| funmonkee |
 funmonkee Super Spammer
 Posted: 11:40 - 12 Dec 2009 Post subject: Garage heating |
Apparently there are low power consumption heating lamps available for garages. The dude that told me this said he has some that consume less than 1p per hour... although he now can't remember where he got them, make or branding...
SO, can anyone post a link to something like this
Thank you peeps  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b] |
| Vincent |
 Vincent Banned
 Posted: 12:06 - 12 Dec 2009 Post subject: |
1p an hour is cheap I could do with one for the house, let alone the garage. I use a Zibro Kamin Parrafin heater in the lock up - no condensation or lingering smell as with older parrafin heaters. Although, it might have worked out cheap when i first got it but it's not so great nowadays. |
| Wise1 |
 Wise1 World Chat Champion
 Posted: 12:15 - 12 Dec 2009 Post subject: |
I am using this one, not quite 1p an hour, its 20p an hour on maximum, but it has the benefit of blowing the heat, has a remote and you obviously control it so that once the garage is up to temp you can turn it down.
https://www.feelconfident.co.uk/b-amp-q/airforce-wall-mounted-heater-remote-control ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600 |
| unitybiker |
 unitybiker Nova Slayer
| Vincent |
 Vincent Banned
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 14:34 - 12 Dec 2009 Post subject: |
I use a T shirt under a sweatshirt. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 15:31 - 12 Dec 2009 Post subject: |
invest in insulation, it`s a one off cost that will pay for itself in a couple of years,
When I layed the concrete slab for the base I put some polystyrene under the concrete
I used fiberglass 1 inch plus 3mm plywood on the sides, 3 inch plus 3mm plywood on the roof, 1 inch fire proof-sound absorbent foam on the door,
I also have a small dehumidifier 180 watts maximum, the dehumidifier costs about (£65-£70 to buy) £1.20 a week to run in the winter \ £0.20 during the summer.
The dehumidifier heats the garage to about 3 degrees above the outside temperature,
when I am in the garage I use a small fan heater but because of the insulation I don`t use it for long periods
the costs are offset by not having my bike, lathe, spare parts, etc. going rusty.
I`m not showing off just giving a few suggestions ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
| Alexio |
 Alexio World Chat Champion
 Posted: 18:22 - 12 Dec 2009 Post subject: |
Are you talking about this?
https://www0.uk.shopping.com/xPO-DXLWP400 ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 20:58 - 12 Dec 2009 Post subject: |
based on the 400watts that uses and 13.5p per kw/h
that would cost 5.4p per hour to run
to get some heater to run for 1p per hour it would have to be 74watts less than a regular an incandescent light bulb
it is possible to use a type of in ground to air heat pump that uses the differing temperatures to move heat (not create it)
and the only electricity required is that to power the small electric pump,
but the cost of installing that would out weigh the benefits
basically you can't heat your garage for 1p an hour using electricity,
you could using a waste oil burner though, the amount of oil you use in all your bikes would probably be enough to heat your garage  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| funmonkee |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 19:34 - 13 Dec 2009 Post subject: |
If it is to keep the damp out, then use a dehumidifier?!!?!? ... gotta be lighter on the lecky and more effective way of removing damp than a heater!?!?  ____________________ The purpose of life is to fight maturity. |
| geordiecbrblo... |
 geordiecbrblo... Trackday Trickster
 Posted: 22:25 - 13 Dec 2009 Post subject: |
Have you considered one of these? 1p per day and you could then leave it in the garage?
https://www.bikebubble.co.uk/ |
| Vincent |
 Vincent Banned
 Posted: 23:19 - 13 Dec 2009 Post subject: |
Stick a bowl of silica gel in there  |
| lukamon |
 lukamon World Chat Champion
 Posted: 23:56 - 13 Dec 2009 Post subject: |
i think my dad had one of those. as you'd expect for the power usage it was fairly crap but probably kept stuff from going below freezing.
pic if i can find it again, basically a 60w lightbulb in a tube  ____________________ killa wrote: Im an ass man myself |
| cvntdude |
 cvntdude Spanner Monkey
 Posted: 09:54 - 14 Dec 2009 Post subject: |
Just get one of those 1200 watts heaters, they cost about a tenner and have three elements, each of which uses 400 watts .. after having it on full for 5 - 10 mins, stick it down to 2 or 1 elements, i use one in my living room as gas is so expensive, and compared to last years blow heater, it's saved me a fortune ...  ____________________ We all choose what to think about ... |
| stirlinggaz |
 stirlinggaz World Chat Champion
| hmmmnz |
 Posted: 10:50 - 14 Dec 2009 Post subject: |
your bro is a plumber/gas fitter aye??
why not get him to run a extra radiator out in to the conservatory and garage, if you wanted to be really creative you could run a heat exchanger off the flue on the boiler, and use some of the waste heat
electrically speaking, the most efficient way of heating is with a heat pump, maybe a modified a/c unit from a car you might be able to get down to your 1p an hour rate.... may be...
a halogen heat, while better than a regular resistive type bar or fan heater, they don't actually heat the air, they use uv, so only things that absorb uv light will get warm, not really much use in a cold garage ____________________ the humans are dead
| funmonkee |
 Posted: 18:10 - 15 Dec 2009 Post subject: |
Spoke to the garage dude and he said he's using tube heaters. I can't find any that give a quote of 1p per hour. I think the oil heater might be best.
@Hmmmnz, yeah the heat waste re-use would be cool (!) the extractor/flue thing at the side of the house is always chucking out heat.. if that could be re-used that would solve alot of problems  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
| Blue_SV650S |
| funmonkee |
| Vincent |
 Vincent Banned
 Posted: 19:12 - 15 Dec 2009 Post subject: |
| oldbiker |
 Posted: 19:26 - 15 Dec 2009 Post subject: |
philips thermo tubes,,
I have used them to heat lizards and other nice pets.
A one foot tube is about 40W
Assuming that electricity costs about £0.13 per Kw/Hr, 170 hours in a week thats about £0.89 per week.
I think they go up to about 300W
You could wire it into a central heating thermostat.
Just ideas. ____________________ It`s all powerfull white mans magic
| funmonkee |
| Vincent |
 Vincent Banned
 Posted: 19:44 - 15 Dec 2009 Post subject: |
You can also coat the vunerable parts of the bike with Duck Oil - I believe there's something similar available now that works wonders - the name escapes me at present.  |
| hmmmnz |
The last post was made 16 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
