damper rod is free, spring back in and your laughing. its really easy changing fork seals. ____________________ Haz ER-5, innit! |
| Billing |
 Billing World Chat Champion
 Posted: 00:06 - 14 Dec 2009 Post subject: |
When I did my TZR seals all I did was lever my old ones out with a screwdriver, put the new ones in and haven't had any troubles yet
But I think the haynes manual says you should remove the allen bolt before the spring (Y) ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| 27cows |
 27cows World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 11:00 - 14 Dec 2009 Post subject: |
| chris-red |
| TUG |
 ---- World Chat Champion
 Posted: 19:34 - 14 Dec 2009 Post subject: |
~There easy enough to make yourself...
I made mine out of an old socket and grinder to get it to the right shape,took about 10mins to do. Cant find a pic of mine
I also made the same kind of thing as Hmmmnz said for my gs500,but i used a long length of threaded bar with 2 nuts locked together on either end. ____________________ DRZ-400sm |
| Jamie S |
 Posted: 20:34 - 14 Dec 2009 Post subject: |
I'm sure it's only a few inches long at the most.
I can't see any reason you couldn't drill the head off,it won't be tight into the damper rod once the head's off but i would try my best to get that wood out and do it the proper way just incase...
EDIT:
If needed i can go and take some pics of the internals (damper rod/allen bolt length e.t.c.) if it helps? ____________________ DRZ-400sm |
| Jamie S |
 Posted: 23:35 - 14 Dec 2009 Post subject: |
| chris-red |
| TUG |
| Mark65 |
 Mark65 World Chat Champion
| Jamie S |
 Posted: 17:59 - 16 Dec 2009 Post subject: |
Sorted it, managed to get the wood out and used my spair rear wheel spindle welded on to a bit of bar, perfect size.
| TUG |
The last post was made 16 years, 302 days ago. Instead of replying here, would creating a new thread be more useful? |
