| shanekaettle |
 shanekaettle L Plate Warrior
| Alexio |
 Alexio World Chat Champion
 Posted: 03:34 - 14 Dec 2009 Post subject: |
Throttle linkage? It's probably just the cable not adjusted properly  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| shadowbiker |
 shadowbiker Traffic Copper
TS50, im your man
Normally when you get dodgy idle/revving it means theres an air leak which on ts50's is bugger
I would remove the carb and clean/replace the gaskets ( what everone you prefer )
Then refit using silocone to give a good air tight seal from carb to barrel the a small bit on the air intake side and see if that helps.
If not PM me and ill help you out more.
EDIT : just seen youve changed your needle and slide at what position did you set the needle ? |
| Billing |
 Billing World Chat Champion
| shanekaettle |
| shadowbiker |
| shanekaettle |
| Azonicben |
 Azonicben Could Be A Chat Bot
 Posted: 16:27 - 15 Dec 2009 Post subject: |
[pedant]Great scot! My head hurts, so......little........punctuation, spelling atrocious.[/pedant]
Struggled to read all the way through that. I'm calling another tit50 account. Conveniently a lot of struggling ts owners around recently!
 ____________________ Cbt-23/09/07.....Theory-16/09/08.....Das passed 10/10/08.....
Current bike- GsxR750 K4. Broken: Cbr400rr (Nc29) Sold: Hyosung GT125R |
The last post was made 16 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
